2013 Escape 2.0 Ecoboost surge
by HoosierJeeper - 01/19/20 10:36 AM
European Tools via Amazon - New Lug Wrench
by JHZR2 - 01/19/20 09:57 AM
Samsung 32 inch 4K curved monitor at Costco
by Cujet - 01/19/20 09:55 AM
2009 corolla 1.8
by Bettez88 - 01/19/20 09:41 AM
Remote key - OEM vs aftermarket
by AZjeff - 01/19/20 08:13 AM
Toyota Tundra Warranty
by Tundra73 - 01/19/20 08:10 AM
Shell Rotella gas truck oil change intervals?
by gtrplr71 - 01/19/20 07:12 AM
Ford Focus belt idler puller bolt ?
by rkpatt - 01/19/20 06:51 AM
Havoline 5w20 $1.72/quart
by Villalobos - 01/19/20 05:42 AM
Amazon 5qt PUP 5w-20 $16.24
by Matt1980 - 01/19/20 03:42 AM
US Miltary News - F22
by ZeeOSix - 01/19/20 03:09 AM
OEM to Ravenol
by graphine - 01/19/20 02:38 AM
D905 Brake Pads: Bosch vs. Centric vs. Akebono
by The Critic - 01/19/20 01:55 AM
Dodge dart running issues after filling up fuel
by ram_man - 01/19/20 12:58 AM
Akebono ProAct brake pads now include hardware
by The Critic - 01/19/20 12:43 AM
16 Audi S3 G13 Coolant - 40,500 miles
by agpatel - 01/19/20 12:43 AM
BMW “G3” Axle Alternatives?
by E365 - 01/19/20 12:20 AM
Scan Tool recommendation
by zmelli - 01/18/20 11:57 PM
Keyless Entry Help Needed
by DeafBrad - 01/18/20 11:55 PM
75/140 owners manual vs 75/90 tag
by BigGee - 01/18/20 11:36 PM
madjid, michWB, Brianhefty, JimBremer, Katdaddy
70471 Registered Users
94 registered members (Alex_V, 4WD, alchargo, ArrestMeRedZ, AlienBug, 11 invisible), 2,384 guests, and 18 spiders.
Topics300,313
Posts5,173,070
Members70,471
Most Online3,728
Jan 11th, 2020
Door hinge pins and bushings #5272126 11/19/19 08:22 PM
P10crew Offline OP
My 90 chevyrado ate another set of drivers door hinge pin bushings tonight. Got in it at work to head home tonight and the (censor) door wouldn’t close. Had to get out and lift the door up and close it then slide in the other side. Checked it out at home in the light and wala the second set of HELP bushings had broke the shoulder off the bushing , the bushing slid down the pin and the pin worked its self up and just a little more and I think the door could have fell off of the truck. I don’t think the bottom pin alone would have supported the weight of the door. So now I am not buying any more HELP junk. Any body got any opinions as to the quality of pin rebuild kits if I were to use dealer GM kits versus this junk? This is the second set that has failed in 2 years
Re: Door hinge pins and bushings [Re: P10crew] #5272139 11/19/19 08:34 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Sometimes aftermarket parts are an improvement on a known issue, but it’s far from guaranteed. I’d chase down the OE part.
I’d also have a look at why this is happening. What’s the root cause? Does it hold any lubricant? Does water get in? Something else?
Seems like there must be some fundamental reason behind this besides junk parts.
Re: Door hinge pins and bushings [Re: P10crew] #5272160 11/19/19 09:01 PM
clinebarger Offline
GM sold a greasable pin kit for those.......GM part# 19332887
2001 Chevy Camaro L92/4L80E
Re: Door hinge pins and bushings [Re: clinebarger] #5272166 11/19/19 09:05 PM
spasm3 Offline
$115
https://www.ebay.com/itm/Clipsandfasteners-Inc-Door-Hinge-Pin-and-Bushing-Repair-Kit-For-GM-19332887/352146240302?epid=2193467401&hash=item51fd8d332e:g:5AgAAOSwcfdbAvPj:sc:USPSFirstClass!27410!US!-1
$93
https://www.amazon.com/Genuine-GM-P...s=19332887&qid=1574219081&sr=8-1
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Door hinge pins and bushings [Re: P10crew] #5272187 11/19/19 09:23 PM
P10crew Offline OP
Ooo thanks for the numbers and links. I got the truck in the shop and the pins and bushings pulled. I’m gonna go see the kids at my local dealer tomorrow and see what they have in stock. Tell me something though. Aren’t the sintered bushings supposed to be of real hard material and not soft brass? There appear to be just normal soft sintered bronze material.
Re: Door hinge pins and bushings [Re: P10crew] #5272237 11/19/19 11:12 PM
P10crew Offline OP
If they have the greasable kit that’s what I will get. Thanks
Re: Door hinge pins and bushings [Re: P10crew] #5272739 11/20/19 02:28 PM
Duffyjr Online Content
Online Content
Yes thanks for the links, my 89 is just started to sag a bit. These doors on these old trucks are heavy, the hinges appear to be way under engineered for their weight.
89 GMC Sierra Advanced 5w30/51036 Wix
08 Lucerne CX Advanced 5w30/1040 Gold
18 Toro Super Recycler T5 10w30
Re: Door hinge pins and bushings [Re: P10crew] #5272978 11/20/19 06:31 PM
super20dan Offline
every gm product had under engineered door pins and hinges
99 silverado 5.3
2003 tundra v6
1981 toyota cressida wagon
2003 kia sorento
04 toyota highlander 4cyl 2013 toyota rav4
Re: Door hinge pins and bushings [Re: super20dan] #5273154 11/20/19 09:12 PM
Dinoburner Offline
Or underlubricated.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: Door hinge pins and bushings [Re: super20dan] #5273163 11/20/19 09:32 PM
Saabist Offline
Compared to the nylon-bushed door hinges AMC used in the 1970s and 1980s, GM hinges were a paragon of durability.
Re: Door hinge pins and bushings [Re: P10crew] #5274194 11/22/19 05:47 AM
cronk Offline
Ive had a few gm trucks of that era, so I know your plight!
When I worked at a Gm parts counter, we only stocked the standard replacement pins and bushings because no one ever wanted to pay the big shot for the greasable kit.
The standard pins and bushings from GM are better quality than the Dorman ones, in my experience.
2008 Ford F350
2008 Kia Spectra
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: Door hinge pins and bushings [Re: cronk] #5274564 11/22/19 12:34 PM
bdcardinal Offline
We have the same thing with Ranger tailgate handles and older truck inner door handles. Ford offered both in metal at one point, then changed to plastic. The metal ones still fit and never break, but they cost more.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Door hinge pins and bushings [Re: P10crew] #5274997 11/22/19 09:23 PM
P10crew Offline OP
I bought the stock ones. Shoulder bushing looks different than the help ones.
Re: Door hinge pins and bushings [Re: P10crew] #5275014 11/22/19 09:41 PM
caprice_2nv Offline
2005 Silverado I drive for work the driver's hinge pins wore out at about 260,000 kms (160k or so). Now a couple years later at 308,000kms it needs them again. Probably dorman parts.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
79 Honda CX500
Re: Door hinge pins and bushings [Re: P10crew] #5275025 11/22/19 09:59 PM
P10crew Offline OP
I should have took a close up pic of both bushings.The help ones had huge air pockets in the bushing. Looked like they were cast. GM ones looked machined with no air pockets
