Current Honda Factory Fill
by asiancivicmaniac - 12/09/19 04:16 AM
Gulf Western - Premium Gold 15W40
by SR5 - 12/09/19 03:43 AM
how can one tell 100% that the oil was changed
by WhyMe - 12/09/19 03:22 AM
Scraped the side of my truck...
by GumbyJarvis - 12/09/19 12:44 AM
Outlasted 3 Marriages
by Y_K - 12/08/19 10:10 PM
High miles on 0W20 oils?
by EyesofThunder - 12/08/19 10:02 PM
90 350 intake gaskets and sealant
by P10crew - 12/08/19 10:01 PM
Glock Polymer80
by pkunk - 12/08/19 09:59 PM
Reman steering rack 09 CRV
by Chester11 - 12/08/19 09:24 PM
Edge 5W-30 10k miles '13 F150 5.0
by dustyroads - 12/08/19 09:18 PM
Hyundai engine failures getting news again
by OVERKILL - 12/08/19 09:04 PM
2015 Ford Fiesta ST
by daemontrym - 12/08/19 07:39 PM
NVX NSP65 Speaker review: Good deal!
by 14Accent - 12/08/19 07:26 PM
Thanks to Quattro Pete for making the 2020 avatars!
by wwillson - 12/08/19 07:17 PM
Klotz 2 Stroke Smelling Candle
by FA_WRX - 12/08/19 06:31 PM
Non scientific oil test.
by tblt44 - 12/08/19 05:33 PM
Nitromethane prices
by 53' Stude - 12/08/19 05:31 PM
Question about JASO specs?
by frascati - 12/08/19 04:15 PM
Anyone knows outdoorsy magazine that are US only?
by MoneyJohn - 12/08/19 03:54 PM
redradar, Jonas_K, slxgold, Dennisfly, AutopartsTester8
70070 Registered Users
34 registered members (DaHen, asiancivicmaniac, Bama, Dave_Mark, alcyon, 4WD, 3 invisible), 670 guests, and 50 spiders.
Topics298,473
Posts5,136,099
Members70,070
Most Online3,589
Nov 2nd, 2019
Mixing transmission fluid #5277629 11/26/19 06:16 AM
J
jdw1222 Offline OP
J
Have about 6 qts of penzoil. Can I mix with some max life when I do a drain and refill on the tranny? C
It’s penzoil platnnum multi vehicle and max life multi vehichle
2005 F-250 6.0 Powerstroke, Amsoil Bypasss System
Re: Mixing transmission fluid [Re: jdw1222] #5277651 11/26/19 07:02 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
That maxlife is low viscosity, is the pennzoil?
Does your vehicle, spec the low viscosity fluid?
Re: Mixing transmission fluid [Re: jdw1222] #5277656 11/26/19 07:06 AM
K
Kira Offline
K
Specify the vehicle while you're at it.
Re: Mixing transmission fluid [Re: jdw1222] #5277683 11/26/19 07:40 AM
P
pbm Offline
P
I would think you'd be fine as long as both met the required specs. Years ago I had to add a few qts. of ST Dexron III to Mobil 1 ATF while doing an ATF/filter change on my Buick Century (4T65E) because I only bought 5 qts. of M1.....it ran fine.
'Journalism is Dead'
Re: Mixing transmission fluid [Re: jdw1222] #5277689 11/26/19 07:44 AM
G
Gebo Offline
G
I'm getting heartburn...
I'll quietly leave the room.
grin
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Shell Gas and Truck & Pennzoil Full Syn HM
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Mixing transmission fluid [Re: jdw1222] #5277763 11/26/19 09:13 AM
J
JLTD Offline
J
Years ago when we had a bunch of leftovers we mixed several brands. Guess what...transmission didn't blow up. YMMV but I'd expect the same today.
I use the overseas manual to choose my viscosity.
Hers: 2008 Jeep Liberty 154k, SS 5w30/Amsoil
Looking at options.
His: 2015 4Runner 60k, SS 5w20/Amsoil
Re: Mixing transmission fluid [Re: jdw1222] #5277787 11/26/19 09:46 AM
J
JTK Offline
J
You do a mix every time you do a drain/fill. If both fluids are compatible with your vehicle you're good to go.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Mixing transmission fluid [Re: JTK] #5277879 11/26/19 11:50 AM
W
Whimsey Offline
W
This thumbsup I just did a drain and fill on our Explorer that specs Mercon LV, which I was using previously for drain and fills, with Castrol Full Synthetic Multi-Vehicle ATF. It's actually licensed by Ford for use in Mercon LV vehicles. It works just fine. As stated, make sure both fluids are spec'd for your vehicle.
Whimsey
Re: Mixing transmission fluid [Re: jdw1222] #5277958 11/26/19 01:15 PM
J
jdw1222 Offline OP
J
2010 gmc Denali
I picked up the 6 qts on clearance from Home Depot.
Planning to do a full fluid change on the Denali. I’ll double check but think they both met same specs
Re: Mixing transmission fluid [Re: jdw1222] #5278086 11/26/19 03:23 PM
R
RyanY Offline
R
If the Pennzoil Platinum is the LV version it will be fine mixed with Maxlife. I have mixed PPLV and Maxlife in two GM vehicles with no problem.
If not the LV version I would not use it, just to be safe.
2007 Cadillac CTS 3.6L >127k miles (Castrol Magnatec 5W-30 + ACDelco PF2129G)
2012 Honda Odyssey EX-L >103k miles (Pennzoil Platinum 0W-20 + Fram XG7317)
Re: Mixing transmission fluid [Re: Whimsey] #5278215 11/26/19 05:56 PM
B
bbhero Offline
B
Whimsey
Exactly right guys ^^^^^^^^^
Nissan Altima 3.5 Coupe
Napa full synthetic 5w30 Wix 57356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Mixing transmission fluid [Re: jdw1222] #5278765 11/27/19 10:31 AM
B
barkingspider Offline
B
In my 04 avalanche tranny, there’s a mix of castrol dex6, autozone dex6, max life atf, and a qt of penzoil dex/merc. Original trans and it runs like new. It has a drain plug so I’ll do a drain and fill w maxlife when the gallon goes on sale again
04 Avalanche Z71 4x4
Re: Mixing transmission fluid [Re: jdw1222] #5279154 11/27/19 06:20 PM
J
jdw1222 Offline OP
J
Yes. It’s the penzoil platinum LV
