Amazon Packaging
by SubLGT - 12/05/19 02:21 PM
Does a dealer send your paperwork to the
by WhyMe - 12/05/19 02:04 PM
Cheapest option for insurance?
by cwilliamsws6 - 12/05/19 01:31 PM
Volvo T6 (SI6) oil
by posaune - 12/05/19 12:59 PM
Strange VRLA AGM battery issue
by pschnahc - 12/05/19 12:20 PM
Slight whining on power pump.
by Umit - 12/05/19 12:15 PM
Mobil 1 video
by njohnson - 12/05/19 12:06 PM
F150 Syn 3 map updates, finally!
by wallyuwl - 12/05/19 11:49 AM
Visom and GTL Question
by Doublehaul - 12/05/19 10:42 AM
SuperTech 5-30 HM Full Synthetic 5qt. $14.37
by mbz321 - 12/05/19 10:09 AM
Mechanics and come backs
by motor_oil_madman - 12/05/19 08:33 AM
Camping World Labor Rate
by Redright9 - 12/05/19 08:09 AM
Best Batt Maintainer
by Smoky14 - 12/05/19 07:30 AM
MOPAR OEM floor mats
by OVERKILL - 12/05/19 07:22 AM
Pressing Index Finger on Forehead
by Gebo - 12/05/19 06:39 AM
Drove a 6spd manual yesterday...don't miss it
by wemay - 12/05/19 06:20 AM
Ronparise, DrPcFix, benny88, Blazs, UnderDawgAl
70041 Registered Users
104 registered members (AC1DD, 14Accent, 4WD, alchargo, Aero540T, 6 invisible), 2,640 guests, and 38 spiders.
Topics298,328
Posts5,133,095
Members70,041
Most Online3,589
Nov 2nd, 2019
DIY Spray Foam #5274729 11/22/19 04:19 PM
coopns Offline OP
Would like to spray foam the rim joyce of one side of house. I just jammed insulation as much / far as I could.
Had a quote $1200...bit heavy for me but I understand, got to bring in
the big truck, prep.
So I saw the big Dow Great Stuff Pro with the gun, fairly big cans. Here is one on Amazon.
Anyone have much experience/recommendations?
Coop
Re: DIY Spray Foam [Re: coopns] #5274739 11/22/19 04:27 PM
J
JC1 Offline
J
When I finished my basement I sprayed the end of the joists with the regular cans of red dow spray foam.tbe big stuff. Just go slow and steady and let it stick to the wood a bit at the bottom before you go full blast.
Are you trying to seal drafts?
You could use those guns of you want, bit the regular cans work too. Did you estimate how many cans you'll need? Buy extra you can return the unused cans once you are done.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: DIY Spray Foam [Re: coopns] #5274742 11/22/19 04:31 PM
cpayne5 Offline
I wouldn't use those cans to do this job. It will be tedious. But, lots of people use the cans in conjunction with rigid foam board insulation. There's a bunch of videos on YouTube that show the basic method.
Re: DIY Spray Foam [Re: coopns] #5274809 11/22/19 05:50 PM
W
Warstud Offline
W
That would be Rim Joist.
Re: DIY Spray Foam [Re: coopns] #5274819 11/22/19 06:05 PM
W
Warstud Offline
W
FYI....You shouldn't Jam or Pack insulation because the wood won't get proper ventilation.
Check one of the Home Improvement stores to see if they loan out Spray Foam Equipment.
Re: DIY Spray Foam [Re: coopns] #5274824 11/22/19 06:11 PM
M
maxdustington Offline
M
What you need is something like this: https://www.homedepot.ca/product/to...ent-spray-foam-insulation-kit/1000718744
Those guns with replaceable cans are more for contractors who install a lot of windows and doors, I believe you can seal and reuse them as long as the can is not removed. The aerosol can is a single use item. You need more volume and expansion to seal a rim joist cavity.
You can also apply fibreglass insulation and vapor barrier like a normal stud wall if you want to. It's one of the messiest tasks I have ever done.
99 Toyota Tercel CE 5EFE/C151
Re: DIY Spray Foam [Re: coopns] #5274965 11/22/19 08:35 PM
Donald Online Content
Online Content
I would cut pieces of foam for the rim joist. And seal with caulk.
The twin tanks of spray need to be sprayed at a certain temperature and there are some issues about how long you can wait after stopping spraying and start spraying again. You may need to change tips or something if there is significant time between stopping and starting up. Check on that before starting.
2015 Ford F250 w/Powerstroke
Re: DIY Spray Foam [Re: coopns] #5275016 11/22/19 09:44 PM
E
E365 Offline
E
I’ve used the Dow Froth Pak. Two small tanks mixed at the nozzle. $300 I think to do the rim joists in my previous, little rambler.
Excellent results, but you need to seriously prepare. Everything exposed and ready to go, critical surfaces covered, Tyvek suit, eye protection, etc.
Whatever's on sale...
Re: DIY Spray Foam [Re: Donald] #5275238 11/23/19 08:38 AM
A
alarmguy Offline
A
Agree ^^^ its a valid method over just using plain spray foam.
Get nice thick foam board, put it up and seal with spray foam. Much more simple for the DIY and many professionals will also use the same method.
Me personally would spray some foam along any seams, place the foam board in right away and seal again with the spray foam..
Here is an example
______
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
