Castrol and NASCAR
by kstanf150 - 01/22/20 01:14 PM
AMSoil Signature / AMSoil European - 5-40
by 335xiE92FBO - 01/22/20 12:06 PM
How happy are you in your profession ?
by Mr Nice - 01/22/20 11:52 AM
Npt fitting torque?
by motor_oil_madman - 01/22/20 11:47 AM
Tracing wires in walls
by Dave Sherman - 01/22/20 11:32 AM
WM Castrol HM magnatec 6 GALLON BOX $45
by GMguy84 - 01/22/20 11:30 AM
Steering Lubricant Suggestion
by lancerplayer - 01/22/20 11:08 AM
Neglected AW55-50 - Plan Of Attack?
by Bailes1992 - 01/22/20 09:14 AM
BMW caliper pins, no lube?
by ledslinger - 01/22/20 08:58 AM
Glock 44
by bradepb - 01/22/20 08:04 AM
Open up area in basement
by redhat - 01/22/20 07:42 AM
Briggs Intek Leaking Crankshaft Oil Seal
by UncleNorby - 01/22/20 06:26 AM
1ZZ-FE MR-2 (weekends and trackdays)
by geetar - 01/22/20 04:58 AM
Did Rotella Ever Have JASO MA Certification?
by BBDartCA - 01/22/20 12:49 AM
Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
MOVIE: Dr. Dolittle
by Kira - 01/21/20 09:34 PM
Phildrum, 335xiE92FBO, oldrover, sarojasaruu, someoldguy
70503 Registered Users
106 registered members (53' Stude, Astro14, 1WildPig, 2011335d, AndyB, 1978elcamino, 8 invisible), 2,610 guests, and 20 spiders.
Topics300,430
Posts5,175,613
Members70,503
Page 2 of 2 1 2
Re: 2002 Avalon-Original coolant. Change out to? [Re: FXjohn] #2989905 04/30/13 09:44 PM
ChiTDI Offline
Ah, didn't know.
50k on a 2002, you got a plum!
I put 165k on mine before passing to the next generation in the family. Good luck with yours!
Re: 2002 Avalon-Original coolant. Change out to? [Re: ChiTDI] #2990656 05/01/13 06:21 PM
F
FXjohn Offline OP
F
Originally Posted By: ChiTDI
Ah, didn't know.
just taking care of it for an older family member. I'm going to get new tires, new coolant, cabin filter, trans fluid, power steering fluid.
it's never seen salt!
Re: 2002 Avalon-Original coolant. Change out to? [Re: FXjohn] #2992264 05/03/13 12:21 PM
ChiTDI Offline
You might have two drain plugs for the ATF/differential. Mine did.
Yes, ATF for the FWD differential, and it was a common fill from the dipstick. Drains were separate, so just an FYI.
Diff plug was on the front of the housing, and allowed another quart to drain.
Re: 2002 Avalon-Original coolant. Change out to? [Re: ChiTDI] #2992459 05/03/13 04:24 PM
F
FXjohn Offline OP
F
I'm gonna have it done at the dealer, but that's the only thing left to do now. Unless I forgot something. I did double check, it has 62k on it.
I can't believe how sucky the positive terminal is. especially compared to side terminals.
Re: 2002 Avalon-Original coolant. Change out to? [Re: FXjohn] #2993837 05/05/13 01:19 PM
ChiTDI Offline
Yeah, mickey mouse clamp if I remember right.
I'd have the dealer change the PCV valve too, if it was me. They only cost a finn, but those 1MZ-FE engines can get sludge if they are ignored.
62k - Probably run another 10 years easy.
Re: 2002 Avalon-Original coolant. Change out to? [Re: ChiTDI] #2994088 05/05/13 06:54 PM
F
FXjohn Offline OP
F
thanks I'll have that done too. this is the xls with the lexus motor. compared to my truck this thing is a sports car. it sets you back in your seat.
Re: 2002 Avalon-Original coolant. Change out to? [Re: FXjohn] #2999942 05/12/13 12:45 PM
The Critic Offline
If it still has the original timing belt and water pump, I would use this opportunity to have a complete timing belt job done due to age.
And when the water pump is done, the coolant will also be done.
2011 Toyota Prius 1.8L - 202K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
Re: 2002 Avalon-Original coolant. Change out to? [Re: FXjohn] #4395587 05/03/17 02:41 PM
W
WillsYoda Offline
W
The 2002 1mzfe does not sludge. They redesigned it. I'd change out the PCV with OEM nevertheless (it costs 5 bucks).
G05 is fine, but Toyota Red has always worked very well for our toyotas. It isn't that much more.
Re: 2002 Avalon-Original coolant. Change out to? [Re: FXjohn] #5215446 09/17/19 04:01 PM
B
Bonnelvr92 Offline
B
If the coolant is not too dirty or the coolant is cooling the engine just fine I wouldn't worry about changing it. Now if your coolant is dirty, and causing problems, or if it is not cooling the engine right, then I would change it.
Re: 2002 Avalon-Original coolant. Change out to? [Re: WillsYoda] #5233235 10/07/19 05:25 PM
L
littlehulkster Offline
L
Even then I think the sludge problems with Toyotas were actually maintenance problems. The so called "sludge monsters" never seen to sludge if you use synthetic oil in them and change it at a reasonable interval.
2015 Mazda3 I 2.0
Re: 2002 Avalon-Original coolant. Change out to? [Re: The Critic] #5249294 10/24/19 07:40 PM
T
tundraotto Online Content
Online Content
T
^THIS...and if your too frugal...then why worry about the coolant either....timing belt needs done eventually.
Re: 2002 Avalon-Original coolant. Change out to? [Re: FXjohn] #5273628 11/21/19 12:44 PM
Z
zzyzzx Online Sleepy
Online Sleepy
Z
Change it to this:
[Linked Image from d2ul0w83gls0j4.cloudfront.net]
I use it in a bunch of vehicles.
Re: 2002 Avalon-Original coolant. Change out to? [Re: FXjohn] #5273994 11/21/19 08:27 PM
N
N Heat Offline
N
If the OP used Toyota SLL, hes probably due to change out the coolant that he put in 2013 when he started this topic.
Page 2 of 2 1 2
