school me on tint
by WhyMe - 02/19/20 04:27 PM
Michelin 7% Price Increase Effective 3/16/20
by Egg_Head - 02/19/20 03:58 PM
GunsInternational
by Yah-Tah-Hey - 02/19/20 03:39 PM
400hp VW Arteon confirmed for 2021
by wemay - 02/19/20 03:11 PM
redline 75W140
by mobilaltima - 02/19/20 02:50 PM
brake flush, upgrade to dot 4 or stay with dot 3
by apollo18 - 02/19/20 02:49 PM
I'm hoping it is the battery. 2016 Camry
by andyd - 02/19/20 02:48 PM
New Zoro 20% off $75 or more
by bullwinkle - 02/19/20 02:24 PM
New platinum beta ratio?
by mpgo4th - 02/19/20 01:40 PM
Lubrizol GF-6 Video Interview w/ Martin Birze
by ARCOgraphite - 02/19/20 01:31 PM
2008 GMC Sierra - AMSOIL SS 5w30 - 5300~ miles
by Samrsnow - 02/19/20 01:23 PM
Factory Ford filter cut open
by mpgo4th - 02/19/20 01:01 PM
VW coolant G12+ compatable G12++
by raaizin - 02/19/20 12:27 PM
Fun Electrical Gremlins with the Jeep
by Miller88 - 02/19/20 11:59 AM
Checking inner CV joints on fwd
by ram_man - 02/19/20 11:39 AM
AIR FRANCE FLIGHT 296
by 53' Stude - 02/19/20 10:51 AM
Brakes failing randomly
by Avery4 - 02/19/20 10:28 AM
Reliable Brand Washer / Dryer
by diyjake - 02/19/20 10:05 AM
Royal purple oil filters have gone downhill?
by Sprite - 02/19/20 09:25 AM
Meguiar's Ceramic Wax, $13.97 @ Wmart
by wemay - 02/19/20 09:23 AM
Antherzoll, mmahaley, Butterfly, TorchHypnosis, Tgibson
70751 Registered Users
110 registered members (28oz, 92saturnsl2, 53' Stude, 94astro, 2003f7, 9 invisible), 2,337 guests, and 29 spiders.
Topics301,660
Posts5,200,124
Members70,751
Page 1 of 3 1 2 3
Idemitsu ATF Type TLS-LV (WS) #5272632 11/20/19 12:47 PM
M
millerbl00 Offline OP
M
Did a complete fluid change with Idemitsu ATF Type TLS-LV (WS) I got from amazon for my 2013 highlander. Tried other fluids but this one by far is the best shifting one so far. Only $32 for 5 quart on amazon and its fully synthetic. FYI
Idemitsu 30040096-95300C020 ATF Type TLS-LV (WS) Automatic Transmission Fluid for Toyota/Lexus/Scion-5 Quart
Re: Idemitsu ATF Type TLS-LV (WS) [Re: millerbl00] #5272640 11/20/19 12:59 PM
dkryan Offline
“.......complete fluid change...?
How? Using an extractor?
2014 Nissan Altima 2.5 SL
Valvoline M-E 5w-30/Fram Ultra
2005 Toyota Highlander 3.3L
QSUD 5w-30/Fram Ultra
2019 Subaru Outback 2.5L Limited
Idemitsu Zeepro 0w-20/Wix XP
Re: Idemitsu ATF Type TLS-LV (WS) [Re: millerbl00] #5272657 11/20/19 01:14 PM
M
M
Multiple Drains and fills
Re: Idemitsu ATF Type TLS-LV (WS) [Re: millerbl00] #5272701 11/20/19 01:49 PM
J
JeffKeryk Offline
J
Gonna use it on the GS soon. Idemitsu is good stuff. Our TSX loves it. Smooth, strong shifts and better low end pull.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Idemitsu ATF Type TLS-LV (WS) [Re: millerbl00] #5272740 11/20/19 02:28 PM
Z
ZebRuaj Offline
Z
Recently used it on a 2011 Sequoia drain and fill. I like that its 5qts and not the 4qts like others. Gives you some wiggle room for miss-measurements and spills. . Sequoia on ramps pulled out a tad under 5 qts. Did the "put in what came out" method.
~I fix stuff.
Re: Idemitsu ATF Type TLS-LV (WS) [Re: millerbl00] #5273624 11/21/19 12:42 PM
M
M
I found the highlander VERY sensitive to fluid level 6oz over or under made a difference
Re: Idemitsu ATF Type TLS-LV (WS) [Re: millerbl00] #5274771 11/22/19 05:01 PM
J
Joephu Offline
J
I find it so odd that they go through all that work to make a WS specific fluid and not touting that is a full synthetic. That should be plastered on the label in big letters. I just bought 2 gallons from Amazon and will be doing a flush too on my 2016 Lexus ES350.
Re: Idemitsu ATF Type TLS-LV (WS) [Re: millerbl00] #5276065 11/24/19 09:06 AM
J
jrvn Offline
J
I was going to use the Idemitsu T-IV version in my truck but came across this and decided to go with the Toyota OEM stuff https://www.tacomaworld.com/threads/atf-type-for-a-2015-toyota-tacoma.573652/#post-18959083
Re: Idemitsu ATF Type TLS-LV (WS) [Re: Joephu] #5276903 11/25/19 09:06 AM
M
M
I emailed them. They said it was full synthetic.
Re: Idemitsu ATF Type TLS-LV (WS) [Re: millerbl00] #5284709 12/04/19 07:53 AM
M
M
Update after 3000 miles on this transmission oil I am very pleased. With other oils the transmission would start shifting goofy again after about 300 miles. With this oil its night and day. All the bad characteristics are gone and shifts are very stable. Good stuff!
Re: Idemitsu ATF Type TLS-LV (WS) [Re: Joephu] #5340691 02/04/20 09:41 AM
F
fordtough Offline
F
Nithing in the USA is full Synthetic Some "synthetic" oil is made from Group III base stock, some from Group IV. Some from a blend of the two. Mobil sued Castrol and Castrol prevailed in showing that their Group III base stock oil was changed enough that it qualified as full synthetic. Since then API has removed all references to Synthetic in their documentation regarding standards. "Full synthetic" is a marketing term and is not a measurable quality.
Aisin full synthetic sold in the UK group 4 synthetic
https://www.amazon.co.uk/Aisin-ATF-...9066-1-1&vehicleName=Lexus+IS+II+250
2011 Lexus IS250 AWD
Re: Idemitsu ATF Type TLS-LV (WS) [Re: millerbl00] #5341124 02/04/20 06:11 PM
R
RoyFJ Offline
R
AISIN makes a full synthetic WS compatible oil called AFW+ that I use.
http://www.aisin.com.sg/wp-content/...ynthetic-AFW_Multi_Product-Datasheet.pdf
Re: Idemitsu ATF Type TLS-LV (WS) [Re: millerbl00] #5341412 02/04/20 11:01 PM
Chuckh Online Content
Online Content
Who would sell this in the USA though? I can't seem to find a place to get it. I am thinking that this fluid might have been an attempt to address complaints people had with WS. Some say that WS shears too much and does not last long. While I agree that fluid color is not everything, WS does come out black! It makes me want to have a shot of espresso when I see how dark it gets!! I have only seen AFW+ on sites for places that are not in the USA so far such as India. I wonder when this AFW+ fluid will become easier to get. If anything I would expect to find it at a Toyota dealer eventually.
Re: Idemitsu ATF Type TLS-LV (WS) [Re: millerbl00] #5341801 02/05/20 11:58 AM
N
nthach Offline
N
Aisin sells a rebottle of Toyota WS in the US. The stuff mentioned is a "superior" type that is acceptable for use but not a perfect match to WS.
The old formulation of WS turned purple once exposed to air. The new XOM formulation does not. The last D/F I did on the Prius came out dark red. The previous ones were usually brown, despite 30K drains.
Re: Idemitsu ATF Type TLS-LV (WS) [Re: millerbl00] #5341976 02/05/20 02:57 PM
R
RoyFJ Offline
R
The AFW+ made my shifting far better than the original WS and that with a transmission cooler. During hard use in hills and sand as well as long stop and go traffic under hot sun, the shifting remains way smoother than with WS fluid. Incidentally the AISIN site lists two Toyota vehicles as being compatible, one is Prius and other is Land Cruiser with A750. That Land Cruiser also came OEM with factory air to oil auxiliary transmission cooler.
The AFW+ is available in middle east, Europe, Russia and other regions as well as Asia. The brochure recommends full flush every 20.000km with the oil but I would guess thats a general recommendation from the company to be on the safe side. It seems to have superior pour and flash point than the WS fluid but then its expected from a synthetic fluid. From the Russian forums that I have read the results are very positive even for long term use. Its also far cheaper than WS fluid.
Page 1 of 3 1 2 3
