Cam2 CVT fluid is green, and so is Transtar
by slacktide_bitog - 12/06/19 06:59 PM
Rotating Directional Tires for Dry Conditions
by CharlieBauer - 12/06/19 03:42 PM
Review: My 2011 Prius turned 200K
by The Critic - 12/06/19 03:29 PM
NIB sggcx2 dash cam
by BeerCan - 12/06/19 02:57 PM
Mazda FL22 alternative?
by jayjr1105 - 12/06/19 01:57 PM
Tips for sealing radiator hose
by Parlay_Slow - 12/06/19 01:51 PM
Valvoline
by Koncrete_Cam - 12/06/19 01:32 PM
At home tire rotation protocol question
by NissanMaxima - 12/06/19 12:57 PM
Base oil different in 0W vs 5W?
by doyall - 12/06/19 12:54 PM
Five Gees
by Y_K - 12/06/19 12:31 PM
Valvoline Dex/Merc Label
by 28oz - 12/06/19 12:23 PM
Storing a vehicle- advice please!
by Rolla07 - 12/06/19 11:53 AM
1964 Cub Cadet 100
by Phishin - 12/06/19 11:40 AM
2001 Volvo V70XC 6140 Miles Mobil1 10w-30 HM
by Astro_Guy - 12/06/19 11:22 AM
Blend door motor reset
by otis24 - 12/06/19 11:08 AM
My 68 L36
by JeffKeryk - 12/06/19 10:45 AM
2016 Accord 11,513 Miles Mobil1 5w-30 EP
by Astro_Guy - 12/06/19 10:15 AM
BajaBu, Bayoubrad, Fog42, glassmaker, PontiacHO
70052 Registered Users
84 registered members (4WD, BLND1, BAJA_05, Bookmaker, BeerCan, Audios, 7 invisible), 2,182 guests, and 56 spiders.
Topics298,383
Posts5,134,204
Members70,052
Most Online3,589
Nov 2nd, 2019
1994 Ford Tempo / Mercury Topaz Rear Brake Pressure Limiters #5273236 11/21/19 12:57 AM
Cdn17Sport6MT Offline OP
Folks, on the underside of the master cylinder for my 94 Topaz - for the lines that go to the rear drum brakes - there is a pressure reducing valve in-line... and immediately prior to where the line to the respective rear brake starts.
These are NLA - no longer available.
They were used on more than just the Topaz / Tempo.
What do folks suggest I use as a replacement for these two?
Mazda6 GX (Sport in the 'States), 6MT, 2017
Moto Guzzi 850 T5 (Euro version), 1985
Honda Civic Si (EX 2 dr. in the 'States), A/T, 1997
Toyota Camry CE, 5MT, 1999
VW (Type2) Kombi, 4MT, 1979
Re: 1994 Ford Tempo / Mercury Topaz Rear Brake Pressure Limiters [Re: Cdn17Sport6MT] #5273241 11/21/19 01:07 AM
P
pitzel Online Content
Online Content
P
I see 'em on Amazon in-stock. Not cheap (ie: a pair will probably cost you more than the book value of the car!), but still available. Lots on eBay as well.
Type that Ford Part number into Amazon or Google search, and it'll come up.
edit: https://www.amazon.com/Ford-F8UZ-2C161-AA-VALVE-ASY-CONTROL/dp/B000O09P7A
Change your thinking...not your oil!
Turn your mind....not your rotors!
Re: 1994 Ford Tempo / Mercury Topaz Rear Brake Pressure Limiters [Re: Cdn17Sport6MT] #5273243 11/21/19 01:21 AM
Thank you for your help thus far. Totally right re the cost... and the cost surmounting the value of the car!!
I'm actually not sure that that is the correct model number. And also, is it possible that these are residual pressure valves... used to keep a wee bit of pressure on the drum brakes of a disc/drum car?
If they are residual pressure valves, I wonder if a generic valve could easily be plumbed-in.
Re: 1994 Ford Tempo / Mercury Topaz Rear Brake Pressure Limiters [Re: Cdn17Sport6MT] #5273246 11/21/19 01:31 AM
P
Online Content
P
Hit up a pic'n'pull junkyard and take pull off a junked car or truck perhaps? They seem to have been used for a decade or so on F-Series, Econoline vans, Tempo/Topaz, etc. That's what I'd do before buying brand new stuff.
Re: 1994 Ford Tempo / Mercury Topaz Rear Brake Pressure Limiters [Re: Cdn17Sport6MT] #5273873 11/21/19 06:07 PM
super20dan Offline
doubt there any of these turkeys left on the road to matter. worse car ford ever made
99 silverado 5.3
2003 tundra v6
1981 toyota cressida wagon
2003 kia sorento
04 toyota highlander 4cyl 2013 toyota rav4
Re: 1994 Ford Tempo / Mercury Topaz Rear Brake Pressure Limiters [Re: pitzel] #5273882 11/21/19 06:18 PM
M
maxdustington Offline
M
You won't find much from last century in the yard anymore, and I used to frequent a great junkyard. The Junkyard sweet spot is 10-15 years for popular models. Trucks and vans are very often picked over because of their commercial uses.
99 Toyota Tercel CE 5EFE/C151
Re: 1994 Ford Tempo / Mercury Topaz Rear Brake Pressure Limiters [Re: Cdn17Sport6MT] #5274671 11/22/19 03:08 PM
Thx, All, re your input. Agree re finding one in the pic and pull. I also would prefer new ones.
I wonder if it is a residual pressure valve (10 psi) or some kind of pressure reducing valve. I am guessing, 'cuz it only has an in and an out port - that it is a residual pressure valve... to counter the brake springs.
If this is the case, then I wonder how brake balance is achieved... Would it be, say, the relative sizing of the front discs (and pistons) and the rear drums and wheel cylinders?
What I am thinking, here, is that a person could plumb-in this stuff... e.g. Willwood, or the like... and new stuff is available. It would take a few dry road (or wet road) tests.... with the proportioning valves (I would use two) set at progressively different lever-positions for ea. test...
I do wanna stay cheap... and rebuilt calipers and new rear wheel cylinders are cheap, cheap, cheap for this car...
Just wanna see if I can get it running and driving once more, more or less reliably. Sell it to a needy student... I just can't seem to decide to scrap it as it has but 145,000 km (~90,000 miles?) and it likely is good for many, many more miles. No automatic to blow up on it - and, in fact, a pleasant-shifting Mazda 5 speed... and interestingly - the best of the best set of pedals for effective heeling and toeing / double clutching of any car I've drivent!
Re: 1994 Ford Tempo / Mercury Topaz Rear Brake Pressure Limiters [Re: Cdn17Sport6MT] #5274690 11/22/19 03:33 PM
H
HangFire Offline
H
I would not sell a brake balancer experiment to a needy student.
Various musings: http://hangfire.net
Re: 1994 Ford Tempo / Mercury Topaz Rear Brake Pressure Limiters [Re: HangFire] #5274697 11/22/19 03:41 PM
Good pt. Could do nothing to those elements if i first determine what they are... pressure reducers or residual pressure valves... Anyone know?
Re: 1994 Ford Tempo / Mercury Topaz Rear Brake Pressure Limiters [Re: Cdn17Sport6MT] #5275951 11/24/19 05:46 AM
J
Jarlaxle Offline
J
I'd be stunned if they were residual pressure valves...wheel cylinders have used expanders so the valve is not needed since the 1970s, and they were universal since the early 80's.
1979 Coupe de Ville, 542 stroker, parked for winter frown
2011 Crown Vic P71, 5W-20 NextGen, Super Tech
2011 Sportster 883, parked for winter frown I hate winter.
Re: 1994 Ford Tempo / Mercury Topaz Rear Brake Pressure Limiters [Re: Cdn17Sport6MT] #5281595 12/01/19 01:55 AM
Thank you for your response... I have done a bit of research, and I am starting to conclude that they are rear brake pressure reducing valves... I guess there are two because the diagonals comprise the two brake circuits... not front versus back (where you could then have a single valve to cater for the rear).
If they are pressure reducing valves, I wonder if they reduce rear pressure to a % below front pressure... They certainly do not take the load on the rear of the car into account.
If they are no longer available, what would my options be? Wilwood or the like? Then experiment, on dry roads, to determine what the optimal setting is? I wonder if the optimal setting would change in the case of a wet road?
Any comments would be much appreciated!
