119 registered members (Al, 2015_PSD, 53' Stude, Astro14, 18 invisible),
2,661
guests, and 56
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,408
Posts5,134,894
Members70,059
Most Online3,589 Nov 2nd, 2019
PU 0w20 vs PUP 5w20
#5281090
11/30/19 12:38 PM
dgsbikes
OP
OP
Posts: 179 |
Speaking about the current 2019 versions of these two oils only - Pennzoil Platinum 0w20 Pennzoil Ultra Platinum 5w20
Excluding the following variables from any consideration whatsoever: 1. 0w vs 5w doesn't matter as the temps never drop below 25 degrees farenheit 2. Price is exactly the same between the two 3. Availability of both oils is equal
Including the following factors: 1. The two subject oils only (the Pennzoil Ultra 0w20 is not in consideration here) 2. Start stop traffic, with about 4 runs each day for 15 minutes each run in 30F to 45F temperatures in winter and 80F avg in summer). Basically oil never reaches and sustains optimal operating temps 3. Honda VCM, OR Hybrid Atkinson Cyle engines 4. Long OCIs (~5-7K on Honda VCM to 10K on hybrids)
Which will perform better and why? (subject to the exclusions above)
Thanks Desh
Re: PU 0w20 vs PUP 5w20
[Re: dgsbikes]
#5281103
11/30/19 12:56 PM
demarpaint
Posts: 33,545 |
PUP is their premium product, so "in theory" PUP 5W20 should perform better. I'd call Pennzoil and ask them.
God Bless Our Troops
[Re: dgsbikes]
#5281109
11/30/19 01:04 PM
buster
Posts: 32,567 |
It "depends".....if the 0w20 has more VII's, but the same base oil blend, I'd lean towards the 5w20. I believe within the Pennzoil line the base oil blend is probably the same % of GTL, however that can't be confirmed. Within the Mobil 1 line, the 0w20's are PAO based with the 5w20 contain significant III/GTL. In that case, the 0w20 is likely the better of the two.
2019 Frontier Pro 4X - RGT 5w30 2019 Impreza Sport - OE fill
[Re: dgsbikes]
#5281174
11/30/19 01:56 PM
SubieRubyRoo
Posts: 3,420 |
If you're focusing on the most problematic part of your qualifiers, the Honda VCM... go with PUP 5W20. Less VII, less NOACK, "likely" more stay-clean power. I ran the PUP 5W20 much longer than 10K in my 2011 Fusion, and also ran it in my 2006 Odyssey with VCM out to 7,500 miles. Both UOAs showed no issues, and I gave the Odyssey to my stepson at 190k without ever having had any VCM problems or failures.
[Re: dgsbikes]
#5281257
11/30/19 03:18 PM
WhyMe
Posts: 1,018 |
i always thought pup was the long drain version of the platinum line
