What's going on?
by clinebarger - 12/13/19 12:28 AM
Price jacked up on Chevron Supreme at WM?
by Whammo - 12/12/19 11:23 PM
valvoline durablend 5w-30 in yaris, ok?
by jstert - 12/12/19 11:02 PM
Outsmarting RA’s Shipping Lunacy
by The_Nuke - 12/12/19 11:00 PM
Odd Ball!??
by miden851 - 12/12/19 09:40 PM
fedex lost package . how does it work?
by WhyMe - 12/12/19 09:39 PM
RTG 5W-20
by kstanf150 - 12/12/19 09:12 PM
First time running synthetic in my truck
by leeaspell - 12/12/19 09:05 PM
2007 Honda Accord Transmission
by maverickfhs - 12/12/19 07:59 PM
Detriot Axle brake kit review
by 14Accent - 12/12/19 07:51 PM
PQIA Issues An Alert!
by Jackson_Slugger - 12/12/19 06:36 PM
Late night commotion outside.
by LeakySeals - 12/12/19 06:27 PM
Help with Dewalt tools
by henni - 12/12/19 06:19 PM
Educate me on USB drives, devices
by 53' Stude - 12/12/19 05:55 PM
9012 bulb lasted 2 yrs... good?
by mclasser - 12/12/19 05:43 PM
2020 YUGO
by Malo83 - 12/12/19 04:53 PM
Ice on inside of windshield
by JLawrence08648 - 12/12/19 04:41 PM
AC DELCO PF 63E CUT OPEN
by 53' Stude - 12/12/19 04:10 PM
mb20music, Jaglenn, kalima, Powertool1994, lutvi20
70115 Registered Users
33 registered members (carlprop, clinebarger, adams355, BlakeB, cos, 928, 4 invisible), 894 guests, and 29 spiders.
Topics298,667
Posts5,140,058
Members70,115
Most Online3,589
Nov 2nd, 2019
Garden Sprayer- any Fluid retention? #5279860 11/28/19 03:52 PM
P
panthermike Offline OP
P
I read a while ago about using a garden sprayer to pump your fluids I think it's a great idea. I typically do a cold drain and fill on sealed trans units, so I always measure it. My question is; the black tube in the sprayer(pump), does it retain any Fluid or does it all get pumped out? I only ask as I don't want to underfill.or is there no fluid inside there at all? Obviously I don't fully understand how they work 😁
I was hoping someone here has used this method and has some insight. The garden sprayer is enticing option because pumping by hand gets old!
'17 Armada Platinum; RGT 0w20, 51K
'19 Ram 1500; Dealer fill, 14K
'70 F100; Valvoline 15w40
Biotech For All
Re: Garden Sprayer- any Fluid retention? [Re: panthermike] #5279870 11/28/19 04:12 PM
A
atikovi Offline
A
Don't think a garden sprayer can handle viscous fluids.
Re: Garden Sprayer- any Fluid retention? [Re: atikovi] #5279880 11/28/19 04:23 PM
W
WhyMe Offline
W
i had an old one that i converted to pump ATF. all i did was cut off the tip. refiling the 330I trans was such a pain with the hand pump since the fill hole was up there
Re: Garden Sprayer- any Fluid retention? [Re: atikovi] #5279881 11/28/19 04:26 PM
rooflessVW Offline
I have a 1 gallon for gear oil and a 2.5 gallon for ATF.
It pumps just fine.
OP, the pressure in the bottle will get 99% of the oil up out of the pickup tube. Gravity will take care of the rest of the tubing outside the bottle.
Re: Garden Sprayer- any Fluid retention? [Re: panthermike] #5279963 11/28/19 07:00 PM
H
HangFire Offline
H
I use a 1.5 gallon garden sprayer for VTM-4 and ATF. Air pressure does a good job of clearing what's in the hose. Of course there's always a minimal amount left in the bottom. It's little enough I wipe it out instead of waiting for it to drip out.
Various musings: http://hangfire.net
Re: Garden Sprayer- any Fluid retention? [Re: rooflessVW] #5280055 11/28/19 10:11 PM
B
BHopkins Offline
B
It pumps just fine.
I also have a 1 gal. for gear oil and a 2 gal. for ATF. I bought them on discount at the end of the summer. I removed the wand and attached a barbed ball valve so I can control the fluid. They work fantastic. I can't imagine going back to any of the other "popular" methods to pump fluids into transmissions or diffs.
Some fluid will stay in the hose, and even an ounce or so in the tank. I always put more than needed in the tank. For example, if the tranny calls for 7 1/2 quarts, I'll fill the tank with 8 quarts. Most transmissions I've worked with are designed to be filled to overflow. You fill it until fluid starts running out of the fill hole. So it isn't necessary to have the exact amount in the tank. In fact, it's helpful to have some extra.
In God we trust. All others bring data.
2013 Subaru Outback 2.5i - M1 HM 0W-20 & NAPA Gold filter
2014 Mercedes E350
Re: Garden Sprayer- any Fluid retention? [Re: panthermike] #5280198 11/29/19 07:44 AM
P
P
Thanks guys, I'll be doing a bunch of fluid changes coming up and am eager to try this out.
Biotech For All
Re: Garden Sprayer- any Fluid retention? [Re: panthermike] #5280776 11/29/19 10:28 PM
B
BHopkins Offline
B
You won't be disappointed. Using a modified garden sprayer is so much nicer. It makes the pumps that screw onto a quart bottle seem like little amateurish toys.
2014 Mercedes E350
Re: Garden Sprayer- any Fluid retention? [Re: panthermike] #5281440 11/30/19 07:43 PM
The Critic Offline
As an alternative, this is a pre-made solution, but costs a lot more money:
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5245121/thanks-mr-critic#Post5245121
2011 Toyota Prius 1.8L - 200K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 142K - Valvoline Premium Blue Restore 10W-30
Re: Garden Sprayer- any Fluid retention? [Re: panthermike] #5281608 12/01/19 03:23 AM
J
JTK Offline
J
I'll definitely be trying the garden sprayer oil shooter for my next Pathfinder transfer case gear oil change. Filling it from above IV style is a pain.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Garden Sprayer- any Fluid retention? [Re: panthermike] #5287930 12/07/19 05:55 PM
P
P
Got around to getting the pieces that I needed. I just clipped off the sprayer and attached the clear tubing and clamp from the Attwood pump with the Yamaha adapter to the sprayer hose(For the Armada's 7-speed trans) This set-up cost $19.50 plus tax. Very pleased with it now just have to see how it works!
[Linked Image]
[Linked Image]
Biotech For All
Re: Garden Sprayer- any Fluid retention? [Re: panthermike] #5287940 12/07/19 06:10 PM
J
JTK Offline
J
That's sweet panthermike!! Per the Nissan factory service manual for our 2015 Nissan Versa, even the last version of the ancient 4spd auto (2014-2017 model years only) is supposed to be filled through the drain/level check plug with that same type of tool. Luckily there is a "charge tube" up top with one of those locking caps on it that you can get to on it that the FSM makes zero mention of.
Re: Garden Sprayer- any Fluid retention? [Re: JTK] #5288023 12/07/19 07:59 PM
P
P
Yeah I'm not a fan of the design but hoping this setup makes the job much easier thumbsup
Biotech For All
