Some time back, someone posted a type of jack that lifted the jack stand so it was in place when you lowered the floor jack. I can't find it or remember the name. Basically the flood jack fit under the jack stand and lifted it, then you could roll the floor jack out, leaving the jack stand in place.
Looking for a good way to lift my travel trailer for tire changes, needs to be portable incase of a flat. I have the wide trax axles so the drive on lifts will not work. I can take my 3 ton floor jack. Just want to revisit the jack stand system someone posted.
