Mazda 3 i-ACTIV AWD diagonal test
by buster - 12/11/19 05:35 PM
Tires or Toyota ABS
by ford46guy - 12/11/19 05:33 PM
RV chase straight out of the Movies
by KeithS_NW_Ohio - 12/11/19 04:56 PM
Will the octane change?
by Mar57 - 12/11/19 04:45 PM
DIY brake lines help
by LeakySeals - 12/11/19 04:20 PM
random misfire code but not missing
by bowlofturtle - 12/11/19 03:31 PM
Pressure washing Santa Fe clay tile
by henni - 12/11/19 02:55 PM
Confused. Mercon V or Dexron VI?
by AcadiaDave - 12/11/19 02:33 PM
Sooty Oil in Ford Focus
by RW1 - 12/11/19 02:27 PM
oil sample shelf life?
by novadude - 12/11/19 12:51 PM
whoa!!walmart ammo clearance
by joel95ex - 12/11/19 11:56 AM
Carpro Reset
by BeerCan - 12/11/19 10:46 AM
Come on China. Let's get it right.
by Chris142 - 12/11/19 10:34 AM
'best' conventional 10w-40 pcmo for wet clutch bike
by kmrcstintn - 12/11/19 10:32 AM
Any reason not to use Carquest full synthetic?
by wbwanzer - 12/11/19 10:18 AM
53k miles on a Ford FA-1927
by BeerCan - 12/11/19 09:53 AM
Penzoil Platinum 100% Synthetic ????
by Talent_Keyhole - 12/11/19 09:50 AM
TyMillerfc, AcadiaDave, lmt1911, m14308, MyFirstNamePaul
70104 Registered Users
103 registered members (53' Stude, 40Deluxe, 2015_PSD, 97K15004WD, Aero540T, 01rangerxl, 10 invisible), 1,846 guests, and 26 spiders.
Topics298,592
Posts5,138,777
Members70,104
Most Online3,589
Nov 2nd, 2019
Turbo Boost Hose Intercooler Connection, Ford vs. GM #5280928 11/30/19 08:06 AM
L
LoneRanger Offline OP
L
Anecdotally, Ford's is better. Random observation after examination of both our vehicles.
My F-150 they secured the boost hose to the intercooler inlet by a stout worm screw clamp. Her GMC Terrain they use a hard fitting on end of boost hose that is secured with a spring steel clamp and [feels like it] contains an o-ring gasket to seal the connection, but it moves and jiggles around easily. There is a slight film of oil, around where this hard plastic fitting is connected to the intercooler inlet, indicating some leakage of the high pressure boost air. All in all it's a sloppy fit, but by design. The fitting on the intercooler outlet however, is a different design and is firm and very secure. Seems like if they used the inlet fitting style (flex/slop designed in) to allow for movement of the assembly due to engine torque, they'd have used similar design on the outlet end, which is a hard/firm connection not apparently intended to flex much.
'19 Ford F150 2.7 twin turbo GDI V6 .....(Motorcraft 5W30 SN+)
'19 GMC Terrain 1.5 turbo GDI I4...........(GM 0W20 dexos)
'16 Moto Guzzi 1151cc air cooled v-twin (Eni 10W60)
Re: Turbo Boost Hose Intercooler Connection, Ford vs. GM [Re: LoneRanger] #5281114 11/30/19 01:08 PM
bdcardinal Online Content
Online Content
Ford uses the goofy spring clip on the older 6.7 diesels between the air/water intercooler and intake and we replace a ton of them from blowing apart. Mishimoto makes an updated/upgraded version that does not let go.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Turbo Boost Hose Intercooler Connection, Ford vs. GM [Re: LoneRanger] #5281197 11/30/19 02:19 PM
J
JohnG Offline
J
If this loose connection is at a low point in the system, it is indeed by design.
I have heard stories of the Ford system accumulating water condensation in the bottom of the intercooler which can be ingested into the engine with serious results. I think some have actually drilled a pinhole in the bottom of the cooler to prevent this.
Re: Turbo Boost Hose Intercooler Connection, Ford vs. GM [Re: JohnG] #5281462 11/30/19 08:22 PM
L
L
That problem did exist in the Ford setup, but I believe it was corrected for 2017 model year forward.
As far as the GMC is concerned, yes it is at a low point in the turbo high pressure intake air system. My former wife's 2005 volkswagen tdi diesel (pump duese unit injector type known as a PD) had a similar o-ring sealed boost hose feeding into the intake manifold with similar slop in the fit and those were known to eventually wear down the two nubs the clamp secured onto and leak air. If not replaced they'd eventually blow clean off of the manifold.
