Electric car charge cord review
by OVERKILL - 05/26/20 04:55 PM
Edit
by TheLawnRanger - 05/26/20 04:29 PM
faulty bosch right angle drill
by benjy - 05/26/20 04:14 PM
2017 Accord Hybrid Brake Fluid Flush
by Tundragod - 05/26/20 04:12 PM
06 GMC Hybrid
by hardheaded - 05/26/20 03:57 PM
98 Camry busted oil drain plug
by JeffKeryk - 05/26/20 03:31 PM
Picked up a used Honda Push Mower today
by redhat - 05/26/20 02:43 PM
Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Any experience with MU-MIX ?
by henni - 05/26/20 01:22 PM
RA code
by Koncrete_Cam - 05/26/20 12:12 PM
best alternative to a group 79? hopefully more cca
by apollo18 - 05/26/20 11:25 AM
Gas Prices Are Going Up
by BlueOvalFitter - 05/26/20 10:49 AM
One way to "fix" a loud vehicle exhaust
by ZZman - 05/26/20 10:01 AM
Limited slip rear end in Tacoma
by taintedtattoo - 05/26/20 09:45 AM
Best Ball Joint and Pitman Arm Grease?
by 2015_PSD - 05/26/20 09:31 AM
12 volt air compressor
by John_Conrad - 05/26/20 08:42 AM
Battery Charging Compatibility
by cb450sc - 05/26/20 07:11 AM
Techron With GDI Engines Intake Vale Cleaning ?
by ChrisD46 - 05/26/20 06:58 AM
MechEnDawg, jimbacot, MowerVet, RonWSmith3, LJB
71535 Registered Users
95 registered members (97K15004WD, 2015_PSD, AdRock, Alfred_B, 53' Stude, 55hambone, 6 invisible), 2,503 guests, and 78 spiders.
Topics305,914
Posts5,282,633
Members71,535
KTM TPI 2T OIL #5275759 11/23/19 09:06 PM
8
83benz Offline OP
8
Just got a 2020 KTM 300 XC-W TPI Transfer Port Injection. The manual says to use JASO FD synthetic reputable oil and recommend Motorex - Cross Power 2T which is about $18/quart.
Is there options for a NON-premix 2T synthetic oil that is JASO FD rated that isn't $18/quart that people recommend?
2006 VW Jetta TDI - PD 25,000; FOUR 1983 Mercedes Benz 240D 65,000; 95,000; 185,000, 335,000
Re: KTM TPI 2T OIL [Re: 83benz] #5275769 11/23/19 09:34 PM
T
tundraotto Offline
T
Re: KTM TPI 2T OIL [Re: 83benz] #5275774 11/23/19 09:38 PM
T
tundraotto Offline
T
Motul 710 2T would be my choice.....
I use the the 800 Ester in my 2-strokes and it is the most amazing oil I have ever used. Lower temps, clean as a whistle, higher performance (had to turn down carbs at same mix).
Re: KTM TPI 2T OIL [Re: 83benz] #5275896 11/24/19 02:22 AM
R
rubberchicken Offline
R
I checked the Amsoil website, and they recommend Amsoil Dominator 2T is $9 a quart, or $36 a gallon. if you are a dealer or preferred customer. I use the same stuff on my Yamaha Waverunner XLT 1200
Re: KTM TPI 2T OIL [Re: 83benz] #5275904 11/24/19 03:27 AM
Silk Offline
Love to find some FD synth for $19 a litre - how would you like to pay $37 like I did last week.
1987 BMW R65 - Penrite VTwin 20-50
2005 Nissan Expert - 5W-30 Castrol Edge
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: KTM TPI 2T OIL [Re: 83benz] #5276210 11/24/19 01:20 PM
Cujet Offline
I continue to like Castrol TT-S. Although it's not particularly inexpensive.
Pretty much any of the quality EG-D/FD oils are excellent. But in this case, I'd stick with the recommended oil. As it's the proper viscosity for pump-ability.
With a proper design and oil flow, I think engine life could be improved with a system like the KTM injection system, as oil is not diluted by fuel. However, some KTM owners seem to have cylinder wear issues with these. I have to wonder if it's related to oil viscosity and pump action.
Some people are saying that one ounce of oil per gallon seems to be a fix. But that requires a free flow fuel filter.
Re: KTM TPI 2T OIL [Re: Cujet] #5276227 11/24/19 01:41 PM
J
JunkdrawerDog Offline
J
A friend of mine rides a Beta 300 2 stroke with oil injection. Beta recommends a Motul lubricant that is suitable for premixed or injector systems. You might browse the Beta forums to find more info.. I don't recall the Motul being that expensive or hard to find.
Re: KTM TPI 2T OIL [Re: 83benz] #5278102 11/26/19 04:40 PM
8
83benz Offline OP
8
I found Luqui Moly 2T JASO FD for $13/liter.
I'm going to start without until I hear some reason not to.
On a separate issue. Does anyone know for sure if 100LL aviation gas is ok to run in this high compression 2 strokes with EFI? I went by the one gas station in my area that carries "race gas' and it was either 100 octane WITH Ethanal or 110 octane leaded. $8/gallon
I know I can aviation 100LL for about half that price but didn't want to add leaded gas until I knew for sure it was ok.
Re: KTM TPI 2T OIL [Re: 83benz] #5278174 11/26/19 06:06 PM
K
Kamele0N Offline
K
your motocycle is MY2020...and you are expecting that it doesnt have any catalyst converter inside its exhaust? smile
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 (Shell?) 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10W-40
Re: KTM TPI 2T OIL [Re: Kamele0N] #5278182 11/26/19 06:13 PM
8
83benz Offline OP
8
Yes.. it's an off road KTM dirt bike. I'm NEARLY certain it's a straight pipe into a simple muffler - no electronics on that side of the cylinder.
Re: KTM TPI 2T OIL [Re: 83benz] #5279219 11/27/19 08:56 PM
Cujet Offline
100LL is great fuel, but it is likely to lead foul your plug. I’ve used 100LL plenty in two stroke dirt bikes for the octane. It’s use is generally problematic.
May I suggest VP-fuels C9 (96) or Sunoco Optima (95) octane. They are both so similar they can be interchanged and will run perfectly.
Re: KTM TPI 2T OIL [Re: 83benz] #5282891 12/02/19 01:29 PM
sunruh Offline
VP C12 is perfect for a 2smoke
motorcycle oil myth buster
Re: KTM TPI 2T OIL [Re: Cujet] #5283003 12/02/19 03:28 PM
BusyLittleShop Online Content
Online Content
I agree...
Running leaded fuel will not only drain your wallet needlessly but also
add yellowish lead deposits to your spark plugs and combustion
chamber besides being a health risk...
All in all lead is a high maintenance additive...
[Linked Image from turbododgeparts.com]
Larry L
Have a Wheelie NICE day
94 RC45 #2 58,000 on 30 Grade, Currently Mobil 1 5W30 SN
2002 Camaro Mobil 1 5W30
1952 De Havilland Chipmunk
Re: KTM TPI 2T OIL [Re: 83benz] #5283114 12/02/19 04:55 PM
A
ad244 Offline
A
I want one of these bikes so bad... Always used Dominator in my 2T over the years.
Re: KTM TPI 2T OIL [Re: ad244] #5410753 04/22/20 10:25 PM
8
83benz Offline OP
8
Find a KTM Demo Day near you. They are AWESOME!!!
