What's going on?
by clinebarger - 12/13/19 12:28 AM
Price jacked up on Chevron Supreme at WM?
by Whammo - 12/12/19 11:23 PM
valvoline durablend 5w-30 in yaris, ok?
by jstert - 12/12/19 11:02 PM
Outsmarting RAโ€™s Shipping Lunacy
by The_Nuke - 12/12/19 11:00 PM
Odd Ball!??
by miden851 - 12/12/19 09:40 PM
fedex lost package . how does it work?
by WhyMe - 12/12/19 09:39 PM
RTG 5W-20
by kstanf150 - 12/12/19 09:12 PM
First time running synthetic in my truck
by leeaspell - 12/12/19 09:05 PM
2007 Honda Accord Transmission
by maverickfhs - 12/12/19 07:59 PM
Detriot Axle brake kit review
by 14Accent - 12/12/19 07:51 PM
PQIA Issues An Alert!
by Jackson_Slugger - 12/12/19 06:36 PM
Late night commotion outside.
by LeakySeals - 12/12/19 06:27 PM
Help with Dewalt tools
by henni - 12/12/19 06:19 PM
Educate me on USB drives, devices
by 53' Stude - 12/12/19 05:55 PM
9012 bulb lasted 2 yrs... good?
by mclasser - 12/12/19 05:43 PM
2020 YUGO
by Malo83 - 12/12/19 04:53 PM
Ice on inside of windshield
by JLawrence08648 - 12/12/19 04:41 PM
AC DELCO PF 63E CUT OPEN
by 53' Stude - 12/12/19 04:10 PM
mb20music, Jaglenn, kalima, Powertool1994, lutvi20
70115 Registered Users
25 registered members (AndyB, adams355, clinebarger, carlprop, alcyon, c502cid, 3 invisible), 778 guests, and 27 spiders.
Topics298,666
Posts5,140,069
Members70,115
Most Online3,589
Nov 2nd, 2019
Old school door lock issue #5280548 11/29/19 03:57 PM
007 Offline OP
I am unable to open the drivers door of my 70 Chevelle from the outside or inside. Button pulls up and goes down and the inside handle is not stuck but the door does not open. Using a slim jim it appears that the rod going from the lever to the lock is still in place but outside button and inside lever are dead. Crank window, any ideas?
Re: Old school door lock issue [Re: 007] #5280579 11/29/19 05:02 PM
JohnnyJohnson Offline
Taking off the interior door panel will likely tell you. Good luck.
2004 Corolla 137480
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 76862
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Old school door lock issue [Re: JohnnyJohnson] #5280582 11/29/19 05:12 PM
PimTac Offline
I agree. You will have to take off the panel anyways just to see whatโ€™s wrong.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Old school door lock issue [Re: 007] #5280598 11/29/19 05:39 PM
E
edwardh1 Offline
E
probably a pull wire or rod has bent or fallen off
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Old school door lock issue [Re: 007] #5280610 11/29/19 06:01 PM
J
JLTD Offline
J
Some of those designs had a plastic retainer, if that fails and falls off the rod is disconnected.
I use the overseas manual to choose my viscosity.
Hers: 2008 Jeep Liberty 154k, SS 5w30/Amsoil
Looking at options.
His: 2015 4Runner 60k, SS 5w20/Amsoil
Re: Old school door lock issue [Re: 007] #5280628 11/29/19 06:20 PM
G
GoldDot40 Offline
G
Yep, the latch rod is likely disconnected right at the latch. You might be able to shine a light down from the outside and use the slim jim to pull the latch mechanism up to get the door opened at least.
Equal Opportunity Offender
Re: Old school door lock issue [Re: 007] #5280629 11/29/19 06:21 PM
marine65 Offline
A 70 Chevelle is worth fixing.
Several months ago my 2006 Sentra did the same thing.
It also needed front rotors and pads and new struts.
It had 206 K miles on it.
I sent it to the junkyard for $220.
I got another new Hyundai Elantra G.T.
Great little somewhat unknown car.
2018 Hyundai Elantra GT black
2018 Hyundai Elantra GT silver
yup got two of them.
Re: Old school door lock issue [Re: 007] #5280651 11/29/19 06:53 PM
007 Offline OP
As stated the latch rod appears to be in place. I also do know know hot to remove the door panel without the door open as the outside rim of the interior panel is behind the door frame when the door is closed.
Re: Old school door lock issue [Re: 007] #5280660 11/29/19 07:16 PM
P
P10crew Offline
P
Double awt sebin
Here is your latch [Linked Image]
As you can see the plunger from the outer door handle and the lever that connects to the inside lever are somewhat separate. My guess is that something fell apart deeper into the latch. You are going to need get a rod inside the door to lift the claw. Are you sure that the lock rod is up?
Re: Old school door lock issue [Re: 007] #5280665 11/29/19 07:19 PM
M
maxdustington Offline
M
You need to go in from the top via an open window and try to manipulate the latch directly.. Coat hanger I guess? IDK, I have the same issue but I would rather trash the door panel of my car than a 1970 Chevelle!
You can also try whacking where the latch is with your hand while operating the door handle. If it is just a stuck latch, that might work. If you get it open, clean the latch before you put it back together again.
99 Toyota Tercel CE 5EFE/C151
Re: Old school door lock issue [Re: 007] #5280755 11/29/19 09:33 PM
E
eljefino Offline
E
Get us a picture of what you have to work with. Is there a "pocket" where the inside door handle is, that can be removed with accessible hardware? Then you could stick a mirror or endoscope in. I got an endoscope for $15 on amazon!
Re: Old school door lock issue [Re: 007] #5281492 11/30/19 09:03 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
Pretty hard to remove the door panel if you can't open the door. Keep at it with a slim jim.
Re: Old school door lock issue [Re: Kestas] #5281862 12/01/19 10:44 AM
M
Mad_Hatter Offline
M
Yepper..hard as in not gonna happen without hacking into the panel itself.๐Ÿ˜‚
This actually happened on an old beater i had when I was a teen, albeit it was the rear passenger. Friend of mine got out, heard something pop and drop - it was a clip or something like that... never could get it open there after. From then on anyone getting into the back either had to climb through the window (๐Ÿ˜‚we were teenagers) or use the door on the opposite side and slide over.
Re: Old school door lock issue [Re: 007] #5281977 12/01/19 12:34 PM
007 Offline OP
Lots of tweaking with various old school slim jim tools and some WD40 has seemed to solved the issue! Just glad something was not broke or at least it seems that way for now! Thanks for all the ideas.
Re: Old school door lock issue [Re: 007] #5282335 12/01/19 07:40 PM
M
Mad_Hatter Offline
M
๐Ÿ‘
