Good news for .300blk shooters
by The_Eric - 01/28/20 06:43 PM
‘16 Lexus GS350 vs ‘16 Lexus RX350
by miden851 - 01/28/20 06:19 PM
Stone guard removal
by dawgn86 - 01/28/20 06:09 PM
Craigslist is like a petty HOA now
by eljefino - 01/28/20 05:06 PM
Shoretel PABX - any experience?
by stockrex - 01/28/20 04:44 PM
Around Australia record in the 1970's
by sanoptic - 01/28/20 03:21 PM
Oil mixing...does density matter?
by LotI - 01/28/20 02:02 PM
Uh Oh. Subaru Front Halfshaft CV Going Bad
by ARCOgraphite - 01/28/20 01:25 PM
Help choosing the right oil
by CAJ1966 - 01/28/20 12:33 PM
Which cooler line is return?
by LeakySeals - 01/28/20 11:39 AM
New Havoline ProDS 0w20 boosted Moly?
by jayjr1105 - 01/28/20 10:59 AM
Diesel fuel pump, pump synthetic 40 weight?
by H20ham - 01/28/20 10:54 AM
Review: 2019 VW Passat Wolfsburg 2.0T
by wemay - 01/28/20 10:16 AM
Group 2 mix with Group 4
by ridgerunner - 01/28/20 09:50 AM
Power Steering Fluid for 54 Chevy
by ThomasJ49 - 01/28/20 08:54 AM
Am I killing my transmission?
by Avery4 - 01/28/20 08:52 AM
BorgWarner to buy Delphi in $3.3B deal
by wemay - 01/28/20 08:37 AM
COP's which brand
by Eric Smith - 01/28/20 07:56 AM
$150 off Bridgestone tires
by D1dad - 01/28/20 06:26 AM
Towkid, denor, Jubaxtreme, CAJ1966, Shiza
70550 Registered Users
125 registered members (53' Stude, 2015_PSD, Astro_Guy, 2010Civic, advocate, 12 invisible), 3,070 guests, and 19 spiders.
Topics300,678
Posts5,180,981
Members70,550
video 3.2L 1996 engine noise, loose valve, rod, other? #5276035 11/24/19 08:06 AM
sdowney717 Offline OP
I lifted Trooper, and put long screwdriver onto oil pan (ear on other end) and all over motor, and can not hear this tapping sound. Just typical whirring noises.
Especially the oil pan has no loose bearing noises. No knocking type sounds at all down there.
What is this cause of this noise do you think?
https://www.youtube.com/watch?v=qwe8V-4Q6YA&feature=youtu.be
Re: video 3.2L 1996 engine noise, loose valve, rod, other? [Re: sdowney717] #5276038 11/24/19 08:11 AM
M
mpack88 Online Content
Online Content
M
I believe those Troopers are known for making noises. I think it's just the lash adjusters/ rocker arm's that make those noises. Every one ive seen made that same noise.
Re: video 3.2L 1996 engine noise, loose valve, rod, other? [Re: mpack88] #5276039 11/24/19 08:14 AM
It could be. When I got it, it was many more lash adjusters stuck, a real racket of sounds. I put a qt of MMO in 15w-40 oil and after a week, it all had gone, except for this final noise.
Re: video 3.2L 1996 engine noise, loose valve, rod, other? [Re: sdowney717] #5276040 11/24/19 08:17 AM
I have been worried about a incipient rod bearing going, like the beginning stages before it goes really loud.
But putting my ear to the oil pan, is swaying me away from any engine bearings beginning to cause noises.
Re: video 3.2L 1996 engine noise, loose valve, rod, other? [Re: sdowney717] #5276044 11/24/19 08:23 AM
K
ka9mnx Offline
K
Lifter noise/valve lash adjustment (if that is possible).
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: video 3.2L 1996 engine noise, loose valve, rod, other? [Re: sdowney717] #5276046 11/24/19 08:25 AM
K
ka9mnx Offline
K
Rod bearing noise is a dull thud, thud, thud. Lifter noise is a tick, tick, tick.
Re: video 3.2L 1996 engine noise, loose valve, rod, other? [Re: ka9mnx] #5276052 11/24/19 08:32 AM
M
Online Content
M
Yes, it sounds more like a top end noise.
Re: video 3.2L 1996 engine noise, loose valve, rod, other? [Re: sdowney717] #5276053 11/24/19 08:35 AM
Engine has hydraulic lash adjusters. So no adjustment can be made. And it is a huge job to replace them. Have to remove the camshafts which means take the camshaft timing belt off the front, and only has 20,000 miles on a new belt that can last at least 60,000 miles.
Re: video 3.2L 1996 engine noise, loose valve, rod, other? [Re: sdowney717] #5276055 11/24/19 08:36 AM
ctechbob Offline
Yep, sounds just like my 97 did. The 'official' fix for them from Isuzu's TSB from the time period was run 0W-30 Mobil1. Back then 0W's were scarce, so Mobil1 would have been one of the better ones on the market. The goal is to get oil flowing through the HLA's and let them clean themselves out.
2008 Acura TL Type S-165k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W20
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: video 3.2L 1996 engine noise, loose valve, rod, other? [Re: sdowney717] #5276056 11/24/19 08:36 AM
demarpaint Offline
Top end noise. It can run like that for a very long time.
God Bless Our Troops
Re: video 3.2L 1996 engine noise, loose valve, rod, other? [Re: ka9mnx] #5276057 11/24/19 08:38 AM
caprice_2nv Offline
I think you mean a main bearing noise. A rod bearing isn't a tick but more of a knack knack knack that gets worse under load and certain rpms if you're reving it. Like a double knock.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
79 Honda CX500
Re: video 3.2L 1996 engine noise, loose valve, rod, other? [Re: sdowney717] #5276059 11/24/19 08:39 AM
I suppose I could try some seafoam in the oil. Seafoam being volatile wont last forever in the oil, it will evaporate out.
The MMO oil I put in did help a lot of the noise except left with this last bit.
Any thought on seafoaming the crankcase?
Re: video 3.2L 1996 engine noise, loose valve, rod, other? [Re: sdowney717] #5276062 11/24/19 08:47 AM
demarpaint Offline
I'd stick with what worked. If you want to change it up a bit try this: Rislone HM. Trav mentioned it as a good product. There are two ways to use it. Two bottles for 100 miles, then dump the oil and filter. Fill it wiith fresh oil and a new filter, with one bottle for your normal OCI. Or since you already did some cleaning you can use one bottle for your normal OCI. Don't over fill the sump and keep an eye on the oil level.
Re: video 3.2L 1996 engine noise, loose valve, rod, other? [Re: sdowney717] #5276081 11/24/19 09:23 AM
PimTac Offline
Frankly I didn’t hear anything that would concern me. What year is this Isuzu and how many miles on the engine?
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: video 3.2L 1996 engine noise, loose valve, rod, other? [Re: sdowney717] #5276084 11/24/19 09:28 AM
W
Warstud Offline
W
Sounds like this 3.2L Read the comments
