95 registered members (alarmguy, 69Torino, 40Deluxe, 14Accent, Ag76, 6 invisible),
1,798
guests, and 17
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,824
Posts5,142,067
Members70,129
Most Online3,589 Nov 2nd, 2019
Fuel filter change on a 2016 Prius
#5278510
11/27/19 01:16 AM
bogito
OP
OP
Posts: 6 |
Hi all!
I have a 2016 Prius with 33k miles and I am due to another oil change. Does anyone have an idea when and how often should I change the fuel filter?
Thanks in advance. Cheers!
Re: Fuel filter change on a 2016 Prius
[Re: bogito]
#5278515
11/27/19 01:53 AM
dogememe
Posts: 2,235 |
Fuel filter is not serviceable. It's part of the fuel pump inside the tank. Don't worry about it!
2010 Ford Escape 2.5 ~102K Miles: Castrol Magnatec 5W-20, Wix Filter. 2001 Chevy Suburban 5.3 ~290K Miles: Unknown Oil, Filter.
[Re: bogito]
#5278518
11/27/19 01:59 AM
Char Baby
Posts: 11,972 |
I may be wrong in the case of a Prius however, there is typically no specific interval change on the fuel filter as it's part of an assembly(filter, float, fuel pump) in the gas tank as most vehicles have. If you ever have to drop the gas tank for repair/replacement, then the assembly may be a consideration depending on mileage of the vehicle.
I'd like to know as well.
"Retired" -----------------------------------
'80 Firebird FORMULA V8/4bbl-purchased "NEW" '15 Nissan Altima 2.5 SV '15 Honda Civic 1.8 LX
[Re: dogememe]
#5278552
11/27/19 05:08 AM
JohnnyJohnson
Posts: 5,687 |
Fuel filter is not serviceable. It's part of the fuel pump inside the tank. Don't worry about it! Yes wasn't that just a piece of Toyota engineering.
2004 Corolla 137480 Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457 In: Pennzoil Platinum HM 5W-20 ST 4386 2006 Duramax 76862 Out: T6 5W-40 XG9100 73909 In: Rotella Dino PH9100 11-3-19
[Re: bogito]
#5278602
11/27/19 07:12 AM
CourierDriver
Posts: 5,469 |
Wait for the 500 dollar fuel pump change out,,,
I'd still like to have my 67 Beetle back....life was easy then..imho 2 quarts of oil roughly ,lol
[Re: JohnnyJohnson]
#5278606
11/27/19 07:19 AM
atikovi
Posts: 3,294 |
Fuel filter is not serviceable. It's part of the fuel pump inside the tank. Don't worry about it! Yes wasn't that just a piece of Toyota engineering. I can't recall any car less than 10 years old with a replaceable fuel filter.
[Re: atikovi]
#5278662
11/27/19 08:25 AM
Dave Sherman
Posts: 1,310 |
Fuel filter is not serviceable. It's part of the fuel pump inside the tank. Don't worry about it! Yes wasn't that just a piece of Toyota engineering. I can't recall any car less than 10 years old with a replaceable fuel filter. Agreed. My '97 Saturn was the last car I had that had a serviceable fuel filter. I thought nearly all cars went to the sock inside the tank that doesn't get replaced.
2015 Honda Pilot EX AWD Valvoline 0W-20 Bosch filter 1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
[Re: bogito]
#5278717
11/27/19 09:40 AM
CR94
Posts: 2,490 |
... Does anyone have an idea when and how often should I change the fuel filter? ... Yes. Replace the sock only if you get an extraordinarily dirty batch of fuel that clogs it. Otherwise, why worry about it? The original replaceable filter of my Mazda clogged at about 250k miles. The replacement filter never did, although the car continued about that much farther.
2011 Toyota Prius now at 107K 1981 Mazda GLC (323) retired at 606K 1972 Subaru DL retired at 190K 1954 Chevrolet retired at 121K
[Re: bogito]
#5278739
11/27/19 10:06 AM
GSCJR
Posts: 1,190 |
My 2003 Highlander went over 265k Kms without a pump or filter change before I sold it this year. Ran it with less than half a tank of fuel for the last 6 or 7 years and ran it out of fuel twice in the last 11 or so years of ownership.
07 3.5L VQ35DE NAPA FS 5w-30 ProSelect 21358 150KM 10 3.5L 2GR-FE NAPA FS 5w-20 ProSelect 27047 175KM
[Re: bogito]
#5279433
11/28/19 04:35 AM
bogito
OP
OP
Posts: 6 |
Ok, I will not bother. Thanks, guys!
[Re: bogito]
#5283186
12/02/19 05:05 PM
Direct_Rejection
Posts: 340 |
Lexus UX 250h. I only use ARCO 91 octane Top Tier fuel. I only fill up with fresh fuel at a station near SFO where all the Uber drivers fill up. It is so busy that the tanker trucks replenish the holding tanks 2x per day. The fuel gauge does not go below 1/4 tankful.  I learned the hard way. There was a fuel pump failure in the number two lane, Northbound 101, during morning commute, at Hospital Curve. Trust me. Don't go there.
Lexus UX 250h F-Sport Pennzoil Hybrid 0W16
Driver is allergic to walnut shells.
[Re: JohnnyJohnson]
#5291720
12/11/19 05:03 PM
nthach
Posts: 6,107 |
Fuel filter is not serviceable. It's part of the fuel pump inside the tank. Don't worry about it! Yes wasn't that just a piece of Toyota engineering. Mopar was the first to switch over to in-tank filters and then Honda. The Germans have until recently still use inline filters.
