Chasing down a brake issue
by HawkeyeScott - 12/11/19 07:14 PM
Total Quartz 9000 Energy 5w40
by BurntMusic - 12/11/19 06:53 PM
Mazda 3 i-ACTIV AWD diagonal test
by buster - 12/11/19 05:35 PM
Tires or Toyota ABS
by ford46guy - 12/11/19 05:33 PM
RV chase straight out of the Movies
by KeithS_NW_Ohio - 12/11/19 04:56 PM
Will the octane change?
by Mar57 - 12/11/19 04:45 PM
DIY brake lines help
by LeakySeals - 12/11/19 04:20 PM
random misfire code but not missing
by bowlofturtle - 12/11/19 03:31 PM
Pressure washing Santa Fe clay tile
by henni - 12/11/19 02:55 PM
Confused. Mercon V or Dexron VI?
by AcadiaDave - 12/11/19 02:33 PM
Sooty Oil in Ford Focus
by RW1 - 12/11/19 02:27 PM
oil sample shelf life?
by novadude - 12/11/19 12:51 PM
whoa!!walmart ammo clearance
by joel95ex - 12/11/19 11:56 AM
Carpro Reset
by BeerCan - 12/11/19 10:46 AM
Come on China. Let's get it right.
by Chris142 - 12/11/19 10:34 AM
'best' conventional 10w-40 pcmo for wet clutch bike
by kmrcstintn - 12/11/19 10:32 AM
Any reason not to use Carquest full synthetic?
by wbwanzer - 12/11/19 10:18 AM
TyMillerfc, AcadiaDave, lmt1911, m14308, MyFirstNamePaul
70104 Registered Users
117 registered members (14Accent, alarmguy, alcyon, 69Torino, 40Deluxe, ammolab, 10 invisible), 1,792 guests, and 30 spiders.
Topics298,593
Posts5,138,816
Members70,104
Most Online3,589
Nov 2nd, 2019
Appropriate oil for old Volvo #5278204 11/26/19 05:44 PM
N
Nels3 Offline OP
N
I'm driving a 1992 Volvo 240GL with 215K miles on it and am considering switching to a high mileage oil. I'm gonna guess that I burn through a quart between 500 and 1000 miles. When I used the "Find the right oil" link on the Mobil website, it selected Mobil Super Synthetic Euro 5W-40 (only viscosity offered) although it doesn't seem to be available when I search online. I've never used synthetic oil in my car and read that it could possibly cause leaks instead of fixing them. Is it safer to go with a non-synthetic high mileage oil? And viscosity? I live in New York City so we don't get super cold here (might drop to single digits on a couple of winter nights) on rare occasions) or hellishly hot (rarely breaks 100 degrees). Any suggestions would be welcome. Bill
Re: Appropriate oil for old Volvo [Re: Nels3] #5278208 11/26/19 05:47 PM
Astro14 Offline
welcome
Any A3/B4 European rated oil would be fine. 5W30 would be fine. 0W30 would be fine. 0W40 would be fine. Synthetic would be fine. If your car leaks, then it was because the seals were worn, not because "synthetic leaks".
I would go with this: https://www.amazon.com/Castrol-03101-0W-40-Advanced-Synthetic/dp/B00JGQLZSU
Castrol Edge 0W40, A3/B4 rated. MB 229.5 rated (not that you care, but a good specification/approval). $25/jug on Amazon. You won't find a better oil and the 0W will help you on those cold nights that you do have in New York. Great oil for year-round use.
My wife's XC (with over 250,000 miles on it) saw a drop in oil consumption with the Castrol 0W40 vs. other oil brands in similar weights.
Check your flame trap - a sludged up/clogged flame trap will drive up oil consumption in an old Volvo.
Cheers!
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Appropriate oil for old Volvo [Re: Nels3] #5278218 11/26/19 05:59 PM
M
MParr Offline
M
Just about any 10W30 will do just fine.
2019 VW Tiguan SE Now: Castrol Professional OE LL IV 0W20 & OE VW/Mann
2017 Ford Escape SE 2.0T Now: Motorcraft 5W30 SynBlend & NAPA Gold 1348
Re: Appropriate oil for old Volvo [Re: Nels3] #5278220 11/26/19 06:01 PM
Passport1 Offline
I've been driving a Volvo 940 for almost 18 years. It has the same engine as yours except it has a turbo. The red block Volvo engines are very tolerant of oil choices. If your engine is using that much oil you ought to check the oil separator. It is the Volvo version of a PCV. If it is clogged it can cause excessive engine blow by which will increase oil consumption. These engines are very stout.
Your engine will do fine on any conventional 10W-30 or 10W-40 oil. Synthetic will not cause leaks but is not necessary. I'd recommend you use Volvo or Mann filters. They are easy to get on ebay or e.euro.
Other's might disagree but I think any descent 240/740/940 will soon be an appreciating car.
1992 940 Volvo turbo 320K
2006 Saab 9-3 86k
2007 Suzuki Burgman
2012 Suzuki Kizashi
Re: Appropriate oil for old Volvo [Re: Passport1] #5278268 11/26/19 06:51 PM
L
Lolvoguy Offline
L
I concur.
I think the 1986 Buick Skylark is the one to watch out for.
It's generic lines that resemble most of GM's N-body from that time, paired with forgettable handling and abysmal fit and finish will also be in high demand.
coffee
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Appropriate oil for old Volvo [Re: Nels3] #5278319 11/26/19 07:51 PM
A
Audios Offline
A
10/30 or 10/40 will be fine. Rotella T5 semi syn is 17$ a gallon for their 10/30 on amazon, sometimes cheaper with sales and rebates.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: Appropriate oil for old Volvo [Re: Nels3] #5278361 11/26/19 08:29 PM
A
Astro_Guy Online Content
Online Content
A
If I recall, I was using Mobil1 10w-30 back in the day with my 1988 240 DL Wagon. Were I still driving that car, I think that Mobil1 10w-30 high mileage might be my go to oil, that or the Castrol Edge 0W40 Astro14 recommends. Those red block 2.3 liter I4s will go forever if properly maintained.
'01 Volvo V70XC, 247k, 5W-30 M1 EP
'16 Accord, 45k, 0W-20 M1 EP
Re: Appropriate oil for old Volvo [Re: Nels3] #5278797 11/27/19 11:22 AM
Sam_Julier Offline
Any oil that meets the A3/B3, A3/B4 spec, any viscosity. I'd shy away from 10W40 in the winter.
2013 Toyota Avalon Hybrid TGMO 0W20, 75k
1993 Volvo 245 T5 10W30, 168k
1993 Volvo 244 T5 10W30, 175k
Re: Appropriate oil for old Volvo [Re: Nels3] #5282474 12/01/19 10:52 PM
N
Nels3 Offline OP
N
Thanks for all the suggestions. The Edge 0W-40 Advanced Full Synthetic is probably a great oil but wouldn't a high-mileage oil have more in the way of sealing properties (I have well over 200K on my Volvo).
Re: Appropriate oil for old Volvo [Re: Nels3] #5282509 12/02/19 12:16 AM
dave1251 Offline
Delo 400 XLE SAE 10W-30
don't use.
Re: Appropriate oil for old Volvo [Re: Nels3] #5282540 12/02/19 02:49 AM
SR5 Offline
In Australia people run 15W40 mineral or 10W40 semi-synthetic in those cars.
For you I would suggest
Summer: Rotella 15W40 mineral
Winter: 10W40 like GTX or PYB
A 10W-x oil is good down to 0F, so you are OK for winter
Ideally an A3/B3 or A3/B4 mineral oil like we have in Australia, but I don’t think you get mineral A3 oil in the States, only synthetic, and that car doesn’t need synthetic (but it shouldn’t hurt). So an API SN 10W40 should do you, as long as you don’t go too long on the oil change interval (OCI). I would be fine with 5k miles.
Old army mate of mine was a Volvo collector, just after my son was born, my only car broke. So my mate gave me his turbo version of that car to keep me mobile until my car was fixed. Good guy and good car.
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: Appropriate oil for old Volvo [Re: Nels3] #5282748 12/02/19 10:03 AM
I
I_4 Offline
I
The 1990 240 in my signature has over 230k. It gets Valvoline Max Life red bottle (semi-syn) 5w-30 in winter. Summer run it gets the same except 10w-30. So twice a year changes. Uses about one quart about every 6k, sometimes less. Leaks no oil. The red blocks are not fussy with oil, IMHO. Good, stout engines that has not given me a hint of any internal noises or issues. Check your flame trap.
2007 BMW 328 Ams Euro 5W-40
2005 Honda Civic Si EP3 Ams Sig 5W-30
2000 Mazda B3000 (winter)
1992 Mazda Miata (summer/HPDE) Ams Z-Rod 10W-30
1990 Volvo 240DL
Re: Appropriate oil for old Volvo [Re: Nels3] #5282801 12/02/19 10:52 AM
K
ka9mnx Offline
K
When I had my POS 90's Volvo wagon the OM didn't list grade but said to use A3/B3. At the time, I used Mobil1 5w-40.
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Appropriate oil for old Volvo [Re: Nels3] #5282950 12/02/19 01:30 PM
A
aquariuscsm Offline
A
An old neighbor of ours had a Volvo from maybe the 80s? It said “Castrol 20W-50” on the oil cap.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 0W20
Re: Appropriate oil for old Volvo [Re: Nels3] #5282957 12/02/19 01:37 PM
Doublehaul Offline
Ill throw it out there...15w40. Supertech is the most cost effective and very good. Rotella conventional same same but $5 more a jug
2019 Toyota 4Runner 4x4 TRD
2019 Toyota Tacoma 4x4 TRD*
Mobil 1 0w40
The specs on the back are more important than the label on the front
