Mazda 3 i-ACTIV AWD diagonal test
by buster - 12/11/19 05:35 PM
Tires or Toyota ABS
by ford46guy - 12/11/19 05:33 PM
RV chase straight out of the Movies
by KeithS_NW_Ohio - 12/11/19 04:56 PM
Will the octane change?
by Mar57 - 12/11/19 04:45 PM
DIY brake lines help
by LeakySeals - 12/11/19 04:20 PM
random misfire code but not missing
by bowlofturtle - 12/11/19 03:31 PM
Pressure washing Santa Fe clay tile
by henni - 12/11/19 02:55 PM
Confused. Mercon V or Dexron VI?
by AcadiaDave - 12/11/19 02:33 PM
Sooty Oil in Ford Focus
by RW1 - 12/11/19 02:27 PM
oil sample shelf life?
by novadude - 12/11/19 12:51 PM
whoa!!walmart ammo clearance
by joel95ex - 12/11/19 11:56 AM
Carpro Reset
by BeerCan - 12/11/19 10:46 AM
Come on China. Let's get it right.
by Chris142 - 12/11/19 10:34 AM
'best' conventional 10w-40 pcmo for wet clutch bike
by kmrcstintn - 12/11/19 10:32 AM
Any reason not to use Carquest full synthetic?
by wbwanzer - 12/11/19 10:18 AM
53k miles on a Ford FA-1927
by BeerCan - 12/11/19 09:53 AM
Penzoil Platinum 100% Synthetic ????
by Talent_Keyhole - 12/11/19 09:50 AM
TyMillerfc, AcadiaDave, lmt1911, m14308, MyFirstNamePaul
70104 Registered Users
110 registered members (40Deluxe, 53' Stude, 379KITTY, aquariuscsm, Aichiguy, Astro_Guy, 9 invisible), 1,814 guests, and 32 spiders.
Topics298,592
Posts5,138,790
Members70,104
Most Online3,589
Nov 2nd, 2019
Rate of oil burn, not bad? #5280506 11/29/19 02:42 PM
M
MichaelRS Offline OP
M
Just going for some opinions here:
I have a 2002 Toyota Sienna with just over 201,700k on it. I use Castrol 10-30 High Mileage oil. Which is what I started using when I got it in 2012 with 136k on it.
I burn just under 12.5 oz of oil every 1,000 miles. That doesn't seem too bad to me. What do you think?
(Also, had an oil analysis done by Blackstone two oil changes ago. While some values could be better they did not denote anything particularly remarkable or worrisome at that point).
2002 Toyota Sienna
178k As of May 2017
Re: Rate of oil burn, not bad? [Re: MichaelRS] #5280510 11/29/19 02:45 PM
K
ka9mnx Offline
K
1qt per 1k miles is considered the beginning of high oil consumption. Any leaks? PCV valve working as per specs?
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Rate of oil burn, not bad? [Re: MichaelRS] #5280511 11/29/19 02:46 PM
Charlie2015 Offline
Keep doing what you are doing. Also, keep it topped off (aka never more than 1 quart low). My preference is for Valvoline Maxlife, but you cannot go wrong with any name brand high mileage oil.
1998 Honda Accord EX 2.3L Auto (Sold) 214k mi
2009 Scion tC Manual (Daily Driver) 170k mi - Valvoline Maxlife 0w20
Re: Rate of oil burn, not bad? [Re: MichaelRS] #5280516 11/29/19 02:50 PM
Supersonic Online Content
Online Content
Try to replace the valve covers if not done lately.
Re: Rate of oil burn, not bad? [Re: MichaelRS] #5280558 11/29/19 04:12 PM
M
Mad_Hatter Offline
M
Since you've owned it has it always burned that much more or less?..or has it been gradually increasing? Is this normal for this engine? If it is, there's not a whole lot you can do about it besides run a thick HiMi and drive that bad boy into the ground however long that will take... otherwise, unless you're willing to crack it open and look at/replace the stem seals and rings. Even then that may not solve things if this engines got a known drinking problem.
Check/clean/replace your pcv valve if you haven't done so already.
Re: Rate of oil burn, not bad? [Re: MichaelRS] #5280577 11/29/19 05:01 PM
V
vw7674 Offline
V
probably hardened up valve seals.
seeing as you're at 200k+, it would be a viable repair if you wanted 400k miles out of it.
Which you probably don't.
Re: Rate of oil burn, not bad? [Re: MichaelRS] #5280609 11/29/19 06:00 PM
J
JLTD Offline
J
1 quart every 2560 miles? If it's not leaking -- Drive on.
I use the overseas manual to choose my viscosity.
Hers: 2008 Jeep Liberty 154k, SS 5w30/Amsoil
Looking at options.
His: 2015 4Runner 60k, SS 5w20/Amsoil
Re: Rate of oil burn, not bad? [Re: MichaelRS] #5280707 11/29/19 08:07 PM
G
geeman789 Offline
G
18 year old car with 200 000 miles ... worth virtually nothing to sell it.
You can try and fix whatever is causing the oil consumption issue. For possibly $ 100's or $ 1000's of dollars.
OR ...
You can put a $ 3.00 quart of oil in once a month.
Your choice.
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: Rate of oil burn, not bad? [Re: MichaelRS] #5280738 11/29/19 08:47 PM
demarpaint Offline
For the mileage the consumption is not bad. I'd look for leaks, replace the PCV valve with an OE valve, if you haven't already done so, and try a 5W40 oil. If what I mentioned fails, I'd keep driving and top up the oil when needed.
God Bless Our Troops
Re: Rate of oil burn, not bad? [Re: MichaelRS] #5280771 11/29/19 10:15 PM
CanukFurius Offline
I would replace the valve cover gasket and the pcv valve. They are cheap and easy to do.
Re: Rate of oil burn, not bad? [Re: MichaelRS] #5280921 11/30/19 07:51 AM
G
Gebo Offline
G
Do you notice any drips in your driveway? My '98 LS400 with 302K miles started "using" oil around 280K and it finally started dripping. I have been smelling oil about the last 5K.
I found out I have 2 very bad cam seal leaks. Massive leaks. 6 spots overnight. May have to start a "GO FUND ME" page to finance the repairs.
grin2
Otherwise, that oil usage (1 qt/3K) is not bad at all for a 200K+.
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Shell Gas and Truck & Pennzoil Full Syn HM
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Rate of oil burn, not bad? [Re: MichaelRS] #5281237 11/30/19 02:55 PM
M
M
Thank you all for your replies and suggestions. I read each one. Probably should have, as one commentor did, put the 1 quart equivalent in there to make things a little easier.
So I'm burning a quart every 2,500 miles.
I actually have no idea what the burn rate was when I first got it because I really didn't start keeping track until last year at this time. Again because I did not find it particularly odd or concerning the amount I had to add between oil changes. So I'm currently only on my third oil change keeping such a record.
I always shoot for the oil and filter change in the 4000 mile range, but unfortunately I sometimes go up to the 5's and occasionally the early 6's. I always use a higher end filter or one that is touted as such. My favorite and the one I use most often is Royal Purple. Although currently I'm using the Mobil 1 Extended Performance.
Changing that PVC sounds like a good idea. I can get that done almost right away, but being on a fixed income anything major that is optional at the moment I need to defer..
And no, I actually do not see any particular leaking or spotting on the ground.
Thanks again for all your thoughts and suggestions
2002 Toyota Sienna
178k As of May 2017
