If you don't need the space, look at a 2020 Prius. They redesigned them and they are much less ***** than the 2019's and previous. You can get them in AWD now too if you need that.
If you could use the space the RAV 4 hybrid or not is worth a look. We have a 2015 non hybrid AWD with about 80K on it now. No issues to date, just oil changes every 10K, 2 sets of tires and front pads. It's comfy, roomy, rides well and seems to be built well. My only complaint is it's kind of a slug, it could use some more power. It sees wide open throttle often merging or passing.
