My sister is remodeling her kitchen. She moved the kitchen sink to a different location. The old location will house the dishwasher. The water feed and existing 1.5inch waste line are present at the wall. Without a sink next to that location, I'm not sure how to connect the dishwasher to the existing waste line located at the wall. It's wrong to feed it directly into the waste line and I have not seen fitting that would allow that. In the basement directly below that location, if you were to follow the waste line down into the basement, you'll find the utility sink with a drain trap that we could tie into. We could also run a line under the bases of the cabinets and tie into the new sink trap location however it's not very close and level. If it were my house, I think I'd run the dishwasher drain line directly down into the basement and tie into the existing trap at the utility sink, and cap the existing drain behind the dishwasher.
Please take a look at the pictures and let me know what you think!
