Originally Posted by smc733
Really glad to hear that most of you think the sound is normal, and so many have had Theta II engines last long without issue. It adds to my suspicion that the engine may just not be as tolerant to poor maintenance, and for those of us who ensure timely oil changes, the chances of an issue might be lower.
The one other issue I very occasionally (less than once a month) have, is that on a first of the day start, it will lug for 3 seconds as if it is going to stall, then the RPMs come up. Probably nothing. As far as oil burning, I've been keeping an eye on that, and I haven't lost a drop, dipstick still goes right to the second dot right up until the oil change. The dealers around here always go with 5w-30 since Hyundai revised the recommendations upwards.
I'm going to have the dealer take a look when I get my next oil change (this coming weekend), but it seems like I can rest a bit easier and just keep the car as I like it.
Is your air filter clean or dirtied up?..You have 70k on this DI engine, have you ran a system cleaner (like a Berrymans) before or even a spray intake cleaner for the valves? Really dirty, caked valves can interfere with air flow, combustion and the valve's ability to shut all the way.
You can clean them yourselves but it's more involved then just dumping a can of cleaner into the tank. You've got to introduce the cleaner via the intake. A shop can do this if you don't want to bother, but it'll cost ya a pretty coin..
Your throttle plate could be dirtied up as well. Cleaning that would be similar to the valve cleaning but a little more involved because you really should get in there with a good solvent (i use carb cleaner), toothbrush and rags. And while you're in there, check the PCV valve.
