Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
Project Farm Lucas transmission additive video
by 1978elcamino - 01/21/20 09:43 AM
1.8t 0w40, plus a situation.
by WMNN1988 - 01/21/20 09:25 AM
Mobil 1™ ESP X2 0W-20 US Availability
by TheIceStormof06 - 01/21/20 08:46 AM
Wire harness/connector
by Redright9 - 01/21/20 07:58 AM
Will You Jump Someone Else's Car?
by Gebo - 01/21/20 07:08 AM
NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
103 registered members (1978elcamino, 90crvtec, 330indy, 1WildPig, 53' Stude, 10 invisible), 2,399 guests, and 36 spiders.
Topics300,396
Posts5,174,887
Members70,497
Fleetguard LF777 performance #5216610 09/18/19 09:54 PM
P
Pyrotechnic Offline OP
P
Ive found various forum conversations about this filter, and at some point the micron rating comes up, and someone will post some really awful micron number allegedly from Fleetguard and then the discussion ends. It seems to get written off as an old design not worth anyone's time. From what I understand it came out around 1980 to replace the huge LF500 bypass units that were filled with newspaper and wood chips.
Looking at a Fleetguard catalog, I see the LF777 mentioned as 5 micron, but no beta ratio. The Fleetguard LF777 is made with stacked disc media, the same kind found in the Venturi series of filters. I have a hard time believing that the 777 is a poor performer, if it is full of the same media that makes the Venturi filters so great.
Does anyone have any personal experience with the LF777 and how well it performs?
Re: Fleetguard LF777 performance [Re: Pyrotechnic] #5216775 09/19/19 06:19 AM
B
bullwinkle Offline
B
I have experience with the stacked disc Venturi filters, and they do a really good job keeping diesel oil visibly cleaner-but it will take before & after particle counts to tell what the actual difference is.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Fleetguard LF777 performance [Re: Pyrotechnic] #5261145 11/07/19 07:20 PM
J
jetman Offline
J
In 2011 I was building and installing bypass filtration systems on Cummins M11 and ISM engines. I got in a discussion on a forum about what would be the best spin-on bypass filter to use on the remote mount I was using. A Cummins/Fleetguard Field Service Engineer on a forum said the LF777 was the best. A phone call to their tech dept told me the LF3542 was better. The Field guy said the LF777 is a stacked disc design and was 98% efficient at 10 microns. He also told me the LF3542 was 99% efficient at 10 microns. Both are about the same physical size and cost about the same. The threads on both are 1 3/8" x 16. I ended using the LF3542. These days I just install Fleetguard Venturi Combo filters. They do the jobs of both a full flow and bypass filters.
Venturi Combo link
Fulltime DIYer, retired pilot
12 MKX 3.7
07 Yukon 6.2
07 Toyota FJ 4.0
96 Prevost XL40 12.7
51 Chevy 5w PU Resto 5.3
92 TopSportsman Firebird w/604
241" 4link Dragster w/565
83 Glasair! TD
90 Ez-Go 2-cysle GC
Re: Fleetguard LF777 performance [Re: Pyrotechnic] #5262997 11/10/19 04:06 AM
CDX825 Offline
Ive always wondered the same thing about the LF777 filter. I figure that stacked disc media has to do better than the pleated style of bypass filter.
1984 Ford F250 6.9 Diesel C6 2WD Rotella T 15W40 NTZ Bypass Filter
1992 Mazda B2600 4x4 Amsoil Series 3000 5W30
1998 Ford Ranger 4x4 Pennzoil Platinum 5W30
Re: Fleetguard LF777 performance [Re: CDX825] #5263122 11/10/19 08:22 AM
J
jetman Offline
J
If I was doing it today, I would us the LF777.
It would be interesting to cut each open to see what is what.
12 MKX 3.7
07 Yukon 6.2
07 Toyota FJ 4.0
83 Glasair! TD
90 Ez-Go 2-cysle GC
Re: Fleetguard LF777 performance [Re: Pyrotechnic] #5266866 11/14/19 09:33 AM
L
Linctex Online Content
Online Content
L
I have the same base, but use a Wix 51749 .... just because they are so darn cheap!
Re: Fleetguard LF777 performance [Re: Linctex] #5275438 11/23/19 12:35 PM
P
P
Have you opened one of these up or looked down the center hole? Do they have stacked disc media or pleated paper? I've heard that some of the LF777 crosses have a regular pleated paper element inside.
Re: Fleetguard LF777 performance [Re: Pyrotechnic] #5275837 11/23/19 10:12 PM
J
jetman Offline
J
Here are the specs for:
Fleetguard LF777 = 99% @ 30 microns: LF777 link
Fleetguard LF3542 = 100% @ 30 microns: LF3542 link
12 MKX 3.7
07 Yukon 6.2
07 Toyota FJ 4.0
83 Glasair! TD
90 Ez-Go 2-cysle GC
Re: Fleetguard LF777 performance [Re: Pyrotechnic] #5276011 11/24/19 07:32 AM
J
jetman Offline
J
Bad link for LF777?
Here it is again: LF777 link
12 MKX 3.7
07 Yukon 6.2
07 Toyota FJ 4.0
83 Glasair! TD
90 Ez-Go 2-cysle GC
Re: Fleetguard LF777 performance [Re: Pyrotechnic] #5293680 12/13/19 05:26 PM
L
Online Content
L
I will be very soon.
I'm 99.999% sure it's the same 5-micron pleated paper as the WIX fuel filters use.
Re: Fleetguard LF777 performance [Re: Pyrotechnic] #5300124 12/20/19 04:18 PM
P
P
Fleetguard seems to list many oil filters on the website, both full flow and bypass, with the same 99% @ 30 or 100% @ 30 rating. It seems to be nothing more than a default value or a placeholder.
Here's a screenshot from a 2012 Fleetguard catalog. It is an installation diagram for an oil level regulator system, showing an LF777 as an optional 5 micron filter.
[Linked Image]
Then there's this post I found with communication from Fleetguard, with the LF777 being "10 Micron at 98% efficient and 5 Micron at 95% efficient."
https://www.bobistheoilguy.com/foru...in-b-164-a-good-bypass-filter#Post857926
Lots of conflicting information, but in my opinion I think that a genuine Fleetguard LF777 would be worth a try, based on the design and the more favorable numbers that Fleetguard has published.
Re: Fleetguard LF777 performance [Re: Pyrotechnic] #5320374 01/11/20 11:32 PM
J
jetman Offline
J
It's not conflicting info. A filters efficiency % decreases as the micron size gets smaller. That's how it works.
100% at 30 microns
98% at 10 microns
95% at 5 microns
12 MKX 3.7
07 Yukon 6.2
07 Toyota FJ 4.0
83 Glasair! TD
90 Ez-Go 2-cysle GC
