Originally Posted by Astro_Guy
Originally Posted by wag123
It's the gas that gets old and goes bad, not the alcohol, so yes, treat the E0 gas. You should still buy only what you will use up in 6 months or less (best practice, even if treated) and you still need to run your machinery dry before storage.
Agreed, but Stabil 360 is supposed to maintain a positive vapor pressure and thus keep water vapor from entering the fuel tank. I have some Stabil 360 on hand and will dose up this 5 gallons prior to using it.
As long as there isn't alcohol in the gas, this is not a problem. The problem exists with gasohol (E10, E15, etc) because alcohol attracts and absorbs water from the air and will eventually cause phase separation, this is what Stabil 360 is supposed to minimize. Gasoline by itself (E0) does not absorb water so the higher priced Stabil 360 is not necessary in E0. Be advised that Stabil 360 does NOT prevent condensation from forming inside a partially full fuel tank or container. Condensation will eventually cause water to build-up in the bottom of the fuel tank or container, this is not the same as phase separation.
