I need to re-insulate the kitchen floor over a crawl space. It currently has falling down fiberglass batts. Mice have made little messes here and there. So rather than replacing the damaged fiberglass batts I was thinking of replacing all the fiberglass batts with rockwool.
Never worked with rockwool but looks like I can just push up these flexible rectangles of rockwool and they will stay put. I could even get a higher R-value and then have the insulation stick below floor joists.
Currently the hot and cold water pipes freeze when below 5F (typically at night) and they are at the top of the floor joist where the joist meets the floor covered in a batt of insulation.
So how is rockwool to work with? Most people seem to use fiberglass.
