102 registered members (53' Stude, 97prizm, 2015_PSD, 4WD, AndyB, 69 Riv GS, 10 invisible),
2,751
guests, and 65
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,407
Posts5,134,846
Members70,059
Most Online3,589 Nov 2nd, 2019
DIY Trans Fluid change on Toyota vehicles.
#5278308
11/26/19 07:40 PM
laserred96gt
OP
OP
Posts: 1,011 |
What method are DIYers here on bitog using to change the transmission fluid on sealed toyota vehicles, Please post any specific video or instructions you are using and how is it working for you so far ?? Is the exact amount of fluid/temperature as critical as some make it sound ?? Thanks guys.
2017 4Runner Limited, 50k 04 E-150, 4.6, 240K, Synblend 5w20. 11 Camry 2.5, 70K, PU 5w20.
Re: DIY Trans Fluid change on Toyota vehicles.
[Re: laserred96gt]
#5278325
11/26/19 07:54 PM
cpayne5
Posts: 833 |
Drain, measure, refill with the same amount.
I've done it a few times across my two 4Runners and Sequoia. All good.
I've also gone to the trouble of getting the trans up to temp and checking the fluid level the proper way as well. It made me feel good, but not sure it was worth the additional trouble over the first method.
[Re: laserred96gt]
#5278327
11/26/19 07:55 PM
working_title
Posts: 18 |
I've done a few sealed ZF transmissions and an Aisin A750E. I use a thermal imaging camera and a helper to read pan temperature while filling while the car is running, but I would be comfortable using the laser thermometers you can get for cheap. I pump as much fluid in as I can in until it won't hold, then start the vehicle and keep pumping until the temperature is pretty close and the fluid runs out.
At this point I've put 70,000+ miles on those transmissions (combined) and never had any issues. I like to change transmission fluid at around 60-70k miles, which has been the mileage when I've bought those cars.
My only problem with the A750E was that it has a mind of its own that would never hold gears when you wanted it to. The programming was absolutely horrible and by far the worst of any automatic transmission I've owned. Most cars I can control shift points with throttle application after some practice, that one after 2 years I still couldn't figure out.
'15 F150 3.5 Ecoboost Havoline Pro DS 5w-30 '13 335iX (N55) Castrol 0w-40 '10 135i (N54) Castrol 0w-40
[Re: laserred96gt]
#5278351
11/26/19 08:22 PM
Chris142
Posts: 19,878 |
I used to do it by temp and such. Lately I have been draining 3qts out and dumping in 3 qts I use that pump that critic sent me to pump it back in.
02 Wrangler Napa high milage 10w40 87 F250 Valvoline 15w40 07 fjcruiser Car lube plus 10w30 Z400 castrol T 10w40 Can am Maveric edge 5w40 57 case tractor Chevron sae30
[Re: laserred96gt]
#5278388
11/26/19 09:05 PM
ford46guy
Posts: 578 |
I know my lexus has a mode that tells you when the temperature is right. You have to jumper pins on the OBD port. Plan B is a cheap ($20-$30) techstream. It gives you temp. I hear the pan temp method isn't accurate.
95 Tbird V8 240K PP SYNTH ULTRA 5W30 98 MGM 160K M1 HM 5W20 96 Explorer EB V6 159K PP SYNTH HM 5W30 95 Conti 155K MC 5W20 11 GS350 90K PP HM 5W30
[Re: laserred96gt]
#5278391
11/26/19 09:08 PM
Supersonic
Posts: 62 |
Pan and filter is same as any, an offset wrench works good if you have and tight space around the frame areas as in a Camry or Sienna. This one is good for the flush, if not sure of witch is the return line, open the easiest first, tube both ends to a drain bucket, if it come out from the radiator side, you've got the return line, proceed, if not, do the other line, as you will want to be sure not to pump the dirty fluid from the radiator back into the transmission. 2009 Toyota Sienna Transmission Fluid Flush and Filter ChangeOne other point, there is a spec for fluid replacement when valve body is replaced, that should be very close to the volume you'll want to add back in. Finding that spec isn't easy, but it is out there. For 2005 4Runner ~4.3 quarts, if I remember right.
[Re: laserred96gt]
#5278431
11/26/19 09:55 PM
exranger06
Posts: 4,304 |
I just did a trans service on my Sienna a few weeks ago. I got the transmission to the proper temp to refill. I monitored the temp with a Bluetooth OBD2 adapter and the Torque Pro app. There is also a way to get the car into a "service mode" and it will indicate on the instrument cluster when it gets to the proper temp. I haven't used that method yet though. If you use the Torque app, you need to add a custom PID to read ATF temp. The ATF temp PID that's already in the app does NOT work. It simply displays the engine coolant temp instead. You need the custom PID for the real ATF temp. Adding the custom PID is pretty easy. It consists of filling out some fields in the app with a bunch of computer programming gibberish. I found the info online that told me what to enter in each field.
When filling the transmission, it not only needs to be at the correct temperature, but the engine also has to be idling in park. If you fill it to the "correct" level with the engine off, it'll be about a quart too low.
2006 Ford Ranger Sport 1992 Honda Accord EX 2013 Toyota Sienna XLE AWD 1994 Ford Bronco XLT (project) 2011 Cadillac Escalade ESV (wife's)
[Re: exranger06]
#5278715
11/27/19 09:39 AM
diyjake
Posts: 723 |
When filling the transmission, it not only needs to be at the correct temperature, but the engine also has to be idling in park. If you fill it to the "correct" level with the engine off, it'll be about a quart too low. I also have the Torque Pro App, can you please share how you were able to rear the AT temps?
[Re: diyjake]
#5278926
11/27/19 02:07 PM
exranger06
Posts: 4,304 |
When filling the transmission, it not only needs to be at the correct temperature, but the engine also has to be idling in park. If you fill it to the "correct" level with the engine off, it'll be about a quart too low. I also have the Torque Pro App, can you please share how you were able to rear the AT temps? Yes. I took some screenshots; you can see them below. Go to Settings, Manage Extra PIDs/Sensors, then Add Custom PID. Then add the info in the screenshots to the appropriate fields: ![[Linked Image]](https://www.bobistheoilguy.com/forums/attachments/usergals/2019/11/full-19143-38690-screenshot_20191127_145910_torque.jpg)
[Re: laserred96gt]
#5278967
11/27/19 02:56 PM
Leo99
Posts: 4,250 |
Use Car Scanner ELM OBD2. It's free and has and will read Toyota tranny temp out of the "box". Just tell it Toyota sensors instead of generic.
I don't see any reason to mess with temperatures. Just have your car and jug of new ATF at ambient temperature and replace same volume you removed.
The hard part is getting the new fluid in the fill hole.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP) 2004 Corolla 125,000 miles 2004 Rav4 392,000 miles 2015 Camry 90,000 miles
[Re: laserred96gt]
#5278974
11/27/19 03:05 PM
exranger06
Posts: 4,304 |
Any time I need to pump fluid into a transmission, differential, etc, I use a Valvoline 818 pump. Available at Napa. https://www.napaonline.com/p/VAM818![[Linked Image from m.media-amazon.com]](https://m.media-amazon.com/images/S/aplus-media/sc/5279882e-0d80-4cde-b635-ff70407982bc.__CR0,0,4042,2500_PT0_SX970_V1___.jpg)
[Re: exranger06]
#5279171
11/27/19 06:43 PM
N Heat
Posts: 180 |
When filling the transmission, it not only needs to be at the correct temperature, but the engine also has to be idling in park. If you fill it to the "correct" level with the engine off, it'll be about a quart too low. I also have the Torque Pro App, can you please share how you were able to rear the AT temps? Yes. I took some screenshots; you can see them below. Go to Settings, Manage Extra PIDs/Sensors, then Add Custom PID. Then add the info in the screenshots to the appropriate fields: Thanks. I just ordered a bluetooth scanner and will download torque pro.
[Re: laserred96gt]
#5279398
11/28/19 02:18 AM
Youthanasia
Posts: 77 |
Is350, I drain 4 QT and refill. Do it when car has been on ramps all night and new fluid in garage so they're both the same temp then you don't have to worry about it since you just replace what you took out.
