88 registered members (Aero540T, 69Torino, alchargo, 2004tdigls, 53' Stude, Audios, 7 invisible),
1,854
guests, and 17
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,825
Posts5,142,099
Members70,129
Most Online3,589 Nov 2nd, 2019
Winterizing motorcycle
#5281097
11/30/19 12:50 PM
Ndx
OP
OP
Posts: 1,863 |
Hi Guys,
The bike has only 600km on it... Should I change the oil before winter... In spring it will go for the first maintenance
What fuel stabilizer should I use?
I can drain oil quickly and add new... But I don't have any filters in stock.
Thx
Re: Winterizing motorcycle
[Re: Ndx]
#5281124
11/30/19 01:14 PM
eljefino
Posts: 34,995 |
Since your current oil isn't "used up", it will protect fine.
Sta-bil green (for ethanol) is better than red is better than nothing.
If you have carbs, it's better to run them dry.
Cover your tail pipe and air intake to keep mice out.
[Re: Ndx]
#5281125
11/30/19 01:14 PM
02SE
Posts: 4,300 |
To get to nearly 373,000 miles, you must be doing something right. So I'd just continue with whatever you're doing.
[Re: Ndx]
#5281129
11/30/19 01:17 PM
Ndx
OP
OP
Posts: 1,863 |
Sorry 600km not K. kM
Thx guys
[Re: Ndx]
#5281164
11/30/19 01:51 PM
Oro_O
Posts: 1,827 |
If you have carbs, it's better to run them dry. +1. Or drain them. Then in the spring, a little SeaFoam in the 1st tank will really clean things up on case jets and other orifices got a little varnish on them anyway.
[Re: Ndx]
#5281192
11/30/19 02:15 PM
Ndx
OP
OP
Posts: 1,863 |
Injected so no carbs  I just picked up red stabil... Last bottle others we're OOS
[Re: Ndx]
#5281230
11/30/19 02:49 PM
slacktide_bitog
Posts: 9,118 |
Do they make winter tires for motorcycles?
[Re: slacktide_bitog]
#5281234
11/30/19 02:53 PM
Ndx
OP
OP
Posts: 1,863 |
Do they make winter tires for motorcycles?  They sure do... Including studded ones. But I will pass haha
[Re: Ndx]
#5281319
11/30/19 04:45 PM
spk2000
Posts: 1,522 |
Mine is dual carburetor and starts so much easier when I run it dry vs leaving fuel in it. If I run it dry it fires right up and runs great. If I leave fuel in it over winter it is so hard to start and idles / runs rough for a few hundred miles.
96 Grand Marquis 203,000 mi 01 Sable LS Wagon 163,000 mi 02 Montero 191,000 mi 03 Sable LS Sedan 73,000 mi
[Re: Ndx]
#5281348
11/30/19 05:32 PM
JohnnyJohnson
Posts: 5,687 |
Drain the gas tank and run it dry. Leave the oil in and change it before your first ride. If you plan on riding this winter make sure the heater is putting out.
2004 Corolla 137480 Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457 In: Pennzoil Platinum HM 5W-20 ST 4386 2006 Duramax 76862 Out: T6 5W-40 XG9100 73909 In: Rotella Dino PH9100 11-3-19
[Re: Ndx]
#5281355
11/30/19 05:46 PM
Oro_O
Posts: 1,827 |
Injected so no carbs  I just picked up red stabil... Last bottle others we're OOS Still run some SeaFoam or similar (techron, Gumout Regane - not the same cleaning mechanism but same idea) in the spring as you'll get some varnish in the system even with the stabilizer. Just unavoidable as some of the lighter hydrocarbons will still do it. Battery on tender. If in an unheated garage, take the battery inside, stick it on a tender somewhere safe. I lived in Northern VT for several years and had an unheated garage - but never bought a new battery; most of my riding mates got one each season.
[Re: Ndx]
#5281362
11/30/19 05:57 PM
rsylvstr
Posts: 2,626 |
And use super unleaded if possible.
I read you can lose approx 1 octane point per month.
2013 F150 SCrew Lariat 4X4 5.0 3.55 2012 Altima SL that still vibrates. 2018 Polaris Sportsman 850 SP. Polaris fluids and filter.
[Re: Ndx]
#5281387
11/30/19 06:39 PM
totegoat
Posts: 1,383 |
I fill mine with Chevron 87 octane, plug in the battery tender and it always fires right up come spring. (fuel injected)
[Re: Ndx]
#5281489
11/30/19 08:56 PM
ccs368
Posts: 63 |
I have had two incidences where running the engine dry caused me more issues in the spring and one incident where I drained the tank and also caused me problems.
Every year I would drain the four bowls on my 900RR prior to winter and start it back up 5 months later. In ~15 years of ownership, I never had this bike sitting for longer than 5 months. However, one year during the typical spring startup, fuel was spewing unstoppable from the carb overflow tube because one of the floats in the bowl was stuck down in the "empty" position as expected when you drain the bowl dry. Even after tapping with the head of the screwdriver repeatedly, I couldn't break the float free successfully so I had to spend the extra time pulling the bank out and opening all the bowls and flicking the float that was stuck before reassembling. So from my experience, I will not run or drain carb dry. I will use stabil if stored.
The second incident was from my lawn mower that was in storage for four years as I moved from the suburbs to the city and then back again. Fuel poured out from the single carb because of stuck bowl but kind of not unexpected from what I learned with my 900RR and certainly four years didn't help.
Lastly, even earlier was my FZR1000 where I use to drain the tank dry prior to winter. Not sure if the spotted rust buildup inside the tank was over several progressive yearly drains or just after one year. I purchased this motorcycle brand new so think the steel tank was not like this when new. I now fill the tank right to the neck with practically no air gaps. I think after 5 months, the gas is still fresh enough with stabil to fire right up but I personally siphon out this gas and dump it in my car and refill the bike with fresh gas just to be sure.
2015 Toyota Sienna LE FWD 0w20 2003 Toyota Corolla LE 5w30
2006 Suzuki Vinson LT-F500F 10w40 2004 Harley-Davidson Fatboy FLSTF 20w50 2001 Ducati 996S 20w50
[Re: Ndx]
#5281507
11/30/19 09:34 PM
Dyusik
Posts: 2,292 |
Hi Guys,
Thx Battery on a tender (unless lithium) Push the bike around the garage every so often (unless both off the ground) E0 gas in. That's all I've ever done.
95 Cherokee 190K DELO XLE 10W30, XG8 04 YZF-R1 20K Frankenbrew 20w50ish, XG7317 14 RX450h 49k STP SYNHM 10w30, WIX 57047 18 RAM 3500 8k DELO SDE15w40, DBL7349 96 Cherokee
