Current Honda Factory Fill
by asiancivicmaniac - 12/09/19 04:16 AM
Gulf Western - Premium Gold 15W40
by SR5 - 12/09/19 03:43 AM
how can one tell 100% that the oil was changed
by WhyMe - 12/09/19 03:22 AM
Scraped the side of my truck...
by GumbyJarvis - 12/09/19 12:44 AM
Outlasted 3 Marriages
by Y_K - 12/08/19 10:10 PM
High miles on 0W20 oils?
by EyesofThunder - 12/08/19 10:02 PM
90 350 intake gaskets and sealant
by P10crew - 12/08/19 10:01 PM
Glock Polymer80
by pkunk - 12/08/19 09:59 PM
Reman steering rack 09 CRV
by Chester11 - 12/08/19 09:24 PM
Edge 5W-30 10k miles '13 F150 5.0
by dustyroads - 12/08/19 09:18 PM
Hyundai engine failures getting news again
by OVERKILL - 12/08/19 09:04 PM
2015 Ford Fiesta ST
by daemontrym - 12/08/19 07:39 PM
NVX NSP65 Speaker review: Good deal!
by 14Accent - 12/08/19 07:26 PM
Thanks to Quattro Pete for making the 2020 avatars!
by wwillson - 12/08/19 07:17 PM
Klotz 2 Stroke Smelling Candle
by FA_WRX - 12/08/19 06:31 PM
Non scientific oil test.
by tblt44 - 12/08/19 05:33 PM
Nitromethane prices
by 53' Stude - 12/08/19 05:31 PM
Question about JASO specs?
by frascati - 12/08/19 04:15 PM
Anyone knows outdoorsy magazine that are US only?
by MoneyJohn - 12/08/19 03:54 PM
redradar, Jonas_K, slxgold, Dennisfly, AutopartsTester8
70070 Registered Users
35 registered members (adams355, Brian553, Bailes1992, AurionX2, 2015_PSD, Bookmaker, 4 invisible), 770 guests, and 45 spiders.
Topics298,473
Posts5,136,113
Members70,070
Most Online3,589
Nov 2nd, 2019
Blowby #5280991 11/30/19 10:03 AM
L
Lubener Offline OP
L
My old 87 f150 w/4.9L is starting to exhibit some blowby. The breather gets blown out of the valve cover (it fits in tightly) and I get a small amount of oil in the breather filter. The engine consumes very little oil, about a half quart every 2500 miles. PCV system is working but I would like to try a "high flow" PCV valve. Does anyone have a OEM or Fram number I can go from that might work?
The "thinking" man's friend.
Re: Blowby [Re: Lubener] #5281028 11/30/19 10:54 AM
spasm3 Offline
You could use a fixed orifice pcv valve with no check valve. You can drill it in increments till you got what you want. Would have some pcv flow all the time.
You will need to check the fit. Fram FV410
https://www.amazon.com/FV410-Positive-Crankcase-Ventilation-Valve/dp/B0010DW658
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Blowby [Re: Lubener] #5281056 11/30/19 11:40 AM
M
mattd Offline
M
Is it causing seals to leak as well?
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1
Re: Blowby [Re: Lubener] #5281111 11/30/19 01:07 PM
T
Talent_Keyhole Offline
T
Try a dual stage, adjustable PCV valve made by ME Wagner http://mewagner.com/
The last PCV valve you will need to buy.
A fixed orifice PCV valve will not work well at higher speeds and loads due to low intake vacuum. That is when you need crankcase ventilation the most when blow-by is greatest.
Re: Blowby [Re: Lubener] #5281172 11/30/19 01:55 PM
Chris142 Offline
If it's that bad run a road draft tube.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
