Rotating Directional Tires for Dry Conditions
by CharlieBauer - 12/06/19 03:42 PM
Review: My 2011 Prius turned 200K
by The Critic - 12/06/19 03:29 PM
NIB sggcx2 dash cam
by BeerCan - 12/06/19 02:57 PM
Mazda FL22 alternative?
by jayjr1105 - 12/06/19 01:57 PM
Tips for sealing radiator hose
by Parlay_Slow - 12/06/19 01:51 PM
Valvoline
by Koncrete_Cam - 12/06/19 01:32 PM
At home tire rotation protocol question
by NissanMaxima - 12/06/19 12:57 PM
Base oil different in 0W vs 5W?
by doyall - 12/06/19 12:54 PM
Five Gees
by Y_K - 12/06/19 12:31 PM
Valvoline Dex/Merc Label
by 28oz - 12/06/19 12:23 PM
Storing a vehicle- advice please!
by Rolla07 - 12/06/19 11:53 AM
1964 Cub Cadet 100
by Phishin - 12/06/19 11:40 AM
2001 Volvo V70XC 6140 Miles Mobil1 10w-30 HM
by Astro_Guy - 12/06/19 11:22 AM
Blend door motor reset
by otis24 - 12/06/19 11:08 AM
My 68 L36
by JeffKeryk - 12/06/19 10:45 AM
2016 Accord 11,513 Miles Mobil1 5w-30 EP
by Astro_Guy - 12/06/19 10:15 AM
Leaf springs last how long?
by supton - 12/06/19 09:27 AM
BajaBu, Bayoubrad, Fog42, glassmaker, PontiacHO
70052 Registered Users
85 registered members (4WD, BAJA_05, BeerCan, Audios, 928, benjy, 6 invisible), 2,189 guests, and 55 spiders.
Topics298,382
Posts5,134,198
Members70,052
Most Online3,589
Nov 2nd, 2019
Schley Products 68100 Bushing Tool #5276316 11/24/19 02:21 PM
The Critic Offline OP
https://www.sptool.com/product/68100-hondaacura-front-lower-compliance-bushing-rr-tool/
https://www.tooltopia.com/schley-68100.aspx
Purchased this tool because my 9circle kit only covered the 74mm bushings and their 65mm version was OOS everywhere.
I used the Schley tool on a 2003 Pilot with the 65mm bushings.
The best part about the Schley tool is that the pressing cup has a groove to hold the new bushing. This seems to help keep the bushing centered while pressing in the new one.
The intent of the Schley tool is to allow you to replace the compliance bushing without removing the control arm. You will need to remove the axle nut and push in the axle before pulling out the arm though. Otherwise you WILL separate the cv axle’s inner joint.
The cost is a bit steep but a new control arm from Honda is over $300/side and the compliance bushings is only $30. Usually the rest of the arm is still fine (it is just the compliance bushing that wears out) so this tool is a great investment if you own or service any Honda products with the 65mm or 74mm bushings.
7B6B7C77-E9E6-49F5-9129-A4E4AE6BC272.jpeg84197A38-6676-457F-817E-B277DAD84C57.jpeg2286D153-3E9E-4A9C-9327-1DBF1B5B9381.jpeg3B49AAED-5758-4F06-B7CF-5C1008136AAC.jpeg
2011 Toyota Prius 1.8L - 200K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 142K - Valvoline Premium Blue Restore 10W-30
Re: Schley Products 68100 Bushing Tool [Re: The Critic] #5276393 11/24/19 03:53 PM
J
JC1 Offline
J
Schley makes some good quality stuff. Had their Crankshaft pulley holder that I bought for my 98 Sienna timing belt job.
I'm sure you'll get plenty of use from that tool.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Schley Products 68100 Bushing Tool [Re: The Critic] #5276451 11/24/19 04:51 PM
A
atikovi Offline
A
In the picture it's looks like you have the control arm pretty much removed except for at the ball joint. Why not spend 2 minutes to remove it from there too?
Re: Schley Products 68100 Bushing Tool [Re: atikovi] #5276482 11/24/19 05:37 PM
M
maxdustington Offline
M
Two minutes, eh? TBF Crit does live in the mythical land where rust does not exist.
99 Toyota Tercel CE 5EFE/C151
Re: Schley Products 68100 Bushing Tool [Re: The Critic] #5280774 11/29/19 10:23 PM
ctechbob Offline
Looks a lot better than the combination ball joint press, bearing press, and old hollowed out compliance bushing I use. Gets the job done...certainly isn't the easiest way to do it though. That and Honda puts a bevel on the edge of the bushings, so you have to be careful and not slip off, the groove in an official tool would be a godsend for that.
2008 Acura TL Type S-155k*
2003 Honda Accord V6-207k
Oil-Havoline ProDS 5W30 / *HM 5W20
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: Schley Products 68100 Bushing Tool [Re: ctechbob] #5281457 11/30/19 08:06 PM
Eh, the less you remove, the better. There is always a risk to separating the ball joint. Sometimes the boots rip. If you use the ball joint air hammer nuts, you will sometimes rip the threads off of the stud.
Yeah, the groove in the cup is truly a godsend.
Re: Schley Products 68100 Bushing Tool [Re: The Critic] #5282447 12/01/19 09:55 PM
Just did a pair today on a relative’s 03 Accord with the 74mm bushings. No issues at all with the dual 65/74mm design.
35420931-F531-4846-BC95-87907359A38D.jpegFAE5BECB-1D60-437E-953E-152C3C1C50AA.jpeg8DE275BD-09A0-400C-B41B-35D861CA6979.jpeg
Re: Schley Products 68100 Bushing Tool [Re: The Critic] #5282533 12/02/19 01:48 AM
W
WhyMe Offline
W
Honda dealer want a lot to do bushings. cousins 2012 pilot had leaking bushings. they wanted $900 to do both . parts were $250 or so. So i look it up to see why its so much and it looked like a easy job . then i saw that they would be covered under a extended honda warranty for these . service guy did not bother to tell him it was still under warranty.
took it in and was out in less than 2 hours.
Re: Schley Products 68100 Bushing Tool [Re: The Critic] #5283609 12/03/19 04:43 AM
dlundblad Offline
Nice. It’d be very easy to get your money’s worth and then some out of this tool.
I thought about doing something like this when I did the wife’s control arms last year. Sadly, one of the bushes has 2 bolt holes that need to be oriented 90 degrees with the ground.
Since I didn’t have a jig I decided to pass, but this would have been so much cheaper in the long run as well as in the future since it eats bushings. Thankfully the most failure prone bushing is easy to replace unlike the oddball.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
