I just changed the rear shocks on my car . I couldn't get OEM bump stops for my car so I cut down a BMW e36 bumpstop from 110mm down to 65mm. I thought this was okay but when I installed the shock to my car, I did not check its rest height.Now I realize at rest height, the bump stops will hit at an eyeball measurement 30mm of shock travel. The car has not been lowered at all and i reused the stock springs, the ride height is standard.
It just seems to me 30mm of total travel is too little? Eyeball measurement of total travel the bumpstop is limiting is about 70mm, which is total end travel of the shaft, which we do not want.
Its possible to cut the bumpstop from the outside, so should I cut off another 15 to 20mm of the top of the bumpstop ?
