Mazda 3 i-ACTIV AWD diagonal test
by buster - 12/11/19 05:35 PM
Tires or Toyota ABS
by ford46guy - 12/11/19 05:33 PM
RV chase straight out of the Movies
by KeithS_NW_Ohio - 12/11/19 04:56 PM
Will the octane change?
by Mar57 - 12/11/19 04:45 PM
DIY brake lines help
by LeakySeals - 12/11/19 04:20 PM
random misfire code but not missing
by bowlofturtle - 12/11/19 03:31 PM
Pressure washing Santa Fe clay tile
by henni - 12/11/19 02:55 PM
Confused. Mercon V or Dexron VI?
by AcadiaDave - 12/11/19 02:33 PM
Sooty Oil in Ford Focus
by RW1 - 12/11/19 02:27 PM
oil sample shelf life?
by novadude - 12/11/19 12:51 PM
whoa!!walmart ammo clearance
by joel95ex - 12/11/19 11:56 AM
Carpro Reset
by BeerCan - 12/11/19 10:46 AM
Come on China. Let's get it right.
by Chris142 - 12/11/19 10:34 AM
'best' conventional 10w-40 pcmo for wet clutch bike
by kmrcstintn - 12/11/19 10:32 AM
Any reason not to use Carquest full synthetic?
by wbwanzer - 12/11/19 10:18 AM
53k miles on a Ford FA-1927
by BeerCan - 12/11/19 09:53 AM
Penzoil Platinum 100% Synthetic ????
by Talent_Keyhole - 12/11/19 09:50 AM
TyMillerfc, AcadiaDave, lmt1911, m14308, MyFirstNamePaul
70104 Registered Users
103 registered members (AZjeff, 40Deluxe, 53' Stude, 379KITTY, aquariuscsm, Aichiguy, 9 invisible), 1,847 guests, and 28 spiders.
Topics298,592
Posts5,138,790
Members70,104
Most Online3,589
Nov 2nd, 2019
LED replacement bulbs don't work in a fluorescent lamp #5278441 11/26/19 10:06 PM
Number_35 Offline OP
Hello all, hoping as usual you all can provide some wise technical advice.
I have a SAD* light which uses three fluorescent bulbs. The bulbs are oddballs, 2G10 type. The light seemed dimmer than usual (it used to be quite bright) and when I opened it up, one of the three bulbs was burnt out. Rather than replace it with another fluorescent, I figured I'd switch over to LED. The 2G10 bulbs are rare, and I couldn't get one locally, but did find them online.
(* The SAD light is used to treat Seasonal Affective Disorder, which is essentially poor mood due to lack of sunlight, unfortunately quite common here during our long dark northern winter.)
Received them today, installed them, and fired up the lamp with the cover off (seven screws to remove the translucent cover, so wanted to make sure I had the bulbs seated correctly). The three new bulbs looked great. So I put the cover back on, and none of the three bulbs would light. Wha ...???
Took the cover off again and tried substituting in the two good fluorescent bulbs. They worked fine, but I could not get more than a flicker out of and of the LED bulbs. There was a mild but definite smell of hot electronics. I wondered if I'd smoked something in either the lamp or the new LED bulbs. Took the plastic covers off of one of the bulbs and tried to probe the internal wiring to see if the bulb was getting voltage. Strangely enough, touching any one of six of the eight contact points (there are four "tubes", each with a + and a -) with one probe only caused the LEDs to illuminate. I tried this again with the DMM turned right off, and it still worked.
I figured I was adding some capacitance to the circuit.
Then I exposed the guts of the lamp. There are three circuit boards, one for each bulb, each including a transformer, several power transistors, and inductor, and a bunch of capacitors. I figure this circuitry is all in aid of running the fluorescent bulbs. Furthermore, the tantalum caps look to be darkened - they don't look healthy. I'm wondering whether the LED bulbs (rated at 15 W each) somehow damaged the circuitry (designed for fluorescents, rated at 36 W each). [P = IV. I = P/V. I = 15 W/120 V = 0.125 A. I = 36 W/120 V = 0.3 A. On this basis, it's not like the LED bulbs would draw too much current. Perhaps not enough?]
Given that the LED bulbs are rated for an input of 100 - 277 VAC, I am tempted to bypass the fluorescent circuit boards, wiring the 120 VAC inputs directly to the receptacles for the LED bulbs. (I would keep the ON/OFF switch in the circuit of course.)
There's a simple diagram on each of the LED bulb assemblies, showing an input of 100 - 277 VAC across the L and N terminals.
Does anyone see a downside to this? At this point I could put the two working fluorescent bulbs back in, and run the lamp until they give out, and eat the cost of the new LED bulbs. But at some point they'll give out as well. It might be possible to get new fluorescent bulbs though. But once I start modifying the lamp, it will be hard to go back. Perhaps I should rig up a way to run 120 VAC directly to the prongs on one LED bulb only, to see if it works.
Thanks in advance. I can take photos if this is hard to visualize.
Re: LED replacement bulbs don't work in a fluorescent lamp [Re: Number_35] #5278453 11/26/19 10:29 PM
J
Jethro_Bob Offline
J
Do you have a part number for the new bulbs? Or even just a link to the product page?
Edit: I did a quick search, it seems some leds are direct wire but not necessarily all of them can be directly wired.
Re: LED replacement bulbs don't work in a fluorescent lamp [Re: Jethro_Bob] #5278459 11/26/19 10:40 PM
JB, the part number is VPLT-15W2G10. I don't know who the manufacturer is - I thought Intertek, but that appears to be a standards [censored]'n rather than the manufacturer. I'll try to post some photos tomorrow.
Re: LED replacement bulbs don't work in a fluorescent lamp [Re: Number_35] #5278631 11/27/19 07:55 AM
A
alarmguy Offline
A
There are two types of replacement LED light bulbs/tubes.
1. One type allows you to use the ballast already in the fixture from the Fluorescent light.
2. One type requires you to remove the ballast. I chose to purchase the LED replacements that require I remove the ballast simply because a ballast isnt needed and an additional energy waste. Not only that, it was developed for Flourescent Lighting and I am now putting in LED tubes.
You need to be aware of this when purchasing in order to select the right type.
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: LED replacement bulbs don't work in a fluorescent lamp [Re: Number_35] #5278644 11/27/19 08:09 AM
V
vwmaniaman Offline
V
I just converted the kitchen lights at both our homes to LED and my wife's sewing and art room to LED. The bulbs I purchase at Home Depot and Walmart and the 8ft tubes were purchased on ebay. The one from HD say to wire them for direct outlet power and to remove the ballast. Also on the 8' bulbs from ebay. The Wally world ones only work with a ballast and then only some ballasts. I tried them in our kitchen light and they would run for maybe 45 min and shut off. Some ballasts don't work with them. Other house kitchen has a 4 X4 foot unit and they work there just fine. There needs to be some better info on these bulbs about their power requirements. The average Joe won't figure out why what he bought refuses to work.
Don't waste your time on a slipshod repair.
Re: LED replacement bulbs don't work in a fluorescent lamp [Re: vwmaniaman] #5278656 11/27/19 08:19 AM
A
alarmguy Offline
A
Yes, I agree, people think all they have to do is buy the equal in an LED and they dont know there are two types.
For anyone comfortable, without question, the way to go is remove the ballast, its not needed or used for LED unless you buy a special LED build that will work with it.
Key is to check labeling on the package and maybe part number on manufacturers website, in order to know what you bought.
07 Suzuki C50
Re: LED replacement bulbs don't work in a fluorescent lamp [Re: alarmguy] #5278665 11/27/19 08:29 AM
H
hallstevenson Offline
H
I thought all of them required bypassing (or removing) the ballast and just hard-wiring them.
Re: LED replacement bulbs don't work in a fluorescent lamp [Re: Number_35] #5278833 11/27/19 12:05 PM
Propflux01 Offline
There are two types of LED bulbs used once the ballast is removed. One is wired at one end of the bulb only, the other requires one wire on one side, one on the other.
2014 Hyundai Elantra
2014 Hyundai Elantra GT
A 55 Gallon Drum And A Shovel Can Solve A lot of Life's Little "Problems"
Re: LED replacement bulbs don't work in a fluorescent lamp [Re: Number_35] #5278856 11/27/19 12:45 PM
Here are some photos:
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
Re: LED replacement bulbs don't work in a fluorescent lamp [Re: Number_35] #5278901 11/27/19 01:33 PM
Guys, it's all moot. I opened up the three LED bulbs, and the electronics are smoked. A capacitor on each circuit board has split open and barfed out its contents. I now have three expensive pieces of e-waste. GRRRR! If I'd known the electronic ballasts had to be removed from the lamp first, I would have done so. There were no separate instructions supplied. As you can see in the last photo, the instructions listed on the bulb's heat sink are a bit vague. I'll reinstall the fluorescent bulbs, and replace the lamp at some point, ensuring that it comes with LEDs.
Re: LED replacement bulbs don't work in a fluorescent lamp [Re: hallstevenson] #5278937 11/27/19 02:24 PM
E
exranger06 Offline
E
Nope. Some LEDs MUST have the ballast still installed and working, others require removing the ballast. And then there's a third type of LED: The "hybrid" tube, which can work with or without a ballast. I have these in my garage. One fixture still has the ballast installed, the other doesn't. Both fixtures have the same LED tubes. I'll be removing the other ballast soon, since it recently started making this annoying ringing sound when I turn it on.
2006 Ford Ranger Sport
1992 Honda Accord EX
2013 Toyota Sienna XLE AWD
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: LED replacement bulbs don't work in a fluorescent lamp [Re: Propflux01] #5278948 11/27/19 02:32 PM
E
exranger06 Offline
E
That's another good point. T8 fluorescent tubes typically use shunted sockets, which you cannot use with single-end power LEDs. If you're retrofitting a T8 fixture, you need to either use double-end power tubes, or replace the sockets with non-shunted ones. T12 fluorescent tubes typically use non-shunted sockets, so you can easily convert to single or double end powered LEDs.
Re: LED replacement bulbs don't work in a fluorescent lamp [Re: Number_35] #5278958 11/27/19 02:40 PM
M
Miller88 Offline
M
I'm not sure what your options are in Canada, but here in NY , you can get LED grow lights.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: LED replacement bulbs don't work in a fluorescent lamp [Re: Number_35] #5279637 11/28/19 10:13 AM
A
alarmguy Offline
A
Oh good luck to you on that one my past post I was thinking they were standard fluorescent tubes such as t5, t8 ect
07 Suzuki C50
