Michelin Defender on Civic
by jharrison - 12/06/19 08:14 PM
2012 GMC Terrain 3.0L V6 Valve Cover Replacement
by benjamming - 12/06/19 07:30 PM
Cam2 CVT fluid is green, and so is Transtar
by slacktide_bitog - 12/06/19 06:59 PM
Rotating Directional Tires for Dry Conditions
by CharlieBauer - 12/06/19 03:42 PM
Review: My 2011 Prius turned 200K
by The Critic - 12/06/19 03:29 PM
NIB sggcx2 dash cam
by BeerCan - 12/06/19 02:57 PM
Mazda FL22 alternative?
by jayjr1105 - 12/06/19 01:57 PM
Tips for sealing radiator hose
by Parlay_Slow - 12/06/19 01:51 PM
Valvoline
by Koncrete_Cam - 12/06/19 01:32 PM
At home tire rotation protocol question
by NissanMaxima - 12/06/19 12:57 PM
Base oil different in 0W vs 5W?
by doyall - 12/06/19 12:54 PM
Five Gees
by Y_K - 12/06/19 12:31 PM
Valvoline Dex/Merc Label
by 28oz - 12/06/19 12:23 PM
Storing a vehicle- advice please!
by Rolla07 - 12/06/19 11:53 AM
1964 Cub Cadet 100
by Phishin - 12/06/19 11:40 AM
2001 Volvo V70XC 6140 Miles Mobil1 10w-30 HM
by Astro_Guy - 12/06/19 11:22 AM
Blend door motor reset
by otis24 - 12/06/19 11:08 AM
Stahle, BajaBu, Bayoubrad, Fog42, glassmaker
70053 Registered Users
101 registered members (andyd, 4WD, Astro14, 2004tdigls, AC1DD, 11 invisible), 2,049 guests, and 61 spiders.
Topics298,385
Posts5,134,253
Members70,053
Most Online3,589
Nov 2nd, 2019
Replaced my brake pads after 21 years #5279238 11/27/19 08:19 PM
E
Elkins45 Offline OP
E
I inherited a 1998 Chevy 1500 4x4 truck in 2011. At the time it had 22k miles, now it has 45k. The front brake pads wore down to bare metal and didn’t give any indication until I heard one grinding against the rotor. That rotor was too grooved to reuse. The other side had like .1mm of lining left and the but I went ahead and replaced it as well so both sides would be equivalent. Amazingly enough the calipers and rotors came off without drama. I was expecting to have to break out the 10lb hammer and torch to remove the rotor but it fell right off when I pulled the caliper.
45k of easy driving seems premature for a set of pads to wear out. I guess after 21 years they must just have been deteriorated by weathering, or because the rotor had time to rust between every trip?
Re: Replaced my brake pads after 21 years [Re: Elkins45] #5279241 11/27/19 08:22 PM
B
bullwinkle Offline
B
Chevy truck? 4 X 4?? 45K has to be a record for longevity! All our GM vans needed front pads (& usually rotors) by 20-25K.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Replaced my brake pads after 21 years [Re: Elkins45] #5279248 11/27/19 08:25 PM
Dave9 Offline
More likely your driving was mostly stop and go so it's not the mileage but # of stops that wore them, but yes time will cause pad corrosion and disc corrosion and they will both wear down faster unless that corrosion is also reducing stopping power 'cuz it's on the slide pins or rails the pad ears ride on.
It would be a good idea to check your brakes more often. Far more often.
Re: Replaced my brake pads after 21 years [Re: Elkins45] #5279255 11/27/19 08:30 PM
K
Kruse Offline
K
This truck didn't have the little "squealer" tang on the pads that makes noise when the pads are getting thin?
Re: Replaced my brake pads after 21 years [Re: Elkins45] #5279279 11/27/19 09:04 PM
Dinoburner Online Content
Online Content
The 95 in my sig is on the second set of rotors and 3rd set of pads at 140,000 mi. The 77 is on the second set of pads at 180,000. All other vehicles we have owned averaged 50,000 miles between brake repair of some sort. I bought the last set of asbestos pads sold by the local parts store for the 77.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: Replaced my brake pads after 21 years [Re: bullwinkle] #5279320 11/27/19 10:00 PM
F
Fawteen Offline
F
Yet I've had an '88 that went almost 100,000 miles on the original brakes, and a '95 that went 70,000 on the original brakes. My 2014 has over 80,000 on the original brakes. So 45K isn't a "record for longevity". All of them were/are Chevrolet, and all were 4X4.
2014 Silverado
2014 Equinox
1972 Olds 442 Convertible
1918 Model T
Re: Replaced my brake pads after 21 years [Re: Dave9] #5279322 11/27/19 10:03 PM
E
Elkins45 Offline OP
E
I doubt I will ever check my brakes again. Rust is going to kill the suspension/steering components long before my new ceramic pads will wear out. As little as ai drive it I doubt this vehicle will ever see 70K.
I wonder what the chances are of removing the rear drums as easily as the calipers and rotors came off the front?
Re: Replaced my brake pads after 21 years [Re: Elkins45] #5279349 11/27/19 11:28 PM
U
user52165 Offline
U
There's more to checking brakes than pad thickness. Caliper pins, piston boots, shims and retainers all should be periodically checked and lubed. This tool can be used without removing the wheels since you probably don't rotate tires either:
https://smile.amazon.com/gp/product/B0015DMJ2S/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Re: Replaced my brake pads after 21 years [Re: user52165] #5279353 11/27/19 11:35 PM
E
Elkins45 Offline OP
E
Wow...feel the judgement.
Re: Replaced my brake pads after 21 years [Re: Elkins45] #5279449 11/28/19 06:19 AM
G
GoldDot40 Offline
G
I rotated the tires on my '02 Silverado Z71 about a month ago. I gave the hubs/brakes a once over. Front and rear pads still have about 60% material left. Got me to thinking. I couldn't remember the last time I put brakes on it.
All my brakes are purchased through Advance Auto parts online. I logged in to my account and combed through my purchase history. Last time I put brakes on it, I also installed new rotors on all 4 corners. That was in August of 2013.....roughly 66K miles ago.
Equal Opportunity Offender
Re: Replaced my brake pads after 21 years [Re: Elkins45] #5279452 11/28/19 06:28 AM
caprice_2nv Offline
My coworker went 180k on the front and over 200k on the rear brakes on his 2010 Sierra 4x4. The 2013 Silverado in our work fleet has original with 90k miles. We've put one set on the 2005 I drive with 200k on it but it may have been the second set on the front (my boss bought it used with less than 100k).
Different brand but the 2010 Tacoma just needed brakes at 100k.
All of these trucks carry a heavyish load every day (land surveying).
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
79 Honda CX500
Re: Replaced my brake pads after 21 years [Re: Elkins45] #5279501 11/28/19 07:32 AM
K
Kira Offline
K
The OP commented on brake pads above: "The other side had like .1mm of lining left and the but I went ahead and replaced it as well so both sides would be equivalent."
1) I still can't believe someone actually said that.
2) The OP must be cheaper than me (hard to fathom) NOTE: 0.1mm ain't much!
Re: Replaced my brake pads after 21 years [Re: Kira] #5279531 11/28/19 08:10 AM
E
Elkins45 Offline OP
E
I meant that I replaced the rotor even though it wasn't grooved like the other side. That pads on that side hadn't worn down to the backing plate. I realize now that what I meant and what I wrote are two different things. I'm not THAT cheap wink and anyway pads should always be replaced on both sides at the same time.
Re: Replaced my brake pads after 21 years [Re: Elkins45] #5279541 11/28/19 08:23 AM
Driz Offline
I can’t see how in the world it could do that unless you never drove it. I’ve got one of those, 2000 Sierra. That thing has rear brake pads that are the size of my Honda Civic🤬. About the only thing good about them is it there so easy to just flip up and shove some new pads on there which is a good thing because it needs them all the time. You must live in the south because anybody who could keep a frame on one of these for that many years is a magician. I ended up making my own but the one that I took off it look like a piece of unit body tin. It’s not a terrible truck especially compared to what came after that it’s a far cry from when I made real trucks in the 1970s and 80s.
Re: Replaced my brake pads after 21 years [Re: Driz] #5279561 11/28/19 08:54 AM
Silverado12 Offline
Yeah, those early 2000s GM trucks def had some frame rust issues. GM went back to drums for a while as that's what my '12 has. I think now everyone uses disc on the rear.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
