Chasing down a brake issue
by HawkeyeScott - 12/11/19 07:14 PM
Total Quartz 9000 Energy 5w40
by BurntMusic - 12/11/19 06:53 PM
Mazda 3 i-ACTIV AWD diagonal test
by buster - 12/11/19 05:35 PM
Tires or Toyota ABS
by ford46guy - 12/11/19 05:33 PM
RV chase straight out of the Movies
by KeithS_NW_Ohio - 12/11/19 04:56 PM
Will the octane change?
by Mar57 - 12/11/19 04:45 PM
DIY brake lines help
by LeakySeals - 12/11/19 04:20 PM
random misfire code but not missing
by bowlofturtle - 12/11/19 03:31 PM
Pressure washing Santa Fe clay tile
by henni - 12/11/19 02:55 PM
Confused. Mercon V or Dexron VI?
by AcadiaDave - 12/11/19 02:33 PM
Sooty Oil in Ford Focus
by RW1 - 12/11/19 02:27 PM
oil sample shelf life?
by novadude - 12/11/19 12:51 PM
whoa!!walmart ammo clearance
by joel95ex - 12/11/19 11:56 AM
Carpro Reset
by BeerCan - 12/11/19 10:46 AM
Come on China. Let's get it right.
by Chris142 - 12/11/19 10:34 AM
'best' conventional 10w-40 pcmo for wet clutch bike
by kmrcstintn - 12/11/19 10:32 AM
Any reason not to use Carquest full synthetic?
by wbwanzer - 12/11/19 10:18 AM
TyMillerfc, AcadiaDave, lmt1911, m14308, MyFirstNamePaul
70104 Registered Users
116 registered members (AcadiaDave, Aero540T, 14Accent, alarmguy, 69Torino, 40Deluxe, 11 invisible), 1,840 guests, and 30 spiders.
Topics298,595
Posts5,138,827
Members70,104
Most Online3,589
Nov 2nd, 2019
Storing summer tires in crawl space, clear bags ok? #5281091 11/30/19 12:38 PM
O
OCDriver Offline OP
O
I have some summer tires that I want to store in a crawl space. I've cleaned and prepped the area with a shop vac and I'll lay down some cardboard.
Is it okay to use clear construction bags to store them? It's just what I have.
As far as I know, the purpose of using black or opaque bags is to keep out sunlight and UV, but this space basically doesn't get exposed to light at all, other than a tiny bit of LED light through the gap in the wall for the furnace ducts and plumbing.
Re: Storing summer tires in crawl space, clear bags ok? [Re: OCDriver] #5281094 11/30/19 12:41 PM
skyactiv Online Content
Online Content
Sounds like you have nothing to worry about.
Sold: 13' VW GTI 3 door 6 speed manual
Me: 18' Elantra Sport 6 speed manual
Re: Storing summer tires in crawl space, clear bags ok? [Re: OCDriver] #5281098 11/30/19 12:50 PM
T
ted s Offline
T
i just put them in corner of the unheated barrn
Re: Storing summer tires in crawl space, clear bags ok? [Re: OCDriver] #5281156 11/30/19 01:42 PM
M
Mainia Offline
M
Uninflate to 15psi
Re: Storing summer tires in crawl space, clear bags ok? [Re: OCDriver] #5281159 11/30/19 01:45 PM
FA_WRX Offline
I store mine either in the basement or garage. I would consider baging them optional in your situation. I don't store mine in bags and never had a problem.
2015 WRX FA20F
PP 5W30
Napa Gold 100078
Re: Storing summer tires in crawl space, clear bags ok? [Re: OCDriver] #5281243 11/30/19 02:58 PM
E
eljefino Offline
E
The bags are mostly so you don't smear carbon black on the upholstery of your car when you drive home from the tire shop.
Biggest thing in basements that's bad for tires is ozone-- given off by furnaces.
Re: Storing summer tires in crawl space, clear bags ok? [Re: OCDriver] #5281245 11/30/19 02:59 PM
T
tcp71 Offline
T
Store them stacked in the corner of the shed. Oldest ones are summers now at 10years old. They look brand new (senior driven tribeca that has less than 12k miles on it in 10 years).
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: NAPA 5w30 syn. (varies)
Re: Storing summer tires in crawl space, clear bags ok? [Re: Mainia] #5281269 11/30/19 03:36 PM
R
Rand Offline
R
Originally Posted by Mainia
Uninflate to 15psi
better off overinflating than that.
Re: Storing summer tires in crawl space, clear bags ok? [Re: Mainia] #5281272 11/30/19 03:44 PM
K
krzyss Offline
K
Uninflate to 15psi
What is your logic behind it?
Leave it alone or pump them up a little imho.
If electric motors, heat sources and light are away even clear bags are overkill, just for neatness.
Krzyƛ
Re: Storing summer tires in crawl space, clear bags ok? [Re: OCDriver] #5281289 11/30/19 03:59 PM
W
wag123 Offline
W
Spray them down thoroughly with 303 (don't wipe them off), air them up to 44 psi, and don't lay them down. No need to bag them. There isn't enough ozone in the crawl space to worry about.
Re: Storing summer tires in crawl space, clear bags ok? [Re: OCDriver] #5281314 11/30/19 04:38 PM
J
Jethro_Bob Offline
J
No need to worry about air pressure without the weight of the car on them, unless you park near enough the car can read the tpms on startup. There's a few threads on here about that happening.
Re: Storing summer tires in crawl space, clear bags ok? [Re: Rand] #5281518 11/30/19 10:00 PM
2
2010Civic Offline
2
Uninflate to 15psi
Why? I would think lowering the pressure would put less stress on the tire. They won't have any weight on them.
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: Storing summer tires in crawl space, clear bags ok? [Re: OCDriver] #5281613 12/01/19 03:39 AM
F
FT92 Offline
F
I've stored tires over winter in my garage, some sun hits them in the morning thru a window other than that basically dark....never had a problem...a few months or so of storage shouldn't hurt a thing
Re: Storing summer tires in crawl space, clear bags ok? [Re: 2010Civic] #5281706 12/01/19 07:53 AM
CapriRacer Offline
Uninflate to 15psi
No, don't change the pressure. Just top it up when you put the tires back on.
Why?
Because overinflating them adds fresh oxygen - and unless you are putting weight on them, they won't flatspot. (and stacking them 4 high isn't enough weight to worry about.)
And because while reducing the pressure will reduce the amount of oxygen while in storage, you have to add fresh oxygen when you put them back on. That's worse.
CapriRacer
Visit my web site: www.BarrysTireTech.com
