Can I put a cap over this plug?
CA, USA
https://imgur.com/a/nsp4JVG
It is for an old drill. It was old when I saw it in my dad's garage when I was a kid, and now I have it.
My question is--can I put something (a plastic cover of some kind) over the plug, to cover this up? It is for a drill, it is working just fine. I'm just worried about something getting inside & ending the life of this drill prematurely. If they don't sell that type of thing, would it make any sense for me to simply wrap electrical tape over it?
Hardware stores should have inexpensive replacement plugs that have the correct insert you are missing. I would try to use one and then electrical tape around the edges, so it doesn't get lost like the original one. Failing that, I have used electric tape to cover and protect the exposed wires. I would put in a double layer. Third option would be to make a pattern and cut out a paperboard new one and tape it on.
That looks promising. So it would essentially swallow up what I have now? I would just plug in the current prong, into the innards of the yellow plug? Or would I have to cut the plug off, and then work the wires in my cable, inside the yellow unit?
Originally Posted by Sunnyinhollister
Why not replace it with one of these:
https://www.amazon.com/Leviton-515P...=120v+plug&qid=1574904289&sr=8-4
Short term solution: Tape an air-tight seal on the cord end of the plug, hold it upright and fill it with epoxy.
Long term solution: Replace the cord and plug, and clean and lube the inside.
Depending on just exactly how "old" old is, chances are good that the cord is rubber insulated and if not already dry-rotted, it will at some point in the future.
I'd head to the hardware store, get as much cord of the appropriate gauge as I wanted to have on it, terminate it with a new plug, and call it a day. A plug should be $5 or less, and a few feet of cord will be about the same.
