OVERKILL
$100 Site Donor 2021
Originally Posted by Ws6
I agree that right now, it is not appropriate for off-grid. However, my HVAC is a 13 SEER heat-pump. By the time I go off-grid, I will have replaced that. Winter hits the hardest, and with a more efficient heat pump, it will dramatically lower consumption. How much remains to be seen, but I suspect it will be significant.
Sure, as long as you are going into it with both eyes open, I expect you should be OK
As you can see, this couple hovers around 1,000kWh/month here in Canada, regardless of time of year. However the ability for a solar array of your size, at this latitude, to satisfy demand only works in the summer months for them. In fact, if we consider the round-trip penalty for storage, the over-capacity that your system would provide them likely makes it "just about right" for that period. Given the 40% CF figure we saw for the winter however, they'd realistically need a system 3x that size for it to work year-round! Pretty wild.
