Originally Posted by MONKEYMAN
Timing is everything. Very busy right now so the added speed is appreciated. I put Ubuntu on an newish IdeaPad since it was too slow for Windows 10. No change in speed according to Speed Test. Says 90 Mbps which is OK. Was the same with Windows 10. The HP laptop with the i5 is the one showing the doubling of speed which is my work horse.
It's likely the network card/adapters that are restricting those other devices. If you get it on any single device, the ISP has done their job. Make sure you're connecting to your router's 5g band too.
