98 registered members (94astro, alarmguy, 4WD, Audios, Astro14, alchargo, 12 invisible),
2,721
guests, and 61
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,406
Posts5,134,818
Members70,059
Most Online3,589 Nov 2nd, 2019
Can I put a cap over this plug?
#5279013
11/27/19 03:56 PM
paulri
OP
OP
Posts: 1,329 |
https://imgur.com/a/nsp4JVGIt is for an old drill. It was old when I saw it in my dad's garage when I was a kid, and now I have it. My question is--can I put something (a plastic cover of some kind) over the plug, to cover this up? It is for a drill, it is working just fine. I'm just worried about something getting inside & ending the life of this drill prematurely. If they don't sell that type of thing, would it make any sense for me to simply wrap electrical tape over it?
2005 Toyota Sienna LE; 163,000 miles 2006 Toyota Highlander Hybrid 118,000 miles
Re: Can I put a cap over this plug?
[Re: paulri]
#5279048
11/27/19 04:27 PM
JayhawkRoy
Posts: 1,208 |
Hardware stores should have inexpensive replacement plugs that have the correct insert you are missing. I would try to use one and then electrical tape around the edges, so it doesn't get lost like the original one. Failing that, I have used electric tape to cover and protect the exposed wires. I would put in a double layer. Third option would be to make a pattern and cut out a paperboard new one and tape it on.
[Re: paulri]
#5279140
11/27/19 06:07 PM
HangFire
Posts: 3,750 |
I would replace the entire cord, not just the plug.
[Re: paulri]
#5279195
11/27/19 07:28 PM
Sunnyinhollister
Posts: 898 |
2017 Ram 1500 Regular Cab 4x2 5.7L 8spd 2017 Chevy Bolt 2018 Jeep Cherokee Trailhawk 2004 Toyota Highlander AWD - RIP 2001 Ranger XL 4x4
[Re: Sunnyinhollister]
#5279210
11/27/19 07:44 PM
paulri
OP
OP
Posts: 1,329 |
That looks promising. So it would essentially swallow up what I have now? I would just plug in the current prong, into the innards of the yellow plug? Or would I have to cut the plug off, and then work the wires in my cable, inside the yellow unit?
[Re: paulri]
#5279222
11/27/19 08:05 PM
Chris142
Posts: 19,878 |
Spend the $3 on a new plug.
02 Wrangler Napa high milage 10w40 87 F250 Valvoline 15w40 07 fjcruiser Car lube plus 10w30 Z400 castrol T 10w40 Can am Maveric edge 5w40 57 case tractor Chevron sae30
[Re: Chris142]
#5279226
11/27/19 08:06 PM
paulri
OP
OP
Posts: 1,329 |
Spend the $3 on a new plug. Like the one Sonny recommended? Or did you mean something different?
[Re: paulri]
#5279269
11/27/19 08:52 PM
Dave9
Posts: 963 |
Short term solution: Tape an air-tight seal on the cord end of the plug, hold it upright and fill it with epoxy.
Long term solution: Replace the cord and plug, and clean and lube the inside.
[Re: paulri]
#5279270
11/27/19 08:55 PM
Sunnyinhollister
Posts: 898 |
[Re: paulri]
#5279300
11/27/19 09:27 PM
Dinoburner
Posts: 477 |
We upgraded to a three prong cord on a 60 plus year old drill. It was easy to find a screw for the bonding conductor. This is assuming a metal drill.
77 Chev stepside 454 Casteroil syn 95 GMC 4wd mobil syn 2016 Equinox LTZ V6 dealer Kubota L5030 T6
[Re: paulri]
#5279335
11/27/19 10:30 PM
bunnspecial
Posts: 1,080 |
Depending on just exactly how "old" old is, chances are good that the cord is rubber insulated and if not already dry-rotted, it will at some point in the future.
I'd head to the hardware store, get as much cord of the appropriate gauge as I wanted to have on it, terminate it with a new plug, and call it a day. A plug should be $5 or less, and a few feet of cord will be about the same.
2010 Lincoln MKZ-Mobil 1 5W-30 1970 MG MGB Roadster-Valvoline VR-1 20W-50 1974 Austin Marina GT VR-1 20W-50
