Total Quartz 9000 Energy 5w40
by BurntMusic - 12/11/19 06:53 PM
Mazda 3 i-ACTIV AWD diagonal test
by buster - 12/11/19 05:35 PM
Tires or Toyota ABS
by ford46guy - 12/11/19 05:33 PM
RV chase straight out of the Movies
by KeithS_NW_Ohio - 12/11/19 04:56 PM
Will the octane change?
by Mar57 - 12/11/19 04:45 PM
DIY brake lines help
by LeakySeals - 12/11/19 04:20 PM
random misfire code but not missing
by bowlofturtle - 12/11/19 03:31 PM
Pressure washing Santa Fe clay tile
by henni - 12/11/19 02:55 PM
Confused. Mercon V or Dexron VI?
by AcadiaDave - 12/11/19 02:33 PM
Sooty Oil in Ford Focus
by RW1 - 12/11/19 02:27 PM
oil sample shelf life?
by novadude - 12/11/19 12:51 PM
whoa!!walmart ammo clearance
by joel95ex - 12/11/19 11:56 AM
Carpro Reset
by BeerCan - 12/11/19 10:46 AM
Come on China. Let's get it right.
by Chris142 - 12/11/19 10:34 AM
'best' conventional 10w-40 pcmo for wet clutch bike
by kmrcstintn - 12/11/19 10:32 AM
Any reason not to use Carquest full synthetic?
by wbwanzer - 12/11/19 10:18 AM
53k miles on a Ford FA-1927
by BeerCan - 12/11/19 09:53 AM
TyMillerfc, AcadiaDave, lmt1911, m14308, MyFirstNamePaul
70104 Registered Users
113 registered members (alarmguy, alcyon, 69Torino, 40Deluxe, ammolab, Aero540T, 10 invisible), 1,873 guests, and 29 spiders.
Topics298,593
Posts5,138,812
Members70,104
Most Online3,589
Nov 2nd, 2019
Random dome light sensor failure #5278134 11/26/19 04:22 PM
dlundblad Offline OP
I closed the rear hatch glass of my truck like normal and come to find out, the rear passenger and cargo dome lights remained on for about 9 hours. It drained the battery, but thankfully it couldn't have been at a more convenient time. After a jump and a 20 minute drive, it has been fine ever since.
I'm assuming the contacts wore out since it turns off when completely depressed. Thankfully the dome light has an off switch.. Just something else to watch out for as your vehicle ages I guess.
Happy Thanksgiving everyone!
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: Random dome light sensor failure [Re: dlundblad] #5278299 11/26/19 07:31 PM
Dave9 Offline
This is a reason I dislike the newer vehicle, timer based courtesy/etc light time out circuits. I want lights to go out immediately, so I see they are all out instead of having to wait around or assume they'll go out. Usually there is a setting to at least shorten if not disable that time out period but too often vehicles default to some period besides zero.
If you think it'll be a problem in the future, you might put in some much lower current LED bulbs so even if they stay on, they probably won't drain the battery from a period as short as overnight, but of course the ultimate solution is replace all trigger switches so you have an expectation it'll be much longer till it happens again if you even own the vehicle at that point.
Re: Random dome light sensor failure [Re: dlundblad] #5278541 11/27/19 04:23 AM
I never thought about the LED light upgrade. I might have to look into that. Thanks.
Re: Random dome light sensor failure [Re: dlundblad] #5283503 12/02/19 10:36 PM
R
red7404 Offline
R
you might check for bad grounds.
Re: Random dome light sensor failure [Re: dlundblad] #5283526 12/02/19 11:02 PM
A
Aero540T Online Content
Online Content
A
This recently happened to me on my 04 Grand Cherokee. The lift gate switches one or both went bad and the jeep thought the lift gate was open. Even though the lights weren’t on overnight the body control module stayed active and drained the battery. I unplugged the switches and all was fixed. I don’t plan on replacing them as I’m pretty sure I know whether it’s open or not.
I did actually replace all my interior lights with LED but the problem was the module in my case.
2004 Jeep Grand Cherokee Limited 4.7L (wife’s) PUP & FU
2002 Ford Taurus 24V M1HM & M1EP
2001 Dodge Ram 1500 5.9L 4x4 10w-30 RP & FU
1993 Yamaha FZR 600
Re: Random dome light sensor failure [Re: dlundblad] #5283933 12/03/19 11:55 AM
supton Online Content
Online Content
Heh, when I got my '99 Camry 3 years ago, it was a blast from the past, as the dome light was tied directly to the door switches. No time out, no fade out, just off and on. I've thought about adding fade out and auto off, but it's just been too easy to check the dome light and make sure it's off when I get out of the car.
2011 Toyota Camry, base, 2.5L/6MT, 196k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 155k, ours
1999 Toyota Camry LE, 2.2L/4AT, 217k, his
