Mixing oil
by DerekPho - 12/15/19 03:03 AM
Grease plus Gear Oil
by PumpPusher - 12/15/19 12:59 AM
Costco/Kirkland 5qt-2pack synthetic $29.99
by wgtoys - 12/14/19 10:31 PM
Mercedes delays EV release
by JeffKeryk - 12/14/19 09:33 PM
Retired. Dreams are of work...
by rekit - 12/14/19 08:19 PM
Silly to charge a brand new battery?
by jayjr1105 - 12/14/19 08:06 PM
Help me pick a tire for our Volvo
by Ddub - 12/14/19 07:10 PM
Porter Cable 12V Batteries
by bcossa2001 - 12/14/19 06:52 PM
LG Red and Bio EP at Amazon
by demarpaint - 12/14/19 06:51 PM
2-stroke oil choices
by dnewton3 - 12/14/19 05:29 PM
Do cats like potato chips?
by atikovi - 12/14/19 03:45 PM
Buying a cheap, beater bicycle
by Oldtom - 12/14/19 03:14 PM
Metabo/Hitachi Impact driver $50
by Deere John - 12/14/19 03:03 PM
Ate up camshaft.pics
by Chris142 - 12/14/19 02:57 PM
Caprice cam swap. :)
by ls1mike - 12/14/19 02:55 PM
Electric boiler seems expensive to run
by ram_man - 12/14/19 01:42 PM
01 Crown Vic Bucking/Stumbling Uphill
by Gasbuggy - 12/14/19 01:20 PM
Where and how do you sleep?
by 53' Stude - 12/14/19 01:01 PM
Headlight Condensation
by rrretiree7 - 12/14/19 12:59 PM
Maik, Pluckster, DerekPho, mikinko, merrittgene
70129 Registered Users
51 registered members (Audios, 2015_PSD, 2002 Maxima SE, alcyon, AlienBug, 6 invisible), 997 guests, and 18 spiders.
Topics298,820
Posts5,141,930
Members70,129
Most Online3,589
Nov 2nd, 2019
Eneos CVT fluid #5273062 11/20/19 07:38 PM
B
bbhero Offline OP
B
I changes the CVT fluid in my car on Monday... I used this Eneos CVT fluid that us full synthetic. My car had gotten a bit loud in the past couple of weeks at low speed. The fluid that drained out actually did have some metallic shimmer to it as it was on my hand... That was note worthy because the first time I did a drain and refill it did not have that. The car has been quieter than it was before I added the Eneos CVT fluid. I am very impressed with this fluid. I am going to do another drain and refill in a couple of weeks... The other drain and refill had about 5k miles on it. I bet the first drain and refill did do some cleaning and that is why I saw what I saw on my hand as it drained out. The car is running quieter at low speed and accelerates very well. [Linked Image]
Nissan Altima 3.5 Coupe
Napa full synthetic 5w30 Wix 57356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Eneos CVT fluid [Re: bbhero] #5273085 11/20/19 08:01 PM
B
bronx Offline
B
What’s the make/model of your car?
Re: Eneos CVT fluid [Re: bronx] #5273088 11/20/19 08:05 PM
B
bbhero Offline OP
B
2008 Nissan Altima VQ 3.5 two door coupe...
288,000+ miles... Original CVT in it.
Re: Eneos CVT fluid [Re: bbhero] #5273120 11/20/19 08:35 PM
M
Mitsu4B11 Offline
M
That's great to hear. I've always read the horror stories about people's JATCO CVTs going bad just after that 100,000mi mark.
What fluid change intervals have you typically done to get you to 288k mi? Have you changed any of the transmission's filters?
I've been doing 30,000mi or 3 year drain and fills with my Mitsubishi that has a JATCO CVT in it.
'15 Mitsubishi Lancer 2.0L (4B11) // Pennzoil Platinum 0W-20
Re: Eneos CVT fluid [Re: Mitsu4B11] #5273124 11/20/19 08:42 PM
B
bbhero Offline OP
B
Being perfectly honest...
The first transmission fluid change was at 283,500 miles... Used Castrol Transmax CVT fluid in that first time early October...
Of note is here is my typical operation conditions... A whole, whole, whole lot of open highway driving... Like 98 percent of the miles and time the car has seen that. And it is not super hot in my area but 3-4 months of a year. In fact my area has not had widespread temps over 100°F hardly at all in the past 7 years.
So the car has seen the best operating conditions throughout it's time.
Re: Eneos CVT fluid [Re: bbhero] #5273126 11/20/19 08:43 PM
K
KGMtech Offline
K
Good that there are more options to the too expensive Nissan NS2. I have been using Pennzoil Platinum CVT2 fluid in my Maxima, I found a MSDS online for the Nissan NS2 that showed the producer of the fluid was SOPUS, which is Shell = Pennzoil.
The Pennzoil CVT2 is green just like the Nissan stuff. Eneos is also very good.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Eneos CVT fluid [Re: KGMtech] #5273133 11/20/19 08:49 PM
B
bbhero Offline OP
B
I wish I could have found that Pennzoil CVT-2 fluid... I would have gotten that if it was available.
Re: Eneos CVT fluid [Re: bbhero] #5273158 11/20/19 09:24 PM
M
Mitsu4B11 Offline
M
Interesting. Thanks for the reply. At least from your anecdote, it would seem that city miles clearly take a pretty severe toll on CVTs. I’ll keep that in mind when considering my highway/city driving percentages on when to change next. I’ll probably stick with the 30,000mi / 3yr interval for the time being as I probably do 70% highway and 30% city.
Re: Eneos CVT fluid [Re: bbhero] #5273170 11/20/19 09:45 PM
R
red7404 Offline
R
iam sorry. but i need a part number.
Re: Eneos CVT fluid [Re: bbhero] #5273385 11/21/19 08:05 AM
shrooms Offline
I tried this once with the Civic. It hated it.
Back to Honda CVT fluid. Perfect.
2002 Mazda MPV. Kendall T1 5W20, Fram XG2, Dex VI
2001 Honda Civic HX. Amsoil SS 5W20, Fram XG3717
Re: Eneos CVT fluid [Re: bbhero] #5273410 11/21/19 08:29 AM
A
ARCOgraphite Offline
A
A lot of folks had luck with the Valvoline fluid also at a low cost. It the friction modifier and anti foamant that are critical. for the pusher link belt.
The oil the dealer put in my car in a complete drain and refill was not as good as factory and it foamed a lot. I also suspect they did some reporgramming as it revved up a lot more than before the service.
The level may have been a tad high but the year of my trans has the submerged pusher belt that causes foaming. The later jatco CVT8 trans have the belt out of the sump, IIRC
BBHero. your trans as at end of life. I think you are good. Noo need to do another drain and fill.
Unless it makes you feel better.
Maybe a nice surf and turf dinner out would make you feel even better-er smile
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Eneos CVT fluid [Re: shrooms] #5273432 11/21/19 08:50 AM
B
bronx Offline
B
You tried the Eneos Eco CVT, or another the Eneos Model H fluid?
Model H
Eco CVT
Re: Eneos CVT fluid [Re: bbhero] #5273520 11/21/19 10:45 AM
J
JTK Offline
J
bb- I would do some research on your CVT. It may have a return line filter mounted behind the fluid cooler.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Eneos CVT fluid [Re: KGMtech] #5273642 11/21/19 12:55 PM
D1dad Offline
That’s awesome to hear. How much is the Pennzoil per qt?
Re: Eneos CVT fluid [Re: D1dad] #5273984 11/21/19 08:09 PM
K
KGMtech Offline
K
It was about $13 CAD per bottle, got it from a Shell distributor in the Toronto area.
1984 Yamaha XJ750RL
