Topics298,632
Posts5,139,575
Members70,113
Most Online3,589 Nov 2nd, 2019
1988 Toyota Pickup ST Full Synthetic 5w30, 5k miles on oil, 133xxx on engine
#5273274
11/21/19 03:26 AM
Yota88
OP
OP
Posts: 16 |
To me this oil sample seems pretty good. I changed the oil then did a radiator replacement so I think that’s why some metals might be higher. Just a thought. Let me know what you guys think
Re: 1988 Toyota Pickup ST Full Synthetic 5w30, 5k miles on oil, 133xxx on engine
[Re: Yota88]
#5273283
11/21/19 03:59 AM
Char Baby
Posts: 11,962 |
Well, IDK but others may. Are you going to do another UOA again at 5K miles? If so and the wear metals do in fact decrease in that next UOA, I'd then go 6K miles on your OCI.
"Retired" -----------------------------------
'80 Firebird FORMULA V8/4bbl-purchased "NEW" '15 Nissan Altima 2.5 SV '15 Honda Civic 1.8 LX
[Re: Char Baby]
#5273285
11/21/19 04:09 AM
Yota88
OP
OP
Posts: 16 |
Yes I will do another sample after another 5k miles
[Re: Yota88]
#5273319
11/21/19 06:15 AM
JohnnyJohnson
Posts: 5,667 |
How much oil does it consume in a 5K OCI?
2004 Corolla 137480 Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457 In: Pennzoil Platinum HM 5W-20 ST 4386 2006 Duramax 76862 Out: T6 5W-40 XG9100 73909 In: Rotella Dino PH9100 11-3-19
[Re: Yota88]
#5273416
11/21/19 08:38 AM
BigD1
Posts: 3,378 |
Never done an oil analysis on my 92 22RE. Mine has just over 200,000 now on the engine and 312,000 on the truck. It's using about a quart every 3,000 miles. It does have some oil pan weeps, but it's nothing major at the moment.
Keep an eye on the driver side timing chain guide!
1992 Toyota Pickup--AmazonBasics Conventional--10W-30--Toyota 90915YZZD1
[Re: Yota88]
#5273429
11/21/19 08:47 AM
ARCOgraphite
Posts: 13,937 |
Not good but I feel other issues are at play here.
Was the engine near overheating?
And whats with this seafoam comment? Did you do a sump or TB clean?
That will mess things up.
Don't put that seafoam which has become for no reaosn "all the internet rage amongst no-nothings" junk in your engine.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
[Re: JohnnyJohnson]
#5273452
11/21/19 09:29 AM
Yota88
OP
OP
Posts: 16 |
[Re: ARCOgraphite]
#5273458
11/21/19 09:35 AM
Yota88
OP
OP
Posts: 16 |
You think this report isn’t good? My temp gage never went past 1/4 where it always stays. I did not put seafoam in vehicle. I only asked if I put it in the oil would it alter the oil test results. I’ve always heard good things about seafoam do you have any bad experiences you can share?
[Re: Yota88]
#5273473
11/21/19 09:56 AM
Brons2
Posts: 3,234 |
Sodium and Potassium is something to keep an eye on. It doesn't look like the oil is formulated with it, it's usually in the 300-400 range if it's part of the add pack. I don't know why the radiator change would put coolant in the oil unless you have a front mounted oil cooler that you disconnected as part of removing the radiator.
Also, your silicon is somewhat high at 17ppm for 5000 miles, check your air filtration.
Otherwise the viscosity and TBN look good for a longer interval. I agree to check back in 5K and see where you're at with the P, Na and Si.
2012 Hyundai Sonata GLS 6MT 2.4GDI, ProDS 5w & 10w30 seasonal, XG9688 filter, 2018 Mitsubishi Outlander SEL 2.4 CVT, Dealership Castrol 0w20, Mazda filter.
[Re: Yota88]
#5273851
11/21/19 05:22 PM
ARCOgraphite
Posts: 13,937 |
You think this report isn’t good? My temp gage never went past 1/4 where it always stays. I did not put seafoam in vehicle. I only asked if I put it in the oil would it alter the oil test results. I’ve always heard good things about seafoam do you have any bad experiences you can share? So it was just a radiotor leak? I dont know what "never went past 1/4" means. Most temp gauges are at temp a "12 o'clock - straight up. I will say, don't run a cool thermostat - run factory spec - or no more than 10 deg cooler.a Its kinda cool you have an '88 with only 133K miles!
[Re: Yota88]
#5273869
11/21/19 05:57 PM
JohnnyJohnson
Posts: 5,667 |
That pretty good lots of BITOGers would give their eye teeth if they could match that.
[Re: ARCOgraphite]
#5273966
11/21/19 07:40 PM
BigD1
Posts: 3,378 |
You think this report isn’t good? My temp gage never went past 1/4 where it always stays. I did not put seafoam in vehicle. I only asked if I put it in the oil would it alter the oil test results. I’ve always heard good things about seafoam do you have any bad experiences you can share? So it was just a radiotor leak? I dont know what "never went past 1/4" means. Most temp gauges are at temp a "12 o'clock - straight up. I will say, don't run a cool thermostat - run factory spec - or no more than 10 deg cooler.a Its kinda cool you have an '88 with only 133K miles!  On these trucks, 1/4 is normal when the cooling system is right, and that's with a stock Toyota thermostat.
[Re: Yota88]
#5274692
11/22/19 03:38 PM
dave1251
Posts: 12,560 |
The wear metals are fine with the exception of lead then again this is why I don't recommend using seafoam.
make the inside of your engine oil cap white. don't use.
[Re: BigD1]
#5274758
11/22/19 04:44 PM
Al
Posts: 18,767 |
I think they put the nylon guards in after 1990. But I could be wrong. These nylon guides were a disaster. Took one of the best engines on the planet and screwed it up. Yes I would inspect the chain if you aren't sure. My '94 failed at around 90K miles. Fortunately it did not bend valves. I was lucky.
