Price jacked up on Chevron Supreme at WM?
by Whammo - 12/12/19 11:23 PM
valvoline durablend 5w-30 in yaris, ok?
by jstert - 12/12/19 11:02 PM
Outsmarting RA’s Shipping Lunacy
by The_Nuke - 12/12/19 11:00 PM
Odd Ball!??
by miden851 - 12/12/19 09:40 PM
fedex lost package . how does it work?
by WhyMe - 12/12/19 09:39 PM
RTG 5W-20
by kstanf150 - 12/12/19 09:12 PM
First time running synthetic in my truck
by leeaspell - 12/12/19 09:05 PM
2007 Honda Accord Transmission
by maverickfhs - 12/12/19 07:59 PM
Detriot Axle brake kit review
by 14Accent - 12/12/19 07:51 PM
PQIA Issues An Alert!
by Jackson_Slugger - 12/12/19 06:36 PM
Late night commotion outside.
by LeakySeals - 12/12/19 06:27 PM
Help with Dewalt tools
by henni - 12/12/19 06:19 PM
Educate me on USB drives, devices
by 53' Stude - 12/12/19 05:55 PM
9012 bulb lasted 2 yrs... good?
by mclasser - 12/12/19 05:43 PM
2020 YUGO
by Malo83 - 12/12/19 04:53 PM
Ice on inside of windshield
by JLawrence08648 - 12/12/19 04:41 PM
AC DELCO PF 63E CUT OPEN
by 53' Stude - 12/12/19 04:10 PM
Does old adhesive need to be removed for vinyl planking?
by JLawrence08648 - 12/12/19 04:06 PM
mb20music, Jaglenn, kalima, Powertool1994, lutvi20
70115 Registered Users
45 registered members (carlprop, boulderdentist, alcyon, Blaze, alchargo, 1WildPig, 2 invisible), 1,098 guests, and 31 spiders.
Topics298,666
Posts5,140,042
Members70,115
Most Online3,589
Nov 2nd, 2019
Citgo Transgard ATF+4 seems quite different from other ATF+4 #5274756 11/22/19 04:43 PM
cvlw Offline OP
Yo Oil Guys.
I recently did a siphon/fill of my daughter's car power steering as noted here: post on bitog
That got me thinking about next year when I do this to her car again. So I did some research on Chrysler ATF+4 certified brands.
I found that most were basically the same except for Citgo Transgard ATF+4. For some reason, according to their product data sheet, it is nearly on par with Redline C+, particularly for the pour point. I know pour point is not the ultimate factor, but, it is a good consideration. I live in Minnesota and the depth of winter can see some mighty cold temps. And I have heard it said that ATF+4 is a tight spec.
What do you guys think? is this Citgo ATF+4 better than most of the others?
Appreciated.
cvlw
Citgo Transgard ATF+4 shows a Pour Point of -70f/-57c
Redline C+ shows a pour point of -76f/-60c
Valvoline ATF+4 shows a pour point of -54f/-48c (I used this in my daughter's car)
Citgo ATF+4 PDS
Valvoline ATF+4 PDS
Redline C+ PDS
Re: Citgo Transgard ATF+4 seems quite different from other ATF+4 [Re: cvlw] #5274769 11/22/19 04:59 PM
2015_PSD Offline
I asked a similar question about ATF+4 not too long ago (https://www.bobistheoilguy.com/foru...which-atf-4-would-you-choose#Post5233271) and many posted that due to the strict licensing requirements from FCA they are all the same. I cannot dispute that, but I do see some ATF+4 labeled "synthetic" and others are not labeled at all.
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Mahle]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: Citgo Transgard ATF+4 seems quite different from other ATF+4 [Re: cvlw] #5275443 11/23/19 12:39 PM
MolaKule Offline
Global Moderator
Global Moderator
Originally Posted by cvlw
...cvlw
What are the Brookfield viscosity values between the various ATF fluids you've looked at?
"Dr. Larry Fleinhardt:
You know that it's considered unsolvable?
Charlie Eppes:
Well, certainly people who have failed to solve it might think that." From NUMB3RS
Re: Citgo Transgard ATF+4 seems quite different from other ATF+4 [Re: cvlw] #5276086 11/24/19 09:35 AM
cvlw Offline OP
I had to do some research to try and understand the Brookfield.
citgo: 9000 cP at -40C / 2050 cP at -28.9C
valvoline: 9000 cP at -40C / {no info on higher temp}
Redline: 38 at -40C {what does 38 mean here?}
The Citgo and Valvoline have the same cP at -40C. I don't, yet, understand the number for Redline. Since -40C is already soul-cringing cold, at best both fluids are the same and my question is answered. At worst, there is maybe a petty difference if graphed out across a range of temps leaving nothing but nitpicking.
The fact that ATF+4 is a tight spec seems to hold true. I saw other bitog comments that Redline C+ is really a "boutique" vs any other ATF+4 and those seem to hold true as well.
Brookfield very generally measures fluid resistance to flow and a lower number indicates that it is LESS resistant to flow. So,I guess this measurement is more aligned with "will it pump?" versus "will it dump (out of the bottle)?".
Thanks.
cvlw
