how can one tell 100% that the oil was changed
by WhyMe - 12/09/19 03:22 AM
Scraped the side of my truck...
by GumbyJarvis - 12/09/19 12:44 AM
Outlasted 3 Marriages
by Y_K - 12/08/19 10:10 PM
High miles on 0W20 oils?
by EyesofThunder - 12/08/19 10:02 PM
90 350 intake gaskets and sealant
by P10crew - 12/08/19 10:01 PM
Glock Polymer80
by pkunk - 12/08/19 09:59 PM
Reman steering rack 09 CRV
by Chester11 - 12/08/19 09:24 PM
Edge 5W-30 10k miles '13 F150 5.0
by dustyroads - 12/08/19 09:18 PM
Hyundai engine failures getting news again
by OVERKILL - 12/08/19 09:04 PM
2015 Ford Fiesta ST
by daemontrym - 12/08/19 07:39 PM
NVX NSP65 Speaker review: Good deal!
by 14Accent - 12/08/19 07:26 PM
Thanks to Quattro Pete for making the 2020 avatars!
by wwillson - 12/08/19 07:17 PM
Klotz 2 Stroke Smelling Candle
by FA_WRX - 12/08/19 06:31 PM
Non scientific oil test.
by tblt44 - 12/08/19 05:33 PM
Nitromethane prices
by 53' Stude - 12/08/19 05:31 PM
Question about JASO specs?
by frascati - 12/08/19 04:15 PM
Anyone knows outdoorsy magazine that are US only?
by MoneyJohn - 12/08/19 03:54 PM
Did Honda discontinue PSF
by iluvhonda - 12/08/19 02:44 PM
02 Silverado 5.3L LT Gas fill issue
by Gito - 12/08/19 02:30 PM
redradar, Jonas_K, slxgold, Dennisfly, AutopartsTester8
70070 Registered Users
29 registered members (A_A_G, 4WD, BarryinIN, AZjeff, Char Baby, 3 invisible), 735 guests, and 60 spiders.
Topics298,471
Posts5,136,092
Members70,070
Most Online3,589
Nov 2nd, 2019
'19 Ram 1500 Classic Diff Fluid Weight #5277116 11/25/19 02:21 PM
P
panthermike Offline OP
P
Hey all,
Recently replaced my troubled F-150 for a Ram. I'm starting to prepare for future fluid changes and all seems about the same as my previous '16 Ram except for when I got to the Diff fluid section of the manual. For the rear axle, Ram now recommends 75w90, whereas before it was 75w140. I wondered if this was changed to mirror the new model Ram maybe? I'm sure if they recommend it, it's fine of course but I don't believe there were any physical changes to the axle.
I'm planning on going Amsoil regardless but maybe 75w110 would be a good option?
'17 Armada Platinum; RGT 0w20, 51K
'19 Ram 1500; Dealer fill, 14K
'70 F100; Valvoline 15w40
Biotech
Re: '19 Ram 1500 Classic Diff Fluid Weight [Re: panthermike] #5277138 11/25/19 03:00 PM
R
Rand Offline
R
75w110 certainly wont hurt anything either way
.1mpg?
Re: '19 Ram 1500 Classic Diff Fluid Weight [Re: panthermike] #5277175 11/25/19 04:02 PM
P
Pelican Offline
P
It's all the name of the god....."MPG"
Re: '19 Ram 1500 Classic Diff Fluid Weight [Re: panthermike] #5277176 11/25/19 04:04 PM
Sunnyinhollister Offline
On my 2017 there were two different viscosity recommendations depending on the manual revision. If you tow regularly or heavy go with the 75W-140. I does get a little warm where you are located. I ordered a magnetic drain plug for mine. Just waiting for it to come in.
2017 Ram 1500 Regular Cab 4x2 5.7L 8spd
2017 Chevy Bolt
2018 Jeep Cherokee Trailhawk
2004 Toyota Highlander AWD - RIP
2001 Ranger XL 4x4
Re: '19 Ram 1500 Classic Diff Fluid Weight [Re: panthermike] #5277198 11/25/19 04:38 PM
2015_PSD Offline
I would use it with no hesitation whatsoever. 75W-110 is the upper viscosity that 75W-90 used to be before the J306 tables were updated. if you tow a lot I would also consider 75W-140. Amsoil is great oil and you cannot go wrong no matter which viscosity you choose.
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge 0W-20 + FRAM Ultra]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum Euro 0W-40 & Mann filter]
Re: '19 Ram 1500 Classic Diff Fluid Weight [Re: panthermike] #5277288 11/25/19 07:00 PM
O
oldhp Offline
O
RedLine 75W140 if you tow/haul heavy. Otherwise RedLine 75W110. P.S. I like RedLine oil.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: '19 Ram 1500 Classic Diff Fluid Weight [Re: panthermike] #5277307 11/25/19 07:32 PM
Slick17601 Offline
My 2018 Ram also recommends 75W-90.
2018 RAM Bighorn 5.7
2008 Toyota Sienna 3.5
Re: '19 Ram 1500 Classic Diff Fluid Weight [Re: panthermike] #5277312 11/25/19 07:36 PM
J
JTK Offline
J
What gears does your 2019 classic have?
Per the owner's manual for my 2017 Ram 1500 4x4, pentastar, 3.21 gears, it recommends 75w85 for the front diff (I plan to use regular old 75w90), 75w140 for the rear diff and some unique BW44-44 Mopar fluid for the transfer case that all 2016+ are supposed to use.
I have a thread on that one with nothing but tumble weeds rolling by and crickets chirping.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: '19 Ram 1500 Classic Diff Fluid Weight [Re: panthermike] #5277341 11/25/19 08:18 PM
dave1251 Offline
My son's 2019 Ram recommends 75W90. I use 75W90 in my Silverado where 75W85 is recommended.
don't use.
Re: '19 Ram 1500 Classic Diff Fluid Weight [Re: panthermike] #5277365 11/25/19 08:49 PM
double vanos Offline
This is a pertinent post to me. My ‘18 F150 calls for 75-85 oil in the 9.75 diff with 3:55 gears. My old ‘11 with the 9.75 called for 75-140 which I’d love to use in the ‘18. Does anybody see anything wrong with my thinking? I can’t imagine that much has changed clearance wise that a lighter oil would be necessary. I’m thinking the EPA has something to do with this...
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: '19 Ram 1500 Classic Diff Fluid Weight [Re: double vanos] #5277392 11/25/19 09:13 PM
O
oldhp Offline
O
As long as you use a good synthetic....I see no problems what so ever. My 2018 RAM 1500 2wd 3.6/8 speed auto calls for 75W140. In a 6 banger!!! But I changed it early when new and put in RedLine 75W140 so I won't have to worry about until I hit 60-70 thousand miles. I don't pull/haul anything heavy. I could've probably used 75W110 and been ok....but what the heck.
Re: '19 Ram 1500 Classic Diff Fluid Weight [Re: double vanos] #5277457 11/25/19 10:26 PM
2015_PSD Offline
I would run the 75W-140, the shift to a lower viscosity oil is totally CAFE based.
Re: '19 Ram 1500 Classic Diff Fluid Weight [Re: JTK] #5277739 11/26/19 08:51 AM
P
P
My truck has the 3.21 as well. I'll probably use the 75w110 as a happy medium and 75w90 in the front. I was trying to find out some info as well on the BW44-44 fluid as well. Seems hard to find though, some folks use ATF. Even Amsoil says that their MV Trans fluid is suitable. I may just use the Mopar stuff even though it's expensive, at least it's only a <2qt job.
Biotech
Re: '19 Ram 1500 Classic Diff Fluid Weight [Re: panthermike] #5277782 11/26/19 09:40 AM
J
JTK Offline
J
That's the big question. I have yet to see anything online in regards to someone draining/filling a 2016+.
Lots of 2015 and under posts and videos, but it's a mix of borg warner 44-45's and the older 44-44s.
There's 2 different part numbers for Mopar 44-44 T-case oil. One for up to 2015 and the other for 2016+.
Good thing is the diffs and T-case are super easy to service on these, especially with the pentastar. No exhaust or x-members in the way.
Re: '19 Ram 1500 Classic Diff Fluid Weight [Re: JTK] #5277945 11/26/19 01:02 PM
P
P
Hmmm, that's interesting on the xcase fluid. Let me know if you find anything!
Biotech
