Liqui moly viscoplus
by Toh1 - 12/07/19 10:14 PM
Bought me a lemon 15 focus
by gabriel9766 - 12/07/19 10:12 PM
New axle fixed steering pull?
by Chris142 - 12/07/19 09:52 PM
E-core super tech vs Fram orange can 10k
by Doublehaul - 12/07/19 09:01 PM
Interesting trend at my local walmarts
by N Heat - 12/07/19 08:39 PM
Stp S2 oil filter come with silicone ADBV for $4.99
by MetalSlug - 12/07/19 07:50 PM
RATS
by MrQuackers - 12/07/19 07:46 PM
First Day of Summer in New Zealand.
by Silk - 12/07/19 07:02 PM
Gumout Regane Complete 6pk for $22.79
by volk06 - 12/07/19 06:15 PM
Basement sewer smell/Plumbers info req'd.
by irv - 12/07/19 06:03 PM
Project Farm tests car batteries
by cwilliamsws6 - 12/07/19 05:59 PM
Is this normal?
by TurboLuver - 12/07/19 05:12 PM
Any Scooter Riders?
by Passport1 - 12/07/19 03:20 PM
High Performance Lubricants
by wwillson - 12/07/19 02:27 PM
Student laptop needed.
by irv - 12/07/19 01:13 PM
4 unifi AP
by BeerCan - 12/07/19 12:25 PM
Another OCD battery ?
by Gebo - 12/07/19 11:45 AM
High school football championships
by 53' Stude - 12/07/19 10:57 AM
It's raining in the Bay Area
by JeffKeryk - 12/07/19 10:28 AM
smlobx, bithebay87, Keelin, professor229, MxTale
70063 Registered Users
35 registered members (clinebarger, carlprop, bdcardinal, brages, 264mag, allepunta, 3 invisible), 957 guests, and 52 spiders.
Topics298,428
Posts5,135,246
Members70,063
Most Online3,589
Nov 2nd, 2019
Dynamat (well budget brand) a dishwasher success. #5274826 11/22/19 06:14 PM
P
pezzy669 Offline OP
P
So I have a ~20 year old GE Nautilus builders grade edition dishwasher in my condo that was installed when the place was built in 2000. The dishwasher is a beast and (knock on wood) I have not had any issues with it in the 2 years I have lived here. It along with the multiple Nautilus dishwashers I experienced over the years (they were apparently an early 2000's apartment complex favorite) have always cleaned exceptionally well but were always incredibly noisy. Well I finally figured out why when I pulled my current machine door apart to clean out a gunked up rinse aid dispenser - ZERO insulation or sound deadening mat in the front door, just the plastic inner door panel and the thin sheet metal exterior.
So ordered a box of Noico 80 mil sound deadening mat designed for cars (much cheaper version of Dynamat) for $12.99 on Amazon and a $6.99 roller meant to buff the mat onto the mating surface and went to work once it was delivered. Took me ~1 hour to do the full panel of the sheet metal door and ~65% of the plastic interior door, glad I did not get 2 boxes because I would have had a lot of excess.
So here are the noise measurements I took before and after using a app called NIOSH SLM on my iPhone. Both were empty loads when it is loudest, can't wait to see how quiet it is with a full load.
Top at latch:
Before:
Phone at latch - 77 db
1' away from latch - 64 db
After:
~1" latch - 74 db (3db reduction)
1' away from latch - 60 db (4db reduction)
Mid way down center of door:
Before:
~1" from sheet metal - 69 db
1' away from sheet metal - 67 db
After:
~1" from sheet metal - 64 db (5db reduction)
1' away from sheet metal - 62 db (5db reduction).
Bottom at door and motor cover plate gap:
Before:
~1" from panel gap - 73 db
1' away from panel gap - 70 db
After:
~1" from panel gap - 68 db. (5 db reduction)
1' away from panel gap - 66 db (4db reduction)
Overall:
This was probably the best $20 I have spent to limp this dishwasher along until I can gut and remodel my kitchen which is still 1-2 years down the road. I could probably get some further noise reduction replacing the quite expensive ($52+$10 shipping) perimeter door seal that is hard as a rock but it does not leak so I'm good with the noise reduction the sound deadening mat.
Anyhow just wanted to share my experience, was not sure what to expect going into this project but ended up quite pleased.
2012 Volkswagen Jetta Sportwagen TDI - 69k - Castrol Edge Professional LL03 5W30
2011 Volkswagen Jetta Sportwagen TDI - 49k - Castrol Edge Professional LL03 5W30
Re: Dynamat (well budget brand) a dishwasher success. [Re: pezzy669] #5274874 11/22/19 07:04 PM
M
mightymousetech Offline
M
Very nice. I did the same at our old house. Made a nice difference. When you look at a range of dishwashers within a brand, most of the difference between the cheapest model and the most expensive is the amount of sound deadening.
Mighty Mouse Tech
BMW Diagnostic and Alignment Tech
2013 BMW 135i M Sport Edition Motul 0W40, MTL/MT-LV
2010 BMW 328i X-Drive, BMW 0W30, MT-LV
Re: Dynamat (well budget brand) a dishwasher success. [Re: pezzy669] #5274904 11/22/19 07:36 PM
4WD Offline
That high density rubber will kill attenuation but not block all frequencies …
I found a great combo is dynamat with 3M CCF stuck on top …
(also scissors and peel/stick)
Re: Dynamat (well budget brand) a dishwasher success. [Re: 4WD] #5274942 11/22/19 08:07 PM
P
pezzy669 Offline OP
P
Thanks for the heads up - maybe a dumb question but what is 3M CCF?
I'm going to have to pull the door apart again in the near future because the rinse aid tank has a very slow leak at one of the seams so it will be wide open to add some additional sound attenuation material. Might give the 3M layer a go if its not too crazy expensive.
Thanks in advance!
Re: Dynamat (well budget brand) a dishwasher success. [Re: pezzy669] #5274946 11/22/19 08:10 PM
4WD Offline
Closed cell foam … easy to find online …
Try eBay
Re: Dynamat (well budget brand) a dishwasher success. [Re: pezzy669] #5275001 11/22/19 09:29 PM
1
14Accent Offline
1
Jeeze, are old dishwashers really that loud? I have a circa 2012 "Ikea" (Whirlpool) dishwasher and I can barely hear it running. I took the door apart a month ago to replace the latch, and I don't remember seeing any insulation or sound deadening inside. It's so quiet I've found myself walking into the kitchen, 15 feet away or so, just to see if I remembered to hit the start button.
Either way, cool project! Glad to hear it worked out.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: Dynamat (well budget brand) a dishwasher success. [Re: pezzy669] #5275048 11/22/19 10:28 PM
DallasTexas Offline
Bosch fan here.
06 E320 CDI 98k miles
14 Sienna 33k miles
96 E300 297k miles Donated
Re: Dynamat (well budget brand) a dishwasher success. [Re: 14Accent] #5275051 11/22/19 10:37 PM
4WD Offline
Pretty much … replaced a 15 year old GE with an all stainless Maytag (inside/outside) a few months back … huge difference …
Re: Dynamat (well budget brand) a dishwasher success. [Re: pezzy669] #5275170 11/23/19 07:04 AM
E
edwardh1 Offline
E
most Bosch dw are quiet.
I dont buy any other Bosch products though
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Dynamat (well budget brand) a dishwasher success. [Re: 14Accent] #5275420 11/23/19 12:06 PM
P
pezzy669 Offline OP
P
Oh yeah it seems the low-mid grade dishwashers never really had any merit in the sound attenuation department until prob the late 2000's early 2010's. I think improvements in the design of the water jets was the majority of the sound reduction, stainless steel interior tubs are supposed to be a huge reduction as well vs the plastic.
My apt before my condo had a 2015ish Whirlpool that was mid-grade ($500-600) and it was like yours where you had to be basically right next to it to hear a little splashing here and there.
Just to give you reference of noise, you know the commercial grade washers in restaurants and bars? Thats about how this dishwasher sounded before the sound matting.
