Burning smell from rear wheel
by 2010Civic - 01/27/20 06:01 PM
2017 VW Golf 1.8T - Valvoline 5w40 MST - 8,600 miles
by BurntMusic - 01/27/20 06:00 PM
Cost to rebuild a Ford 4R75E vs. new or used.
by atikovi - 01/27/20 05:26 PM
Autozone Clearance 85w140 gear oil 5 gal
by GON - 01/27/20 04:31 PM
Resonating Noise at 3000rpm
by tookien - 01/27/20 04:28 PM
Looking for Purolator Tech oil filter pics.
by Black_Thunder - 01/27/20 04:02 PM
2019 Mini Cooper Clubman S ALL4 Review
by oilpsi2high - 01/27/20 02:51 PM
The "Penny Challenge"
by ZeeOSix - 01/27/20 02:32 PM
2008 Highlander Battery Post Bolt Snapped
by maverickfhs - 01/27/20 02:31 PM
conventional wisdom rebuild axle or replace?
by NissanMaxima - 01/27/20 01:22 PM
will a thermostat gasket leak coolant into the engine?
by motor_oil_madman - 01/27/20 12:55 PM
Swiss F/A-18C Demo
by Malo83 - 01/27/20 12:43 PM
Technical Service Bulletin Availability
by SubLGT - 01/27/20 12:40 PM
GM Goes All In on EVs: Pickups & SUVs
by SubLGT - 01/27/20 12:11 PM
2019 Jetta 1.4t Rental Review
by javacontour - 01/27/20 11:55 AM
JLR 0w-20w standard Huh????
by Local Color - 01/27/20 11:44 AM
Effects of increasing engine RPM?
by Avery4 - 01/27/20 11:09 AM
New C8-R Vettes at Rolex 24
by racin4ds - 01/27/20 10:39 AM
H20ham, Meletz, yagciogullari, roadrnnr, Burner718
70541 Registered Users
116 registered members (2010Civic, 2009Edge, 4WD, 53' Stude, 1978elcamino, 65convertible, 10 invisible), 2,675 guests, and 22 spiders.
Topics300,646
Posts5,180,121
Members70,541
Winterizing motorcycle #5281097 11/30/19 12:50 PM
N
Ndx Offline OP
N
Hi Guys,
The bike has only 600km on it... Should I change the oil before winter...
In spring it will go for the first maintenance
What fuel stabilizer should I use?
I can drain oil quickly and add new... But I don't have any filters in stock.
Thx
Re: Winterizing motorcycle [Re: Ndx] #5281124 11/30/19 01:14 PM
E
eljefino Offline
E
Since your current oil isn't "used up", it will protect fine.
Sta-bil green (for ethanol) is better than red is better than nothing.
If you have carbs, it's better to run them dry.
Cover your tail pipe and air intake to keep mice out.
Re: Winterizing motorcycle [Re: Ndx] #5281125 11/30/19 01:14 PM
02SE Offline
To get to nearly 373,000 miles, you must be doing something right. So I'd just continue with whatever you're doing.
Re: Winterizing motorcycle [Re: Ndx] #5281129 11/30/19 01:17 PM
N
Ndx Offline OP
N
Sorry 600km not K. kM
Thx guys
Re: Winterizing motorcycle [Re: Ndx] #5281164 11/30/19 01:51 PM
O
Oro_O Offline
O
Quote
+1. Or drain them.
Then in the spring, a little SeaFoam in the 1st tank will really clean things up on case jets and other orifices got a little varnish on them anyway.
Re: Winterizing motorcycle [Re: Ndx] #5281192 11/30/19 02:15 PM
N
Ndx Offline OP
N
Injected so no carbs smile
I just picked up red stabil... Last bottle others we're OOS
Re: Winterizing motorcycle [Re: Ndx] #5281230 11/30/19 02:49 PM
slacktide_bitog Online Content
Online Content
Do they make winter tires for motorcycles? ontome
Re: Winterizing motorcycle [Re: slacktide_bitog] #5281234 11/30/19 02:53 PM
N
Ndx Offline OP
N
They sure do... Including studded ones.
But I will pass haha
Re: Winterizing motorcycle [Re: Ndx] #5281319 11/30/19 04:45 PM
spk2000 Offline
Mine is dual carburetor and starts so much easier when I run it dry vs leaving fuel in it. If I run it dry it fires right up and runs great. If I leave fuel in it over winter it is so hard to start and idles / runs rough for a few hundred miles.
96 Grand Marquis 203,000 mi
01 Sable LS Wagon 163,000 mi
02 Montero 191,000 mi
03 Sable LS Sedan 73,000 mi
Re: Winterizing motorcycle [Re: Ndx] #5281348 11/30/19 05:32 PM
JohnnyJohnson Online Content
Online Content
Drain the gas tank and run it dry. Leave the oil in and change it before your first ride. If you plan on riding this winter make sure the heater is putting out.
2004 Corolla 138441
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Winterizing motorcycle [Re: Ndx] #5281355 11/30/19 05:46 PM
O
Oro_O Offline
O
Still run some SeaFoam or similar (techron, Gumout Regane - not the same cleaning mechanism but same idea) in the spring as you'll get some varnish in the system even with the stabilizer. Just unavoidable as some of the lighter hydrocarbons will still do it.
Battery on tender. If in an unheated garage, take the battery inside, stick it on a tender somewhere safe. I lived in Northern VT for several years and had an unheated garage - but never bought a new battery; most of my riding mates got one each season. wink
Re: Winterizing motorcycle [Re: Ndx] #5281362 11/30/19 05:57 PM
rsylvstr Offline
And use super unleaded if possible.
I read you can lose approx 1 octane point per month.
2013 F150 SCrew Lariat 4X4 5.0 3.55
2012 Altima SL that still vibrates.
2018 Polaris Sportsman 850 SP. Polaris fluids and filter.
Re: Winterizing motorcycle [Re: Ndx] #5281387 11/30/19 06:39 PM
T
totegoat Offline
T
I fill mine with Chevron 87 octane, plug in the battery tender and it always fires right up come spring. (fuel injected)
Re: Winterizing motorcycle [Re: Ndx] #5281489 11/30/19 08:56 PM
ccs368 Offline
I have had two incidences where running the engine dry caused me more issues in the spring and one incident where I drained the tank and also caused me problems.
Every year I would drain the four bowls on my 900RR prior to winter and start it back up 5 months later. In ~15 years of ownership, I never had this bike sitting for longer than 5 months. However, one year during the typical spring startup, fuel was spewing unstoppable from the carb overflow tube because one of the floats in the bowl was stuck down in the "empty" position as expected when you drain the bowl dry. Even after tapping with the head of the screwdriver repeatedly, I couldn't break the float free successfully so I had to spend the extra time pulling the bank out and opening all the bowls and flicking the float that was stuck before reassembling. So from my experience, I will not run or drain carb dry. I will use stabil if stored.
The second incident was from my lawn mower that was in storage for four years as I moved from the suburbs to the city and then back again. Fuel poured out from the single carb because of stuck bowl but kind of not unexpected from what I learned with my 900RR and certainly four years didn't help.
Lastly, even earlier was my FZR1000 where I use to drain the tank dry prior to winter. Not sure if the spotted rust buildup inside the tank was over several progressive yearly drains or just after one year. I purchased this motorcycle brand new so think the steel tank was not like this when new. I now fill the tank right to the neck with practically no air gaps. I think after 5 months, the gas is still fresh enough with stabil to fire right up but I personally siphon out this gas and dump it in my car and refill the bike with fresh gas just to be sure.
2015 Toyota Sienna LE FWD 0w20
2003 Toyota Corolla LE 5w30
2006 Suzuki Vinson LT-F500F 10w40
2004 Harley-Davidson Fatboy FLSTF 20w50
2001 Ducati 996S 20w50
Re: Winterizing motorcycle [Re: Ndx] #5281507 11/30/19 09:34 PM
Dyusik Offline
Hi Guys,
Thx
Battery on a tender (unless lithium)
Push the bike around the garage every so often (unless both off the ground)
E0 gas in.
That's all I've ever done.
95 Cherokee 190K DELO XLE 10W30, XG8
04 YZF-R1 20K Frankenbrew 20w50ish, XG7317
14 RX450h 50k M1 AFE 0w20, WIX 57047
18 RAM 3500 10k Delvac 15w40, DBL7349
96 Cherokee
