Mazda 3 i-ACTIV AWD diagonal test
by buster - 12/11/19 05:35 PM
Tires or Toyota ABS
by ford46guy - 12/11/19 05:33 PM
RV chase straight out of the Movies
by KeithS_NW_Ohio - 12/11/19 04:56 PM
Will the octane change?
by Mar57 - 12/11/19 04:45 PM
DIY brake lines help
by LeakySeals - 12/11/19 04:20 PM
random misfire code but not missing
by bowlofturtle - 12/11/19 03:31 PM
Pressure washing Santa Fe clay tile
by henni - 12/11/19 02:55 PM
Confused. Mercon V or Dexron VI?
by AcadiaDave - 12/11/19 02:33 PM
Sooty Oil in Ford Focus
by RW1 - 12/11/19 02:27 PM
oil sample shelf life?
by novadude - 12/11/19 12:51 PM
whoa!!walmart ammo clearance
by joel95ex - 12/11/19 11:56 AM
Carpro Reset
by BeerCan - 12/11/19 10:46 AM
Come on China. Let's get it right.
by Chris142 - 12/11/19 10:34 AM
'best' conventional 10w-40 pcmo for wet clutch bike
by kmrcstintn - 12/11/19 10:32 AM
Any reason not to use Carquest full synthetic?
by wbwanzer - 12/11/19 10:18 AM
53k miles on a Ford FA-1927
by BeerCan - 12/11/19 09:53 AM
Penzoil Platinum 100% Synthetic ????
by Talent_Keyhole - 12/11/19 09:50 AM
TyMillerfc, AcadiaDave, lmt1911, m14308, MyFirstNamePaul
70104 Registered Users
103 registered members (53' Stude, 40Deluxe, 2015_PSD, 97K15004WD, Aero540T, 01rangerxl, 10 invisible), 1,846 guests, and 26 spiders.
Topics298,592
Posts5,138,777
Members70,104
Most Online3,589
Nov 2nd, 2019
High mileage oil choices #5279694 11/28/19 11:19 AM
A
aquariuscsm Online Content OP
OP Online Content
A
I might change my oil again this weekend with a high mileage oil since I tracked down the source of the oil leak,and give it a try to see if I have success with it. I've narrowed down my choices.
Pennzoil High Mileage (the dino version)
Pennzoil Platinum High Mileage
Quaker State High Mileage (synth blend)
Castrol GTX High Mileage
Castrol Edge High Mileage
I'm leaning towards the Pennzoil dino one because I used it in my 300ZX and I loved how smooth it ran.
The QS one says "formulated to support catalytic converters and other emission equipment". The GTX one says "Phosphorus Replacement Technology to help extend the life of the emission system". What exactly does that mean add pack wise?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 0W20
Re: High mileage oil choices [Re: aquariuscsm] #5279714 11/28/19 11:35 AM
F
firebird72 Offline
F
i would suggest valvoline maxlife over any of those.
where is the leak you found? high mileage oils wont really stop or help a leak from a physically damaged gasket or seal, they only "condition" good seals to last longer. you might want to try adding an actual leak fix or seal sweller type of product if its anything more than just seepage.
Re: High mileage oil choices [Re: aquariuscsm] #5279716 11/28/19 11:38 AM
J
Jackson_Slugger Offline
J
Mobil 1 HM shut down the weeping leaks on my father's Taurus almost immediately...
Re: High mileage oil choices [Re: firebird72] #5279725 11/28/19 11:42 AM
A
OP Online Content
A
It appears to be leaking from where the oil filter mount is attached to the engine.
Re: High mileage oil choices [Re: aquariuscsm] #5279730 11/28/19 11:47 AM
M
MetalSlug Offline
M
Nothing beat Mobil 1 hm
Re: High mileage oil choices [Re: aquariuscsm] #5279784 11/28/19 01:27 PM
G
gman2304 Offline
G
Had a rear main seal leak on my Chevy 5.3 a couple of years ago. It would leave a quarter sized spot overnight. Valvoline Maxlife HM cured it within 500 miles. It hasn’t leaked since.
Re: High mileage oil choices [Re: firebird72] #5279806 11/28/19 01:57 PM
L
Lubener Offline
L
I believe max life was the first and that's what I would use too.
The "thinking" man's friend.
Re: High mileage oil choices [Re: aquariuscsm] #5279847 11/28/19 03:10 PM
E
ejes Offline
E
I've had my best luck with Valvoline Full Syn HM and ST Full Syn HM in an 04 Dodge 1500 5.7. I tried PP full syn HM a few times in a 97 LeSabre with the 3800 V6 and it just didn't seem to perform as well for me.
Re: High mileage oil choices [Re: aquariuscsm] #5279868 11/28/19 04:08 PM
csandste Offline
ST Full Syn HM costs the same as the non-high mileage IIRC and would be my choice if I was filling it myself.
2017 Kia Soul Plus-- VWB 5w30+ a bit of Harvest King syn 5w30-- 70,000 miles
Re: High mileage oil choices [Re: aquariuscsm] #5279884 11/28/19 04:33 PM
dave1251 Offline
I've used almost all and haven't noticed a difference. Then again I've not had a leaker.
don't use.
Re: High mileage oil choices [Re: aquariuscsm] #5279899 11/28/19 05:04 PM
Charlie2015 Offline
I highly recommend Valvoline Maxlife.
1998 Honda Accord EX 2.3L Auto (Sold) 214k mi
2009 Scion tC Manual (Daily Driver) 170k mi - Valvoline Maxlife 0w20
Re: High mileage oil choices [Re: aquariuscsm] #5279997 11/28/19 08:07 PM
ctechbob Offline
Is it super hard/impossible to get to? (assuming we're talking about your 300zx). If not, 4 bolts and a gasket, I'd rather just fix the leak than try to bandaid it. Also, judging by what I'm seeing online it is a paper type gasket anyways, no seal sweller in the world is going to work on that.
2008 Acura TL Type S-155k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W20
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: High mileage oil choices [Re: ctechbob] #5280099 11/29/19 01:11 AM
M
Mad_Hatter Offline
M
That's a good point. It's important to know what the leaking gasket material is made of. Seal conditioners (plasticizers) do nothing for non rubber type gaskets. A lot of people don't know this and when the HiMi oil fails to solve the leak, they get mad and frustrated with the product, calling it "snake oil" etc...all the time not realizing they have a fibre gasket/seal.
Re: High mileage oil choices [Re: ctechbob] #5280305 11/29/19 10:12 AM
A
OP Online Content
A
The leak is on the filter mount on my Accord,coming from the gasket where it connects to the block. It's definitely buried, not sure if I'd need a lift or maybe a specialized wrench to get into the tiny spaces to access the bolts. Funny thing,we went on a short road trip yesterday (200 miles) and when we got home I opened the hood to examine the leak,and no oil had leaked whatsoever.
Re: High mileage oil choices [Re: aquariuscsm] #5280692 11/29/19 07:47 PM
ctechbob Offline
Ohh, in that case, its just 2 o-rings that should sit behind that plate. Give the HM a try, can't hurt.
Guess that didn't really answer your question.
Any of the HM oils are going to carry the SN or SN+ rating. You can use them without worrying about cat damage as in order to carry the SN rating they have to be cat friendly in the first place.
Trans-Idemitsu H+
