Pennz Plat 5W30, 4,786 miles, 2017 Honda 1.5T
by chinee - 01/27/20 07:11 PM
Quaker State deal
by JohnnyJohnson - 01/27/20 06:46 PM
A new deal on Castrol Edge EP 5W-30
by JohnnyJohnson - 01/27/20 06:37 PM
Burning smell from rear wheel
by 2010Civic - 01/27/20 06:01 PM
2017 VW Golf 1.8T - Valvoline 5w40 MST - 8,600 miles
by BurntMusic - 01/27/20 06:00 PM
Cost to rebuild a Ford 4R75E vs. new or used.
by atikovi - 01/27/20 05:26 PM
Autozone Clearance 85w140 gear oil 5 gal
by GON - 01/27/20 04:31 PM
Resonating Noise at 3000rpm
by tookien - 01/27/20 04:28 PM
Looking for Purolator Tech oil filter pics.
by Black_Thunder - 01/27/20 04:02 PM
2019 Mini Cooper Clubman S ALL4 Review
by oilpsi2high - 01/27/20 02:51 PM
The "Penny Challenge"
by ZeeOSix - 01/27/20 02:32 PM
2008 Highlander Battery Post Bolt Snapped
by maverickfhs - 01/27/20 02:31 PM
conventional wisdom rebuild axle or replace?
by NissanMaxima - 01/27/20 01:22 PM
will a thermostat gasket leak coolant into the engine?
by motor_oil_madman - 01/27/20 12:55 PM
Swiss F/A-18C Demo
by Malo83 - 01/27/20 12:43 PM
Technical Service Bulletin Availability
by SubLGT - 01/27/20 12:40 PM
GM Goes All In on EVs: Pickups & SUVs
by SubLGT - 01/27/20 12:11 PM
2019 Jetta 1.4t Rental Review
by javacontour - 01/27/20 11:55 AM
H20ham, Meletz, yagciogullari, roadrnnr, Burner718
70541 Registered Users
139 registered members (4WD, 2010Civic, 53' Stude, 3MillerBoys, 25ring, 928, 15 invisible), 2,561 guests, and 19 spiders.
Topics300,650
Posts5,180,201
Members70,541
Page 2 of 2 1 2
Re: Crysler Crossfire Pro/Con? [Re: tc1446] #5274799 11/22/19 05:38 PM
CT Rob Offline
When i worked at the Chrysler dealer ,we couldnt give them away.We had one for almost 2 years b4 they basically gave it away.
2017 Toyota Tundra SR5 Crewmax 4x4 Trd offroad.Inferno Orange.All stock for now....
Re: Crysler Crossfire Pro/Con? [Re: CT Rob] #5274807 11/22/19 05:49 PM
CharlieBauer Offline
I knew what you meant!
cheers
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: Crysler Crossfire Pro/Con? [Re: tc1446] #5275174 11/23/19 07:08 AM
E
ET16 Offline
E
I looked at a couple of them. The interiors don't seem to hold up well. Some Mercedes shops won't touch them.
Re: Crysler Crossfire Pro/Con? [Re: tc1446] #5275184 11/23/19 07:25 AM
W
wings&wheels Offline
W
Friend's parents have one. They enjoy it and there haven't been any major issues that I recall.
They are a relatively low production vehicles and some parts may become more difficult to get, but otherwise cant think of any reason not to if you really want one. You certainly wont see another one every day.
Even the worst convertible (and this surely is not) gets you in the sun on a good day, add in a manual transmission and its a recipe for fun.
'05 Lotus Elise S/C
'85 Land Rover 90 diesel
'74 Triumph TR6
'74 BMW 2002
'72 Land Rover Series III 88"
'99 Porsche 996 (Wife's)
'01 Porsche Boxster S (mostly Wife's...)
Piper Pa28-236
Re: Crysler Crossfire Pro/Con? [Re: tc1446] #5279369 11/28/19 12:23 AM
B
Bladecutter Offline
B
My wife bought a 2008 Roadster (6 speed manual) brand new in Oct '08, and it wound up being the most mixed ownership experience we have ever had in a car.
[Linked Image]
Driving it was fun, and when you replaced the Continental EcoSport tires with something that actually sticks to the road, the driving experience is enhanced greatly.
What wasn't fun?
Having it go back to the dealership over and over again due to warranty repairs.
The car had well over $21k in warranty work done in the 3 years we owned it.
There was an issue with the main grounding point for all of the main computers that wound up taking out the BCM several times, the Air Bag ECU once, The SKREEM unit once, the ECU once, and causing trip after trip to the dealership for repairs for several months straight until they tracked down the source of all the issues.
Here's a picture of how well the car was put back together after one of these repair visits, when we got home, and had trouble getting the trunk open:
[Linked Image]
[Linked Image]
Yes, that's their tools for removing the body trim, along with all the parts just laying in the trunk, with the panel hanging by its emergency escape cord.
Then later, there was a defect in the clutch where a spring in the pressure plate broke, and it took out the clutch and the flywheel at the 9k mile mark.
So, we had to wait a week or so for the flywheel to arrive from Germany, which after the car was repaired, and was handed over to me, I learned that the car WOULD NOT rev over 3k rpms, where it would shut off 1 bank of cylinders on the drive home. That meant that the dealership didn't test drive the car after they repaired it. Turns out, the flywheel was dropped, and the tone ring damaged, somewhere between the factory in Germany, and install on the car. That, of course, meant several more weeks while we waited for yet another flywheel to be sourced in Germany and shipped to Colorado.
Then at 11k miles, a common issue popped up with the engine starting to leak oil from a part on top of the valve covers that was not well sealed from the factory (not enough gasket sealer that dried out, and started weeping), so I decided to pop off both covers, and repair it myself, instead of taking it to the dealership and having them screw up the car one more time.
The biggest problem was that at the same time that we owned the Crossfire, we also owned a 1998 Boxster, and that car, during the exact same time period, had less mechanical problems than the Crossfire, and it had ~80k miles when we bought it. The Boxster drove better, had better handling, better brakes, was more reliable as a used purchase, and was just more fun to drive either as a daily driver, up in the mountains, or out at HPR, a road course racetrack.
The final straw with the car was when we had parked the car, and was closing the convertible top, when the front of the top slammed shut hard, without any warning, and nearly took off my daughter in laws fingers as she was reaching up to work the latch. We drove it to a Fiat dealer in Texas to trade it in for a Fiat 500 Sport just to get rid of it as thoroughly as possible. We never wanted to see it again, and driving it 800 miles away was worth it to us.
[Linked Image]
You literally could not pay us enough to ever own one again.
I don't have much good to say about the Crossfire Forum, either.
Way too many people who are overly fixated on the fact that its a Merc under the Chrysler badge, and think that owning a Chrysler badged Merc built product somehow makes them members of the Elite class.
BC.
2014 Mazda CX-5 Touring (Soul Red)
2015 Porsche Cayman
2007 Ducati 848
1988 Honda Hawk GT
Page 2 of 2 1 2
