Mazda 3 i-ACTIV AWD diagonal test
by buster - 12/11/19 05:35 PM
Tires or Toyota ABS
by ford46guy - 12/11/19 05:33 PM
RV chase straight out of the Movies
by KeithS_NW_Ohio - 12/11/19 04:56 PM
Will the octane change?
by Mar57 - 12/11/19 04:45 PM
DIY brake lines help
by LeakySeals - 12/11/19 04:20 PM
random misfire code but not missing
by bowlofturtle - 12/11/19 03:31 PM
Pressure washing Santa Fe clay tile
by henni - 12/11/19 02:55 PM
Confused. Mercon V or Dexron VI?
by AcadiaDave - 12/11/19 02:33 PM
Sooty Oil in Ford Focus
by RW1 - 12/11/19 02:27 PM
oil sample shelf life?
by novadude - 12/11/19 12:51 PM
whoa!!walmart ammo clearance
by joel95ex - 12/11/19 11:56 AM
Carpro Reset
by BeerCan - 12/11/19 10:46 AM
Come on China. Let's get it right.
by Chris142 - 12/11/19 10:34 AM
'best' conventional 10w-40 pcmo for wet clutch bike
by kmrcstintn - 12/11/19 10:32 AM
Any reason not to use Carquest full synthetic?
by wbwanzer - 12/11/19 10:18 AM
53k miles on a Ford FA-1927
by BeerCan - 12/11/19 09:53 AM
Penzoil Platinum 100% Synthetic ????
by Talent_Keyhole - 12/11/19 09:50 AM
TyMillerfc, AcadiaDave, lmt1911, m14308, MyFirstNamePaul
70104 Registered Users
98 registered members (40Deluxe, AZjeff, BAJA_05, A_Harman, b1amgm47, 53' Stude, 10 invisible), 1,829 guests, and 32 spiders.
Topics298,592
Posts5,138,799
Members70,104
Most Online3,589
Nov 2nd, 2019
Page 1 of 4 1 2 3 4
VW guys questions on the ea839 engine #5277240 11/25/19 05:59 PM
BeerCan Online Content OP
OP Online Content
My new Porsche has the ea839 engine which I believe calls for 508 or C2 oil. It's near impossible to find the correct spec and I don't have the manual in hand yet.
So the question. I'm still a little afraid of 20w oil in some applications. This is a 4500lb SUV with a turbo v6.
If I was to say I am not worried about warranty implications, what spec would be best for this engine? A40? C30?
Most trips will be 30 miles one way in mixed driving/traffic. Slight heavy foot driver. I hate the way my wife drives, it makes me sea sick 😁
2020 Porsche Cayenne
2017 Ford F250 6.7 PS
2016 Ford F150 3.5 EB
2016 Porsche 981 GTS
2015 Ford Mustang 2.3 EB
My car list is getting long smile
1994 Porsche 968 Coupe
1987 Porsche 944 Turbo
Re: VW guys questions on the ea839 engine [Re: BeerCan] #5277252 11/25/19 06:12 PM
B
Boomer Offline
B
Audi forums are saying the new 508 oil has a dye added and it is checked if there is a warranty claim. Don't know that as a fact....just saying. Anyway, I use the new 508 oil in my 2019 Passat. Granted it is a four cylinder but I am using no oil, it is staying clear (I know, not a UOA) but so far no complaints.
2019 VW Passat 2.0 liter gasoline DI engine, DI, 2,700 miles, Castrol Professional VW 508 0W-20
2017 VW Golf All Track 1.8 liter gas engine DI, 25,500 miles Castrol Professional VW 505 5W-40
Re: VW guys questions on the ea839 engine [Re: BeerCan] #5277261 11/25/19 06:21 PM
M
MParr Offline
M
The ea839 engine does specify 508.00/509.00 oil. That V-6 shouldn’t be to hard on oil. I can’t tell you what you should use. Castrol does make their Professional OE LL 3 oil, that is 5W30 504/507 and has the same dye in it as the LL IV.
2019 VW Tiguan SE Now: Castrol Professional OE LL IV 0W20 & OE VW/Mann
2017 Ford Escape SE 2.0T Now: Motorcraft 5W30 SynBlend & NAPA Gold 1348
Re: VW guys questions on the ea839 engine [Re: BeerCan] #5277270 11/25/19 06:32 PM
P
paoester Offline
P
C30 should be OK. (A40 has too much SA which some say could create more valve stem deposits on the DI engine.) In VW 2.0L turbos that spec 508 0w20, VW has been telling dealerships of possible problems if non-508-non-0w20 is used. Seems strange to me. C30 Mobil1 ESP 5w30 maybe.
Should you decide to have faith in Porsche-VW-Audi recommendations for 508, then suncoastparts.com right there in your local FL swampland, or ecstuning.com or rmeuropean.com will ship to you if your own Porsche dealer jacks the price up.
The 508 spec forces oil makers to put in zirconium chemical markers so Porsche would know you're not using the "right" oil. And its green-blue (teal or similar) to try to get technicians to use the right oil.
2019 VW Tiguan S 4Motion, Pennzoil Platinum 0w-20, VW Mann oil filter
Re: VW guys questions on the ea839 engine [Re: BeerCan] #5277279 11/25/19 06:50 PM
T
Trav Offline
T
I wouldn't worry a second about using a xw20 oil. The engine as far as I can tell uses liquid cooled turbo bearings with wide main and rod mountings/caps with a demand controlled variable displacement oil pump. You could say the engine was designed around lower viscosity oil unlike many engines that could run almost anything and just back spec'd for CAFE reasons.
Personally I would not run a heavier oil in this if it calls for C20/508.00, the pump and the engine were not designed for it. This oil looks like it will fit the bill for that spec and includes the dye. Castrol is good stuff.
https://www.europaparts.com/castrol-edge-professional-0w20-long-life-iv-ge525771ldsp.html
Edit: This is interesting.
https://www.audi-technology-portal....-technologies/demand-controlled-oil-pump
Re: VW guys questions on the ea839 engine [Re: BeerCan] #5277281 11/25/19 06:55 PM
P
paoester Offline
P
Trav is right.
Take a look at page 7 of https://drive.google.com/file/d/1GruL4CARAbo_0WL8zUZc5usiiT1IXD7M/view where they say cylinder wall temperature was dropped 20C, which would help the use of lower viscosity oil smeared on there.
The French ship us the cheapest C20 508 oil. rmeuropean.com Total 0w-20. https://www.rmeuropean.com/Products/206764-MFG759.aspx
Re: VW guys questions on the ea839 engine [Re: paoester] #5277298 11/25/19 07:20 PM
T
Trav Offline
T
Thanks for posting that. There is some serious technology in that engine, they state C20 or 504.00 as the oil spec. I guess he will have to wait and see what the owners manual spec is.
Re: VW guys questions on the ea839 engine [Re: paoester] #5277303 11/25/19 07:29 PM
P
paoester Offline
P
They mention 0w-20 on page 26 of https://drive.google.com/file/d/1GruL4CARAbo_0WL8zUZc5usiiT1IXD7M/view and the mention of 504 is a typo probably, should be "508".
Re: VW guys questions on the ea839 engine [Re: BeerCan] #5277328 11/25/19 07:53 PM
E
edyvw Offline
E
If manual states also 504.00, stick to that.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
Re: VW guys questions on the ea839 engine [Re: BeerCan] #5277343 11/25/19 08:21 PM
P
paoester Offline
P
Beercan, run to your Cayenne glove compartment and pull out the Owner's Manual. Its not on the web. It says Porsche C20 like what the Audi EA839 engines use, right?
Re: VW guys questions on the ea839 engine [Re: edyvw] #5277346 11/25/19 08:24 PM
W
wemay Online Happy
Online Happy
W
I'd stick to 508
2018 KIA Sportage LX AWD
Shell RGT 5W20, STP S2808
2013 Hyundai Santa Fe Sport 2.0T
M1AP 5W30, M1-104
Re: VW guys questions on the ea839 engine [Re: paoester] #5277353 11/25/19 08:29 PM
OP Online Content
I will soon as I get it back. It's at the paint protection people right now.
Good links and info here thanks
Re: VW guys questions on the ea839 engine [Re: BeerCan] #5277445 11/25/19 10:09 PM
B
benjy Offline
B
manufacturers are stooping to all time lows to get you to use thinner oils!!! wondering whats recommended overseas. these oils are recommended-specd but if required must be supplied FREE!!!
Re: VW guys questions on the ea839 engine [Re: benjy] #5277552 11/26/19 12:20 AM
E
edyvw Offline
E
That engine? VW 502.00, Porsche A40.
Re: VW guys questions on the ea839 engine [Re: BeerCan] #5277565 11/26/19 12:50 AM
T
TiGeo Offline
T
Liquimoly Top Tech 6200. 0W20 VW 508 00. Online Euro shops have it. FCPEuro.com.
2018 VW Atlas SEL 4Motion 3.6 VR6 - Castrol OE 5W40 VW filter
2018 VW GSW S 4Motion 1.8 TSI Unitronic St2 IS20 - LiquiMoly 5W40 VW filter
2013 Ford Focus SE HB 2.0 Ti-VCT - MC syn-blend 5W20 MC filter
Page 1 of 4 1 2 3 4
