Put the winter tires on the Impala today.
by JimPghPA - 12/11/19 07:31 PM
Chasing down a brake issue
by HawkeyeScott - 12/11/19 07:14 PM
Total Quartz 9000 Energy 5w40
by BurntMusic - 12/11/19 06:53 PM
Mazda 3 i-ACTIV AWD diagonal test
by buster - 12/11/19 05:35 PM
Tires or Toyota ABS
by ford46guy - 12/11/19 05:33 PM
RV chase straight out of the Movies
by KeithS_NW_Ohio - 12/11/19 04:56 PM
Will the octane change?
by Mar57 - 12/11/19 04:45 PM
DIY brake lines help
by LeakySeals - 12/11/19 04:20 PM
random misfire code but not missing
by bowlofturtle - 12/11/19 03:31 PM
Pressure washing Santa Fe clay tile
by henni - 12/11/19 02:55 PM
Confused. Mercon V or Dexron VI?
by AcadiaDave - 12/11/19 02:33 PM
Sooty Oil in Ford Focus
by RW1 - 12/11/19 02:27 PM
oil sample shelf life?
by novadude - 12/11/19 12:51 PM
whoa!!walmart ammo clearance
by joel95ex - 12/11/19 11:56 AM
Carpro Reset
by BeerCan - 12/11/19 10:46 AM
Come on China. Let's get it right.
by Chris142 - 12/11/19 10:34 AM
'best' conventional 10w-40 pcmo for wet clutch bike
by kmrcstintn - 12/11/19 10:32 AM
TyMillerfc, AcadiaDave, lmt1911, m14308, MyFirstNamePaul
70104 Registered Users
120 registered members (AcadiaDave, Al, 4WD, Aero540T, 14Accent, alarmguy, 9 invisible), 1,889 guests, and 32 spiders.
Topics298,596
Posts5,138,836
Members70,104
Most Online3,589
Nov 2nd, 2019
schaeffers or ? #5275371 11/23/19 11:06 AM
L
longbowhntr Offline OP
L
I have an 2002 ford f350 with the 7.3 has about 74,000 miles on it have owned it since new have been running schaeffers 15/40 in it the last few oil changes seems to like it but it is expensive around $28.00 a gallon,I can get the Rotela T6 15/40 for around 20 at the local wal mart or I can get the amsoil oe 15/40 for around the same price as the schaeffers.
I only change the oil once a year don't drive it much and been using the wix 51734xe oil filter because we get them cheap through work.trying decide what to use this time.
Has anyone tried the rotella 15/40 in a 7.3? or should I just stick with what I have been using.
Re: schaeffers or ? [Re: longbowhntr] #5275392 11/23/19 11:38 AM
JohnnyJohnson Offline
There is nothing wrong with Rotella T6 5w 40. Rotella has rebates Schaeffer's has never had a rebate I've seen. 74,000 miles isn't that much on a truck that age. You will make it just fine on Rotella for a year. My last Rotella T6 went 19 months with low OCI miles.
2004 Corolla 137480
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 76862
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: schaeffers or ? [Re: longbowhntr] #5275450 11/23/19 12:44 PM
B
benjy Offline
B
your talking pocket change!! why so many discuss a few bucks is beyond me!! so much $$$$ is foolishly spent on unhealthy habits so use whetever you like.
Re: schaeffers or ? [Re: benjy] #5275471 11/23/19 01:09 PM
LOL its another thing if your getting something for the extra dollars in not its a waste and you've been taken advantage of.
2004 Corolla 137480
2006 Duramax 76862
Re: schaeffers or ? [Re: longbowhntr] #5275475 11/23/19 01:14 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Schaefer’s is great stuff. Rotella is fine and proven oil too. I’d likely argue Schaefer’s is probably a better blend of higher quality stuff, if you’re a PAO nut, but that is speculative, and you might not ever see an actual longevity increase in reality.
So there’s two ways to look at this:
1) because the truck gets so little use, it’s not ever going to wear out and so use what’s cheap and convenient.
2) because the truck gets so little use, buying a higher end oil really is not a costly consideration that makes much difference.
Since you don’t drive it much, I’d probably go Schaefer’s since it supposedly uses Antimony which is a good add to combat corrosion and other bad conditions, and then use UOA to verify that you can change it every other year.
Re: schaeffers or ? [Re: longbowhntr] #5275527 11/23/19 02:20 PM
T
tundraotto Offline
T
^This. Perfect.
Re: schaeffers or ? [Re: longbowhntr] #5275552 11/23/19 02:51 PM
J
JLTD Offline
J
Agree with a two year interval with Schaeffer Oil. (Two Fs in Schaeffer guys) Makes sense with the low usage and a UOA. thumbsup
I use the overseas manual to choose my viscosity.
Hers: 2008 Jeep Liberty 154k, SS 5w30/Amsoil
Looking at options.
His: 2015 4Runner 60k, SS 5w20/Amsoil
Re: schaeffers or ? [Re: JHZR2] #5275617 11/23/19 04:12 PM
M
Mainia Offline
M
I always look as Schaefers as a Group 3 company. Do they have a high PAO oil?
Re: schaeffers or ? [Re: Mainia] #5275706 11/23/19 06:59 PM
T
TiredTrucker Offline
T
Does it really matter? Group III has many qualities that meet Group IV PAO, and even exceed Group IV PAO in some ways. So the idea that Schaeffer likes to do a Group III (75%) and Group IV (25%) in most of their full syn motor oils is not really a bad thing, but actually a positive in some ways.
https://www.machinerylubrication.com/Read/533/base-oil-trends
https://www.machinerylubrication.com/Read/31106/polyalphaolefin-pao-lubricants
The main thing that PAO offers over Group III is thermal oxidative stability. A quality Group III has higher lubricity than PAO, has better additive solubility, and comes very close in viscosity index and pour point.
I have had very good results with Schaeffer syn blend which is 75% Group II+ and 25% Group IV PAO. Just ask my Detroit 60 12.7L with 1,046, 240 miles on it, is still all original except for water pump and air compressor, and only uses about 1 qt of oil in 11-12,000 miles. Still works every day.
Freedom is not about having the choice to do what you want, but the choice to do what you ought.
Re: schaeffers or ? [Re: longbowhntr] #5275773 11/23/19 08:37 PM
L
L
Thanks guys will probably just stick with the schaeffers going to send off a sample to get tested just got the sample bottle from blackstone today, I have around 3,700 miles on the oil now and it has been in there since last October.
Re: schaeffers or ? [Re: longbowhntr] #5276016 11/24/19 07:36 AM
T
turbowhistle Offline
T
I used to have a 2002 F350 with the 7.3 as well. The 7.3 was in my opinion the best motor International made for these trucks. Mine only had about 131,000 when I got rid of it. Mechanically (Motor, Trans and Differentials) it ran great, loved the truck. The issue I had was the rust around the inner rear fenders, rocker panels and bottom of the inner doors. Had the rust fixed I thought but it returned a year or so later. I hated to get rid of the truck but because of the rust I had to.
When I had my 7.3, I thought the pol and filter were super easy to change. I used Delo 15w40, Shell Rotella 15w40 but mostly the Motor Craft 15w40 purchased at WM (3 Jugs in the 5 Quart Containers along with the Motor Craft FL1995 Oil Filter). The oil filter although pretty big was super easy to get to as you know. I would loosen it just a little then use a Sharpe Steel Punch to puncture the bottom of the oil filter to let the oil filter drain before removing it with no mess to deal with. The oil filter held well over a quart of oil as you know. Although the 7.3 held 15 Quarts of oil, it was a breeze to do the oil and filter changes. The Motor Craft 15w40 was/is a great oil as well. t was made for Ford by Conoco-Phillips specifically designed to work well with the HPOP ( High Pressure Oil Pump) that drive the Injectors in the 7.3 as the 7.3 was noted for sheering some brands of oil early on.
Looking back on it, I wouldn't have an issue using the Rotella T6 5w40 in the 7.3, it is really a good oil. I use the Rotella T6 5w40 in my 2011 Ram 3500 Cummins, no issues at all. As a matter of fact, I am the member of the Shell Rotella Website which allows you to cash in on Shell Products and other Merchandise on their website.
Much continued success with your 2002 F350 with the legendary 7.3, hang on to it as long as you can.
Re: schaeffers or ? [Re: longbowhntr] #5276018 11/24/19 07:38 AM
T
T
By the way, there is a great website for the Power Strokes incase you were not aware. powerstrokehelp.com this guy is very knowledgable.
Re: schaeffers or ? [Re: longbowhntr] #5276063 11/24/19 08:50 AM
L
L
I tried to run mobil delvac esp1 5/40 in it once and it seemed to crank longer to start I took it to the dealer i bought it from and had them hook it up to the computer thought something was wrong and he said it was starting within specs and all the pressures where fine,talked to another diesel shop he said he's never heard of anyone running 5/40 in a 7.3 to change it back to 15/40 as soon as I did it started starting quicker for some reason not sure why.I don't run it alot in the cold if i do i plug it in the night before i drive it.
I have been offered 25,000 for the truck a couple of times i just don't want to spend 50,000 more to get a new one with all the emissions on them and having to use def fluid I can at least work on this one if I have to.I have seen bill on powerstroke help.com he has some pretty good info on there.
Re: schaeffers or ? [Re: TiredTrucker] #5276064 11/24/19 08:52 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Absolutely right - does it matter? No. I’ve never been a PAO purist, though many on here are. You made fine points, and so I don’t see much more to add. Good points!
Re: schaeffers or ? [Re: longbowhntr] #5276111 11/24/19 10:01 AM
T
T
I would hold onto your 7.3 as long as possible. The 7.3 is a favorite with the Power Stroke folks. When I had my 2002 F350 7.3, I changed the oil and oil filter every 5000 miles or 6 months, never had any issues. Of course the front end would get greased as well. My oil was never really dark or dirty each oil change.
Now, with my 2011 Ram 3500, the oil and filter is changed every 5000 miles or 6 months. The owners manual states every 7500 or 6 months. Due to the emissions stuff on my Cummins, the oil gets dark five minutes after changing. The emissions stuff started showing up on the 2007 and newer diesels when the fuel changed (ULSD). I always use the Rotella T6 5w40 and either the Mopar or Cummins oil filter. Cummins makes the filters for Mopar for the Cummins Diesel, both good filters.
