New Mercedes Ute
by Shannow - 01/25/20 03:04 AM
A decent battery charger for sub $50?
by michaelluscher - 01/25/20 02:03 AM
Temperature swing affects on oil
by leeaspell - 01/25/20 12:58 AM
Coefficient of Friction
by jrommelt - 01/24/20 11:46 PM
2017 Chevy Cruze Diesel Oil
by Ponch - 01/24/20 11:03 PM
electric motor amp rating
by motor_oil_madman - 01/24/20 10:42 PM
Radio, Instrument panel, display, AC cutting off
by DrDanger - 01/24/20 09:39 PM
Filter Brand Quality Change?
by BBDartCA - 01/24/20 09:21 PM
Autozone $7 off $30
by GMguy84 - 01/24/20 09:17 PM
Honda Power Steering Fluid
by shortlid - 01/24/20 09:14 PM
Autozone Clearance 2020 M1EP
by GMguy84 - 01/24/20 09:11 PM
Spark Plugs
by A_Spruce - 01/24/20 09:00 PM
Flank drive wrenches
by spasm3 - 01/24/20 08:39 PM
Auto assembly and mfg. logistics
by P10crew - 01/24/20 08:26 PM
Kodiak
by P10crew - 01/24/20 08:05 PM
yet another black eye for the 2,4 ecotec
by super20dan - 01/24/20 07:52 PM
New incentive for 0w20
by Snagglefoot - 01/24/20 06:43 PM
Pete44, Connie7, 2020XT, 4strokes, Perseus
70518 Registered Users
27 registered members (bbhero, ctechbob, brian, Bookmaker, Black_Thunder, 4 invisible), 1,734 guests, and 16 spiders.
Topics300,519
Posts5,177,626
Members70,518
Page 1 of 4 1 2 3 4
Full Synthetic Oil made from Natural Gas #5277961 11/26/19 01:17 PM
sdowney717 Offline OP
First time I have bought a bunch of oil where it mentions made from NGas.
Does this make it more pure. Are they condensing the gas and finding oil in what comes out of a well.
Seeing it is a full synthetic, I guess not, it must be transformed in some way.
Years ago I heard they can turn NGas into gasoline too.
Re: Full Synthetic Oil made from Natural Gas [Re: sdowney717] #5277962 11/26/19 01:21 PM
https://www.prnewswire.com/news-rel...oil-made-from-natural-gas-255519821.html
Yes, what I got is Pennzoil
Platinum Euro vs Platinum Euro LX is some of the AZ half priced oil I bought, what is the difference versus LX?
Re: Full Synthetic Oil made from Natural Gas [Re: sdowney717] #5277977 11/26/19 01:32 PM
P
paoester Offline
P
"Finished motor oil. Primarily isoparaffinic in nature and up to 99.5% free of sulfur and nitrogen impurities, Shell’s GTL base oils have beneficial properties such as high viscosity indices, good oxidation stability, low volatility and good cold flow properties. The base oils are then blended with high-performing additives, such as active cleansers, to produce finished motor oils." is the best way to explain it.
Its almost as good as Group4 PAO base oil. Nice stuff.
----- For more very boring details about what it is: http://gasprocessingnews.com/featur...es-clean-base-oils-from-natural-gas.aspx
Re: Full Synthetic Oil made from Natural Gas [Re: paoester] #5277987 11/26/19 01:40 PM
Nice, this was also mentioned in diesel engine testing,
" Similar to motor oil formulations, significant improvement in piston cleanliness was observed."
Which Is what I have also read, the engine internals stay significantly cleaner with a GTL (gas to liquid) oil.
Re: Full Synthetic Oil made from Natural Gas [Re: sdowney717] #5278041 11/26/19 02:37 PM
ChrisD46 Offline
Being a SOPUS company - would it be safe to assume QSUD also makes use of GTL base stocks deriving from Natural Gas ?
'17 Hyundai Sonata 2.4L GDI 5W20 QSUD / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
Re: Full Synthetic Oil made from Natural Gas [Re: ChrisD46] #5278045 11/26/19 02:41 PM
Only if it is marked on the bottle like Pennzoil is. They won't let that slip by, as its a plus for the consumer demand.
Re: Full Synthetic Oil made from Natural Gas [Re: sdowney717] #5278048 11/26/19 02:44 PM
Re: Full Synthetic Oil made from Natural Gas [Re: sdowney717] #5278050 11/26/19 02:45 PM
PimTac Offline
It’s the Fischer Tropsch process. It has been around for decades.
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: Full Synthetic Oil made from Natural Gas [Re: sdowney717] #5278053 11/26/19 02:47 PM
K
kschachn Offline
K
I’m not sure why they would have to put it on the bottle, it’s still Group III basestock although it will have a different C.A.S. number on the SDS.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Full Synthetic Oil made from Natural Gas [Re: sdowney717] #5278079 11/26/19 03:13 PM
M
Mad_Hatter Offline
M
They technically can (interchange base oils) but do/would they, dunno?? Call SOPUS and ask them. Could be changing the website info/PDS/TDS/SDS and printing up new labels with new artwork may not be worth the trouble and serve more to confuse loyal QS customers who aren't accustomed to seeing some fancy shmancy "GTL" on their trusted "dino" lube.😉
Re: Full Synthetic Oil made from Natural Gas [Re: sdowney717] #5278165 11/26/19 04:49 PM
R
RamFan Offline
R
Wait, you got PP Euro LX 0w-30 for $2/qt???
18 Giulia Ti Sport Q4
  • 2.0T I4 - 22k - PP Euro LX 0w30 - PureOne - 10k/1yr
16.5 CX-5 Touring AWD
  • 2.5L I4 - 67k - Castrol Edge EP 0w20 - Denso - 7.5k/1yr
Re: Full Synthetic Oil made from Natural Gas [Re: sdowney717] #5278192 11/26/19 05:29 PM
skyactiv Offline
Didn't SOPUS make some conventional oils in a few weights using a GTL base oil? Because the NOACK in a few of the older PQIA test showed typical GTL numbers?
It's probably not the case today.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Full Synthetic Oil made from Natural Gas [Re: sdowney717] #5278211 11/26/19 05:49 PM
sloinker Offline
The larger question is what percentage of the whole is GTL in the bottle, is it something akin to semi-synthetics of yesteryear?
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Full Synthetic Oil made from Natural Gas [Re: skyactiv] #5278261 11/26/19 06:41 PM
B
bbhero Online Content
Online Content
B
You are correct....
Nissan Altima 3.5 Coupe
Cam2 full synthetic 5w30 Wix 57356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Full Synthetic Oil made from Natural Gas [Re: RamFan] #5278263 11/26/19 06:42 PM
Yes, AZ clearance and 10$ for the 5L bottles.
This is what I picked up.
Page 1 of 4 1 2 3 4
