Current Honda Factory Fill
by asiancivicmaniac - 12/09/19 04:16 AM
Gulf Western - Premium Gold 15W40
by SR5 - 12/09/19 03:43 AM
how can one tell 100% that the oil was changed
by WhyMe - 12/09/19 03:22 AM
Scraped the side of my truck...
by GumbyJarvis - 12/09/19 12:44 AM
Outlasted 3 Marriages
by Y_K - 12/08/19 10:10 PM
High miles on 0W20 oils?
by EyesofThunder - 12/08/19 10:02 PM
90 350 intake gaskets and sealant
by P10crew - 12/08/19 10:01 PM
Glock Polymer80
by pkunk - 12/08/19 09:59 PM
Reman steering rack 09 CRV
by Chester11 - 12/08/19 09:24 PM
Edge 5W-30 10k miles '13 F150 5.0
by dustyroads - 12/08/19 09:18 PM
Hyundai engine failures getting news again
by OVERKILL - 12/08/19 09:04 PM
2015 Ford Fiesta ST
by daemontrym - 12/08/19 07:39 PM
NVX NSP65 Speaker review: Good deal!
by 14Accent - 12/08/19 07:26 PM
Thanks to Quattro Pete for making the 2020 avatars!
by wwillson - 12/08/19 07:17 PM
Klotz 2 Stroke Smelling Candle
by FA_WRX - 12/08/19 06:31 PM
Non scientific oil test.
by tblt44 - 12/08/19 05:33 PM
Nitromethane prices
by 53' Stude - 12/08/19 05:31 PM
Question about JASO specs?
by frascati - 12/08/19 04:15 PM
Anyone knows outdoorsy magazine that are US only?
by MoneyJohn - 12/08/19 03:54 PM
redradar, Jonas_K, slxgold, Dennisfly, AutopartsTester8
70070 Registered Users
36 registered members (Dave_Mark, 2015_PSD, adams355, Bookmaker, CB900F2, Bjornviken, 3 invisible), 808 guests, and 41 spiders.
Topics298,473
Posts5,136,107
Members70,070
Most Online3,589
Nov 2nd, 2019
Page 1 of 3 1 2 3
9005 upgrade bulbs? #5279371 11/28/19 12:28 AM
AZjeff Offline OP
I commute at 4am for 40 minutes all year and most of it is at 65-70 mph with very little traffic. The RAV4 uses 9005s for high and low ( projector) beams, I had Sylvania Xtra Visions in the high beam that doubles as the DRL at reduced power. One of the bulbs blew up and made a mess in the housing, not sure if it had to do with the DRL function but since then I've kept the DRL off. I'd like to have more light in both low and high beams. Do any of the enhanced bulbs from Sylvania or Philips or Hella have a noticeable difference in output? Not real interested in LEDs as there seems to be conflicting reports and I really don't want to experiment. I see Hella has 100W 9005s, standard is 65W. They also come with a warning about damaging housings not designed for the higher wattage.
Thanks for any advice.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: 9005 upgrade bulbs? [Re: AZjeff] #5279374 11/28/19 12:40 AM
P
pitzel Offline
P
Look up 9011/9012 HIR swaps. No extra power consumption, they use some technological tweaks to achieve the extra output and higher longevity.
Change your thinking...not your oil!
Turn your mind....not your rotors!
Re: 9005 upgrade bulbs? [Re: pitzel] #5279377 11/28/19 12:44 AM
dogememe Offline
I've been considering this. Worth it for my Suburban or should I go LED? for my high beams
2010 Ford Escape 2.5 ~102K Miles: Castrol Magnatec 5W-20, Wix Filter.
2001 Chevy Suburban 5.3 ~289K Miles: Unknown Oil, Filter.
Re: 9005 upgrade bulbs? [Re: dogememe] #5279386 11/28/19 01:05 AM
Skippy722 Online Happy
Online Happy
I actually switched from LED’s back to 9011’s. Love them, great brightness and they don’t produce any funky beam patterns like LED’s do.
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: 9005 upgrade bulbs? [Re: dogememe] #5279391 11/28/19 01:49 AM
P
pitzel Offline
P
LEDs are so hit and miss, and there's so much cr*p out there. Plus while 9011's are basically just an upgraded 9005 bulb (on steroids), LEDs can have completely different beam patterns and have unpredictable interactions with headlight projectors/reflectors/etc.
If you shop on Amazon and eBay, you can retrofit Philips 9011/9012's into 9005/9006's all 4 bulbs for $50-ish. The 9012's are apparently good for 1000 hours, which, in my world, is 100k miles of use. Maybe in a few years, there will be better/cheap LED options available from reputable outfits (not random People's Republic manufacturers) at more reasonable prices. And longevity will be better understood as there's very little good data out there on how long the cheapie LED headlight bulbs last.
Re: 9005 upgrade bulbs? [Re: AZjeff] #5279463 11/28/19 06:45 AM
SubieRubyRoo Offline
What Skippy said... 9011s in place of 9005s is a big upgrade in light output. I got some 9011 HIRs for about $17 each from Amazon; first time I had them in I had my son actuate the highs while I was about 30 feet in front of the car... I still have blue orbs floating in my vision LOL
I had a set of Hikari LEDs in my Outback's low beams (H7), and in addition to a less than optimal beam pattern, to get a good cutoff line where I could actually see more than 4' in front of the car I had to raise the housings so high I'm sure aircraft pilots wondered WTH was going on when I had the highs on.... tops of trees was the lowest thing they hit with the LEDs in the low beam!
Re: 9005 upgrade bulbs? [Re: AZjeff] #5279539 11/28/19 08:19 AM
R
Rolla07 Offline
R
I did the 9011 swap and the bulbs burned out within 3 months (bulbs were handled with gloves(correctly) too). I went to LEDs, 2 years later they still work. Maybe HID is worth a look. I think the risk with 9011 is ruining the headlight lenses with increased heat...
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: 9005 upgrade bulbs? [Re: AZjeff] #5279548 11/28/19 08:35 AM
A
Audios Offline
A
Careful when adding higher wattage incandescent bulbs, theres a good chance the harness will melt too.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: 9005 upgrade bulbs? [Re: Rolla07] #5279564 11/28/19 08:55 AM
X
XCIDMigs Offline
X
That makes almost no sense as the upgrade from OEM to 9011 has been done a million times and I have personally run them for years in several vehicles. they are just slightly higher Watts, nothing like a 100W bulb the OP was thinking about and have much brighter/whiter output. The other great thing is that its available anyplace unlike a LED or HID kit which if you have a failure then you are stuck looking for parts online or removing the whole thing.
To the OP read some more about it here
https://www.candlepowerforums.com/v...12-always-the-best-upgrade-for-9005-9006
Re: 9005 upgrade bulbs? [Re: AZjeff] #5279599 11/28/19 09:29 AM
Driz Offline
If you can do it how about switching to LED. I know you have to change out the entire housings but in my opinion for a guy like you it’s worth it. 4 AM is just the perfect time to be running into Bambi having dinner on the side of the road at least around here. We just got LEDs for the first time six months ago and I’ll never go back. The way they illuminate the roadsides off into the tree line would be especially useful for a guy was driving at four in the morning once it’s in the urban areas. Maybe even good in urban areas to simply because it lights up the edges so well and the throw is nothing short of fantastic. Of course there’s the price but that’s dropping fast .....
Re: 9005 upgrade bulbs? [Re: AZjeff] #5279607 11/28/19 09:32 AM
M
mk378 Offline
M
If your housing is no good it wouldn't matter what bulb you use. Degraded reflective coating often hurts housing performance worse than a cloudy lens, and it can be difficult to spot.
Re: 9005 upgrade bulbs? [Re: AZjeff] #5279654 11/28/19 10:36 AM
AZjeff Offline OP
Thanks, the 9011 upgrade was exactly what I was looking for. It seems like the price of 9011s has gone up, pretty hard to replace all 4 for $50 now. The links were interesting reading for the tech and the fact that there are light bulb nerds out there.
Re: 9005 upgrade bulbs? [Re: AZjeff] #5279873 11/28/19 04:18 PM
P
pitzel Offline
P
Yeah they were like $11 on Amazon for a few months, the 9011s, but a little more now. I can still find genuine Philips 9012LL's on eBay (from a vendor that I've purchased from previously) for $22 for the pair. So a slight bit over $50. LEDs, at least twice that, if not 3X that, and almost none of the LEDs on the market are backed by a major brand name (although I see Philips has succumbed to the siren call of retrofit LEDs and hawks some kits that have fans -- I personally wouldn't consider anything that needs a fan!).
Re: 9005 upgrade bulbs? [Re: AZjeff] #5279924 11/28/19 05:38 PM
Online Happy
[Linked Image]
Here’s a low beam road shot of my SL1 LED’s on top and 9011 halogens on bottom. The high beam with the halogens is so so so much better than the LED’s.
Re: 9005 upgrade bulbs? [Re: AZjeff] #5279994 11/28/19 07:56 PM
Deontologist Offline
At those speeds and given that there is little traffic, I would seriously consider a ECE-approved auxiliary driving lamp/auxiliary high-beam. One of these will basically double your stock high-beam setup's output. They're very small and light and can easily fit somewhere in the fascia of your car.
https://www.quadratec.com/p/hella/470-series-19-led-light-bars
Page 1 of 3 1 2 3
