Buick Regal 2.0T Ecotec Engines
by ET16 - 02/20/20 06:34 AM
Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
2 quarts supertech 0w-20 for $4.56
by sjstangman - 02/19/20 07:35 PM
1994 Buick Century 63K miles
by MuzzleFlash40 - 02/19/20 07:33 PM
Why is this plug so expensive?
by motor_oil_madman - 02/19/20 07:01 PM
Mice and rat deterrent
by whizbyu - 02/19/20 06:45 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
78 registered members (ARB1977, avi1777, askani79705, AndyB, alarmguy, aquariuscsm, 5 invisible), 1,450 guests, and 28 spiders.
Topics301,690
Posts5,200,577
Members70,756
Did I starve my top end of oil? #5277701 11/26/19 08:00 AM
cwilliamsws6 Offline OP
This happened over a year ago but it still bugs me.
So one day I was driving and out of the blue my car throws a CEL and goes into limp mode. Wouldn't go over 2,500(?) RPM and if I tried to a rev limiter would kick in and the car would buck.
I pulled the code and it read as a bad oil pressure sensor so I replaced that, and the issue was fixed but only for about 6 hours.
Pulled off the VTEC solenoid and the mesh screen the oil passes through was plugged with so much sludge that you could not see any light through it. Got a new one and a replacement gasket from the local dealer's parts house for like $2 and I was back on the road, no actual problems since.
I don't know if I'm just paranoid but I swear my engine has gotten a lot of top end rattle since this all happened. When idling, my car sounds like a sewing machine but it smooths out once I get moving.
The low oil pressure light flashes briefly when starting my car after having it parked overnight on my fairly steep driveway (or any type of incline pretty much) but if I start it after being parked on a flat surface for a long time (like the parking lot at my school or work) it doesn't do that. I've verified the oil is at the correct level and there are no leaks.
Also, two oil changes have happened since this day and both times I didn't notice any metal in the oil or anything of that nature.
Am I overthinking this??
2007 Honda CR-V LX "The Linoleum Falcon" 210K miles
HK conv 5w20, STP blue bottle, PrimeGuard POF4610 filter.
"Bad decisions make good stories."
Re: Did I starve my top end of oil? [Re: cwilliamsws6] #5277709 11/26/19 08:08 AM
H
hallstevenson Offline
H
You replaced the oil pressure sensor and VTEC bits. Just drive it.
Be prepared for gloom and doom scenarios though....
Re: Did I starve my top end of oil? [Re: cwilliamsws6] #5277717 11/26/19 08:15 AM
N
nickaluch Offline
N
Keep it topped with oil and just drive it at this point.
2007 G6 beater.2012 E450 box truck. 2018 Chevy Traverse.2017 E450 box truck.2017 Chevy 3500 extend cargo van.
Re: Did I starve my top end of oil? [Re: cwilliamsws6] #5277727 11/26/19 08:38 AM
Astro14 Offline
Top end?
No.
But that VTEC actuator didn’t get any oil for a while.
Drive it until that breaks/leaks.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Did I starve my top end of oil? [Re: cwilliamsws6] #5277744 11/26/19 08:54 AM
J
JC1 Offline
J
To the OP what make and model of car is this along model year and mileage? Sounds like a Honda due to your VTEC reference.
Maybe take it out for an Italian tune-up and see if it quiets down afterwards. What weight of oil are you using? Have you ever removed the valve covers to see the condition of the motor?
You probably are overthinking it.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Did I starve my top end of oil? [Re: cwilliamsws6] #5277765 11/26/19 09:15 AM
J
JLTD Offline
J
I had a car that would clatter horribly on startup when parked tail uphill. Parking nose uphill solved the issue.
Lates.
Re: Did I starve my top end of oil? [Re: cwilliamsws6] #5279168 11/27/19 06:36 PM
B
benjy Offline
B
yes surely lacking details! hondas are not the bulletproof cars they once were
