Now this is a good job.....
by ZZman - 12/15/19 09:26 AM
Polish snow plow
by P10crew - 12/15/19 08:53 AM
Scary winter drive helping gf's dad pick up new van
by caprice_2nv - 12/15/19 07:53 AM
Royal Purple Max-Tane
by RogerBacon - 12/15/19 07:32 AM
Mixing oil
by DerekPho - 12/15/19 03:03 AM
Grease plus Gear Oil
by PumpPusher - 12/15/19 12:59 AM
Costco/Kirkland 5qt-2pack synthetic $29.99
by wgtoys - 12/14/19 10:31 PM
Mercedes delays EV release
by JeffKeryk - 12/14/19 09:33 PM
Retired. Dreams are of work...
by rekit - 12/14/19 08:19 PM
Silly to charge a brand new battery?
by jayjr1105 - 12/14/19 08:06 PM
Help me pick a tire for our Volvo
by Ddub - 12/14/19 07:10 PM
Porter Cable 12V Batteries
by bcossa2001 - 12/14/19 06:52 PM
LG Red and Bio EP at Amazon
by demarpaint - 12/14/19 06:51 PM
2-stroke oil choices
by dnewton3 - 12/14/19 05:29 PM
Do cats like potato chips?
by atikovi - 12/14/19 03:45 PM
Buying a cheap, beater bicycle
by Oldtom - 12/14/19 03:14 PM
Metabo/Hitachi Impact driver $50
by Deere John - 12/14/19 03:03 PM
Ate up camshaft.pics
by Chris142 - 12/14/19 02:57 PM
Caprice cam swap. :)
by ls1mike - 12/14/19 02:55 PM
Maik, Pluckster, DerekPho, mikinko, merrittgene
70129 Registered Users
96 registered members (40Deluxe, alarmguy, Ag76, 77GrandPrix, 2015_PSD, 7 invisible), 1,752 guests, and 15 spiders.
Topics298,824
Posts5,142,059
Members70,129
Most Online3,589
Nov 2nd, 2019
P0452 dodge dart #5278275 11/26/19 06:54 PM
R
ram_man Offline OP
R
A couple weeks ago my dart fell on its face on take off right after getting gas. Misfired half a dozen times after that and then was fine and has been fine. Today it threw a cel for p0452 and died in a drive through fired back up took
Off backfired once and died when I stopped again. I had to give the car gas to get it to start. Then tonight it was fine again but the cel is still on. Does anyone have any ideas? I couldn’t find much about this code with this car in particular. It’s a evap pressure sensor code.
2014 dodge dart GT
1995 Dodge ram 1500
Re: P0452 dodge dart [Re: ram_man] #5278280 11/26/19 07:04 PM
J
JeffKeryk Online Content
Online Content
J
My understanding is the #1 reason for an evap check engine code is the gas cap.
It can be the cap itself or simply not tightened correctly after a fill up.
This did happen on my folks perfect 1998 Accord LX 4 banger. A new gas cap, like $4, did the trick.
I cleared the code and 1,000 miles later all is good.
The only other time I dealt with an evap code was in my 2001 Tundra; there was a cracked hose to one of the components.
Super easy fix.
It sounds like your error code is pointing to a sensor, so your solution could easily be different.
Good luck.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: P0452 dodge dart [Re: ram_man] #5278281 11/26/19 07:04 PM
Astro14 Offline
Poor running and low evap pressure (P0452) sounds like a vacuum leak to me...
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: P0452 dodge dart [Re: ram_man] #5278295 11/26/19 07:21 PM
M
mattd Online Content
Online Content
M
Just a guess but I would say your canister purge solenoid is stuck open. Do you hear a hiss noise from the fuel fill hole if you unscrew the gas cap while the car is running?
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1
Re: P0452 dodge dart [Re: ram_man] #5278296 11/26/19 07:24 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Does the evaporation system connect to the vacuum system on that car?
On my old 318i, any slight leak - breather hose, oil filler cap, dipstick, etc., would cause a major air leak and the car would barely run if at all, and needed a lot of throttle to keep it going. An inadvertently disconnected breather hose from the intake trunk taught me that...
Gas cap is obvious, but this seems more severe. Did the pump overfill? Maybe something got logged with excess fuel?
Re: P0452 dodge dart [Re: ram_man] #5278337 11/26/19 08:05 PM
T
tiger862 Offline
T
P0452 DODGE Possible Causes
Faulty Evaporative Emission System (EVAP) Pressure sensor
EVAP purge hose/tube obstruction
Evaporative Emission System (EVAP) Pressure sensor harness is open or shorted
Evaporative Emission System (EVAP) Pressure sensor circuit poor electrical connection.
Tiger862
2018 Grand Caravan
Re: P0452 dodge dart [Re: ram_man] #5278348 11/26/19 08:18 PM
R
ram_man Offline OP
R
Any idea where the pressure sensor is?
2014 dodge dart GT
1995 Dodge ram 1500
Re: P0452 dodge dart [Re: JHZR2] #5278353 11/26/19 08:23 PM
M
Online Content
M
The purge solenoid is usually directly connected to the intake manifold
If the solenoid is stuck open it will pull a constant vacuum on the entire evaporate emission system, including the fuel tank. The first thing the ecm usually picks up on are incorrect data from the pressure sensor
ASE Master, L1
Re: P0452 dodge dart [Re: ram_man] #5278386 11/26/19 09:00 PM
T
tiger862 Offline
T
If I am not mistaking it is on fuel tank
I do know Dodge has reprogrammed PCM for this code on other vehicles.
Tiger862
2018 Grand Caravan
Re: P0452 dodge dart [Re: ram_man] #5278448 11/26/19 10:12 PM
saginawmale50 Offline
Dont fill it up all the way, keep it a gallon or two from the top. Run a few tanks like that . 3rd tankful, fill it up all the way and if it stalls and sputters, its the evap pressure sensor.
Re: P0452 dodge dart [Re: saginawmale50] #5278449 11/26/19 10:15 PM
R
ram_man Offline OP
R
Both times it has acted it up was right after we filled it up ironically enough.
2014 dodge dart GT
1995 Dodge ram 1500
Re: P0452 dodge dart [Re: ram_man] #5278591 11/27/19 06:54 AM
CourierDriver Offline
Dodge Darts, since 1960
I'd still like to have my 67 Beetle back....life was easy then..imho 2 quarts of oil roughly ,lol
Re: P0452 dodge dart [Re: ram_man] #5278619 11/27/19 07:40 AM
M
mk378 Offline
M
Patient: "Doctor, it hurts when I do this" [raising his right arm over his head].
Doctor: "Well then don't do that."
Re: P0452 dodge dart [Re: CourierDriver] #5278626 11/27/19 07:52 AM
PimTac Offline
They did fix the engine stalling on left hand turns though with the advent of fuel injection.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: P0452 dodge dart [Re: ram_man] #5278732 11/27/19 09:50 AM
R
ram_man Offline OP
R
I am leaning towards an esim problem so I ordered a replacement for $29 hopefully I’m right!
2014 dodge dart GT
1995 Dodge ram 1500
