94 registered members (2004tdigls, 53' Stude, 69Torino, 77GrandPrix, 14Accent, 40Deluxe, 9 invisible),
1,818
guests, and 17
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,825
Posts5,142,091
Members70,129
Most Online3,589 Nov 2nd, 2019
FRAM XG11665 [4,200 Miles]
#5281079
11/30/19 12:13 PM
2015_PSD
OP
OP
Posts: 8,184 |
I have performed 3 OCs on my Rublcon thus far: 800 miles changed OEM filter with XG11665 (this one) 2000 miles (did not change filter) (1,200 Miles on oil) 5000 miles (changed filter) (3,000 miles on oil and 4,200 miles on filter) At the initial OC (800 miles), I also installed a Gold Plug magnetic drain plug. At the 2,000 mile OC, it was clean, but on this latest OC, it had quite a bit of metal on it (and I probably lost a little because the plug clung to the pan when I removed it). The XG was twisted slightly and I have seen this on most filters for the 3.6L Pentastar, otherwise it was in good shape. I do wonder if the filters are a little too long OR if the oil filter cap is tightened a bit too much. I torqued mine to exactly 25nm this time (I did not torque the cap for the XG--but I did not "he-man" it tight either). A Mahle filter and Castrol Edge replaced this filter and oil and I will be moving to a 5K OCI from this point forward. Enjoy! ![[Linked Image from iili.io]](https://iili.io/Hxrp7S.jpg) ![[Linked Image from iili.io]](https://iili.io/Hx49p9.jpg) ![[Linked Image from iili.io]](https://iili.io/Hxrm22.jpg) ![[Linked Image from iili.io]](https://iili.io/HxrDrl.jpg) ![[Linked Image from iili.io]](https://iili.io/Hxryk7.jpg)
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Mahle] 2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: FRAM XG11665 [4,200 Miles]
[Re: 2015_PSD]
#5281081
11/30/19 12:20 PM
demarpaint
Posts: 33,617 |
The filter looks fine. My bet is the small O-ring bound slightly and the filter twisted a bit when you screwed the cap down. I torque mine to about 10' pounds, I think the manual says 18. I figured with oil on the cap threads and the two O-rings less is better. No leaks so far, and my filters come out with little to no twist.
God Bless Our Troops
[Re: 2015_PSD]
#5281086
11/30/19 12:26 PM
wwillson
Administrator
Administrator
Posts: 2,586 |
2015_PSD,
Could you cut the media from the body and look for metal flakes?
[Re: 2015_PSD]
#5281087
11/30/19 12:27 PM
BlueOvalFitter
Posts: 6,600 |
That sure is a long filter.
"One Filter, One OCI!" 2007 F150, 4.2 V6 Havoline HM 5W20, MC FL-400S "One Box, One OCI!"
[Re: 2015_PSD]
#5281100
11/30/19 12:52 PM
Farnsworth
Posts: 498 |
I don't know if this is right, but I think so. The pleats are no longer in line from top to bottom, they are displaced from one another, which means one cap moved while the other was fixed. Don't know if this is an insert cartridge into the cap type, but if it is and isn't inserted all the way, twisting can occur. Or like has been said the oring is too tight. Don't know if too long would do this, maybe.
[Re: 2015_PSD]
#5281149
11/30/19 01:34 PM
slacktide_bitog
Posts: 9,118 |
Thank you for posting  That is terrible for such a short OCI on a mesh-backed filter  Use the Wix XP/Napa Platinum. It uses wire-backed synthetic media, not plastic mesh like the Ultra
[Re: slacktide_bitog]
#5281168
11/30/19 01:53 PM
JGmazda
Posts: 620 |
Thank you for posting  That is terrible for such a short OCI on a mesh-backed filter  Use the Wix XP/Napa Platinum. It uses wire-backed synthetic media, not plastic mesh like the Ultra  Do they make a WIX XP for a canister filter enclosure?
2008 KIA Sportage
[Re: wwillson]
#5281242
11/30/19 02:57 PM
2015_PSD
OP
OP
Posts: 8,184 |
2015_PSD,
I opened nearly every pleat and did not see any metal flakes within.
[Re: Farnsworth]
#5281246
11/30/19 02:59 PM
2015_PSD
OP
OP
Posts: 8,184 |
I don't know if this is right, but I think so. The pleats are no longer in line from top to bottom, they are displaced from one another, which means one cap moved while the other was fixed. Don't know if this is an insert cartridge into the cap type, but if it is and isn't inserted all the way, twisting can occur. Or like has been said the oring is too tight. Don't know if too long would do this, maybe. It is an insert the filter into the cap style, but it was fully inserted and the bottom o-ring "support" spins freely inside the filter (by design). I am at a loss why the twisting occurs, but it is even worse on a non-backed filter--as I am sure that I will see with the Mahle that I installed today.
#5281247
11/30/19 03:00 PM
2015_PSD
OP
OP
Posts: 8,184 |
Thank you for posting  That is terrible for such a short OCI on a mesh-backed filter  Use the Wix XP/Napa Platinum. It uses wire-backed synthetic media, not plastic mesh like the Ultra  The efficiency of the WIX XP tends to steer me away from it. The good news is that I am settling on a 5K OCI, so hopefully, it will survive that.
[Re: 2015_PSD]
#5281300
11/30/19 04:14 PM
ZeeOSix
Posts: 22,167 |
The twist acts like the "tornado" air intake gizmo ... helps increase the efficiency on an oil filter.  Thanks for the C&P.
[Re: 2015_PSD]
#5281370
11/30/19 06:13 PM
oldhp
Posts: 2,307 |
I think there is a little length difference in filters. I've had a 2017 Jeep Wrangler, my current 2018 RAM 1500 and current wife's 2019 Charger. All with 3.6's. I've used FRAM XG, Mobil1 and the Mopar ones. The FRAM XG is the only one that has never twisted. Both the Mobil1 & Mopar did, but not every time. ?????? I never counted the pleats on FRAM XG's, but the Mobil1's had 47-48 pleats and the Mopar's 57-59 pleats. I mark the cap with some paint "before" I take it off. When re-installing I put the marks back like they were. I never torque the cap. I have "never" changed the O-ring on any of these. I have put some of these filters with the flat part down little tip with O-ring up. Some are a little longer, about 1/16th of an inch. The part that is longer is the base top & bottom of the filter, not the tip of it. I should've marked the longer ones to see if they are the ones that twisted. Maybe next time if I think about it.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod" "When others cut you down, remember where they came from." "I don't run...........I just wait"
[Re: 2015_PSD]
#5281485
11/30/19 08:54 PM
wwillson
Administrator
Administrator
Posts: 2,586 |
2015_PSD,
I opened nearly every pleat and did not see any metal flakes within. What I've found is you can't see the metal flakes until you pull the media tight in bright sunlight, then you can't believe how much metal you see. There are flakes on every media I cut and hold up in bright sunlight.
[Re: wwillson]
#5281509
11/30/19 09:42 PM
CR94
Posts: 2,490 |
... What I've found is you can't see the metal flakes until you pull the media tight in bright sunlight, then you can't believe how much metal you see. There are flakes on every media I cut and hold up in bright sunlight. What sort of engine are your flakes coming from? Are they attracted to a magnet? I rarely see any metal when I look that way.
2011 Toyota Prius now at 107K 1981 Mazda GLC (323) retired at 606K 1972 Subaru DL retired at 190K 1954 Chevrolet retired at 121K
[Re: 2015_PSD]
#5281546
11/30/19 10:50 PM
geeman789
Posts: 1,261 |
That filter is VERY long ... does that make it more likely to twist in the housing ? The filter looks good, aside from the slight twist .
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
